Inside of new windshield fogs up
by mclasser - 06/06/20 02:51 PM
Oil considerations Duratec 3.0 V6, 85k miles
by 97tbird - 06/06/20 02:22 PM
Best way to charge and maintain a battery?
by Avery4 - 06/06/20 02:10 PM
HM oils vs HM oils
by aquariuscsm - 06/06/20 12:37 PM
Confusion: oil grades, yellow metal, vintage
by LouK2 - 06/06/20 12:21 PM
New Rad needed Nissens vs APDI
by Bluestream - 06/06/20 11:58 AM
Oil filter cap wrench suggestions.
by RichR - 06/06/20 11:55 AM
AC Woes
by artbuc - 06/06/20 11:44 AM
Part source Canada TOTAL QUARTZ 9000 50% no tax
by Bluestream - 06/06/20 11:18 AM
Pressure washer foam gun
by Donald - 06/06/20 10:50 AM
Pentastar oil changes
by 4WD - 06/06/20 10:25 AM
Oil Pan Plug Problem
by 2015_PSD - 06/06/20 10:14 AM
Continentals out of balance
by wolf_06 - 06/06/20 10:04 AM
2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
80 registered members (2015_PSD, 4WD, Avery4, bmod305, b1amgm47, 7 invisible), 2,248 guests, and 68 spiders.
Topics306,299
Posts5,289,798
Members71,618
garage floor coating ? #5409506 04/21/20 01:13 PM
T
tomcat27 Offline OP
T
my head is spinning: I am looking for a durable, non-slippery garage floor coating that wont peel or lift.
certainly floor prep is very important
I have a 30 x 30 garage and a 30 x 40 garage. I'm surprised how much this will cost!
Every product that I have researched gets: great reviews and also "fails"
I'd prefer to use a clear in one, and a dark color in the other.
I'm trending towards Rust Oleum - although it sounds like I may need/want to add a topcoat with grit in it.
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
Re: garage floor coating ? [Re: tomcat27] #5409509 04/21/20 01:21 PM
spasm3 Offline
I used a solvent floor stain. Recommended by user demarpaint. I used an H&C brand solvent floor coating. It can be a bit slippery when wet. Prep is everything.
Before
[Linked Image]
After
[Linked Image]
[Linked Image]
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: garage floor coating ? [Re: tomcat27] #5409515 04/21/20 01:35 PM
Inked Offline
Toolbox Police called. You must surrender your box to me immediately!
2017 Acura MDX
2007 H/D FLSTC
Early is on time; on time is late; late is unforgivable.
Re: garage floor coating ? [Re: tomcat27] #5409526 04/21/20 01:47 PM
SubieRubyRoo Offline
My brother has a box even bigger than spasm's really nice one. He's got more wrapped up in his box and tools than most people outside of major cities spend on their houses. The Snap-On, Matco, and insurance salesmen are his biggest fans! LOL
De omnibus dubitandum.
Re: garage floor coating ? [Re: tomcat27] #5409537 04/21/20 01:57 PM
Chris142 Online Content
Online Content
The guys next door did some sort of epoxy but threw sand on it for traction.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: garage floor coating ? [Re: tomcat27] #5409539 04/21/20 01:59 PM
IMSA_Racing_Fan Offline
At a motorcycle dealership I once worked at we recoated the floor prior to closing down for Christmas with a two part paint made for the purpose, it was tough as nails. We may have mixed in sand to provide traction as a safety measure.
Re: garage floor coating ? [Re: tomcat27] #5409544 04/21/20 02:09 PM
R
Reddy45 Offline
R
The garagejournal forum has massive threads on this topic. A lot of those guys try to find floor stores selling discounted/clearanced porcelain tile which is supposed to be much better than any coating. If I was going to dive into a big project like this, I would see if I could do tile first.
Every time I've used an epoxy coating, hot tires eventually killed it.
Re: garage floor coating ? [Re: tomcat27] #5409548 04/21/20 02:13 PM
spasm3 Offline
The nice thing about the H&C solvent stain, is you can smooth out marks with xylene. It will melt the coating. It holds up to moving things around. If it leaves a mark, just wet blue cloth with xylene and smooth it out.
I let it set 3 months, tires do not mar it.
Re: garage floor coating ? [Re: tomcat27] #5409551 04/21/20 02:13 PM
Donald Offline
There is a lot of prep work involved. I mean a whole lot. Including grinding. The companies that do this professionally charge a fortune. My current garage is carpeted. Not sure of the long term life of a carpeted garage.
2015 Ford F-250 w/Powerstroke
Re: garage floor coating ? [Re: Donald] #5409553 04/21/20 02:17 PM
spasm3 Offline
It is a good bit. I did not grind. I have even had a large used oil spill in the past. I degreased with simple green and stiff brushed it ( the whole floor). Pressure washed, degreased again and rinsed. Acid washed it, rinsed 3 times.
Used a large floor drum fan to dry it. Painted the edges/corners of the garage in with a brush, then rolled on 2 coats.
Only down side is it is a touch slick when wet. If you leave the garage door up when raining or humid, water will condense on the floor, but thats not often. I have a large entry mat at the garage door.
Re: garage floor coating ? [Re: tomcat27] #5409589 04/21/20 03:10 PM
skyactiv Offline
Forget the box store garbage and go to a company owned PPG paint store that makes coatings used in industrial settings, U.S. navy warships... .
Google "PPG Megaseal coatings" and explore the many different coatings they offer.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: garage floor coating ? [Re: tomcat27] #5409597 04/21/20 03:16 PM
J
JohnG Offline
J
And there's always the interlocking floor tile, thick vinyl I think. Maybe from Weathertech? My neighbor has it in the RED/Black squares, but he gas more money than God! Nice though.
Re: garage floor coating ? [Re: tomcat27] #5409608 04/21/20 03:27 PM
deanm11 Offline
I had 3-coat commercially applied epoxy applied in my new house in 2003. In basement too.
- Absolutely zero tire pickup
- I don't recall if they did the acid or grinding approach for prep
- Dang slick when wet. Strategic use of mats, at least in winter... some grit in the top coat helps a bit, but only a bit in our experience
- If you drop a heavy tool, it will chip. If you have extra material or even a '1 part' expoy in a good match it will touch up ok
I would still go this way again. Also have it on the basement floor... with that and the poured walls painted the basement is semi-finished
Dean
2012 Subie Impr 2.0 142k M1EP 0w20 7.5k
2002 Tahoe 5.3 171k 5w30 syn 7.5k
Re: garage floor coating ? [Re: tomcat27] #5409617 04/21/20 03:33 PM
T
Touring5 Offline
T
I did my garage 6 years ago. I used the Rustoleum solvent based epoxy product (not the water-based one). Prep is the hardest part: used their epoxy patch for cracks and some spalling from winter salt AFTER using an acid based etch to get the surface rough. Applied with a 18" (or was it 16"?) paint roller. Even with the door open, you need to use a respirator with cartridges for solvents. I also doubled up on the fine sand to make sure it wouldn't be slippery when wet. IMO, the vinyl chips are nice for appearance but are a hindrance when trying to sweep or mop the floor.
FIRST LAW OF DEBATE
Never argue with a fool - people might
not know the difference.
Re: garage floor coating ? [Re: tomcat27] #5409722 04/21/20 06:11 PM
B
benjy Offline
B
there are many options BUT they have one thing in common $$$$$$ to be dine right. if you know how DIY could save $$ as well. putting a rough finish on the newly poured floor + using a clear sealer saves $$$$ but not as nice as a well done pro job, as always it depends on the $$$$$ you can spend
