Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
73 registered members (4WD, 762fermeandyou, 86cutlass307, 55hambone, Astro14, aquariuscsm, 2 invisible), 2,031 guests, and 39 spiders.
Topics306,299
Posts5,289,806
Members71,618
Only 1 grease for dry applications #5409536 04/21/20 01:57 PM
R
Reddy45 Offline OP
R
Why would someone own both a hi-temp grease and non-hi-temp grease? Let's stick with lithium complex no 2 greases to keep things simple.
If water washout is not a concern then the hi-temp grease should cover every application, right?
I know in some cases, the non-hi-temp grease tends to be tackier which helps it cling to certain applications, but nowadays it is not difficult to find a hi-temp grease that checks off all the right boxes.
Re: Only 1 grease for dry applications [Re: Reddy45] #5409561 04/21/20 02:32 PM
samven Offline
I agree, I went to Red and Tacky for everything unless some specific non lithium based grease is called for. I got tired of always running out of 1 or the other just when I needed it so now I just keep 3 or 4 tube of the Red stuff and both guns (the one in the garage and the one in the shop) have the same so I dont need to reload in the middle of a job I just walk out and grab the other gun then take care of refilling later. I used to keep a Moly grease around too but that stuff stained everything that got within 10 ft of it.
Re: Only 1 grease for dry applications [Re: Reddy45] #5409827 04/21/20 08:08 PM
doitmyself Offline
That's the conclusion I came to about 20 years ago when deciding on a grease for my workplace ag., vehicle, and outdoor power equipment applications. It works even better if it is green, blue, or red because, well, people associate colored grease as something special, LOL.
Re: Only 1 grease for dry applications [Re: Reddy45] #5411535 04/23/20 06:49 PM
B
buck91 Offline
B
Valvoline Synpower for everything for me. Its a few bucks more but I don't go through enough to matter.
2018 F150 Screw 4x4 2.7L Ecoboost
2011 F150 Scab 4x4 5.0L
1996 Mustang GT 5spd/ragtop
