Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
99 registered members (aaronc7, AbbyMaster, 3turbodiesels, 86cutlass307, 53' Stude, 830Lee, 4 invisible), 2,236 guests, and 38 spiders.
Topics306,053
Posts5,286,540
Members71,593
2015 Grand Cherokee 5.7 Oil Recommendations #5409457 04/21/20 11:44 AM
E
Env1ous Offline OP
E
Hi all,
Just picked up a 2015 GC with the 5.7 hemi. I have been doing a lot of reading. From factory it calls for 5w-20 and I see a lot of debate and conflicting infor about running a 20 vs a 30 weight oil due to MDS. I do know that a 20 weight can infringe on the territory of a 30 in thickness. So is it true a 30 weight will cause issues with the engine?
Around town/highway in sport mode I notice the oil temp is around 230 and out of sport mode it is around 205-210. What is a thicker 20w oil or a thinner 30w oil?
I just did my first oil change and used Castrol Edge black botte in 5w-20. And found out that it came from the factory with the wrong dipstick lol.
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409462 04/21/20 11:50 AM
E
earthbound Offline
E
I run 5w30 in mine with no issues whatsoever....mds related or not...
19' Honda Crv 1.5T
19' Ram 1500 5.7 Hemi
06' Pontiac/yoda Vibe
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409481 04/21/20 12:29 PM
sloinker Offline
Many Hemi users use Red Line. It is on the thick end of the spectrum for the 5W20 but is heralded for helping quiet lifter tick. Not cheap.
https://www.redlineoil.com/5w20-motor-oil
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409488 04/21/20 12:37 PM
J
jeepman3071 Online Content
Online Content
J
I ran 5w30 Pennzoil Platinum in my dad's 2013 GC 5.7L with no issues until 100k miles and have been using Castrol 0w40 since then. At 160k miles currently it's had no noises and no oil consumption. Oil is changed every 10k miles by the oil life monitor and he does a lot of highway and towing.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409534 04/21/20 01:55 PM
Z
Zaedock Offline
Z
If MDS is messed up from a 30wt, what do people in cold climates do? 5W20 is a 30 or even 40wt bopping around town in winter.
I would say a 30wt will not cause issues with the engine.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Zaedock] #5409546 04/21/20 02:10 PM
53' Stude Online Content
Online Content
Yeah, my toyota has VVT and never any issues using 0w40, 5w40, or 15w40 in winter.
2009 Toyota Camry LE
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409580 04/21/20 03:01 PM
O
OVERKILL Offline
O
You'll have no issues running a heavier oil, however there's nothing wrong with running a 5w-20 or 0w-20 as called for, I run M1 EP 0w-20 in our truck with the same engine and have no concerns about it, given the engine's track record on a 20-weight.
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409598 04/21/20 03:17 PM
T
The_Nuke Offline
T
steer clear of 20w-50; everything else will be fine...although in your climate, 10w-30 may also be a poor choice.
0w-20, 0w-30, 0w-40, 5w-20, 5w-30, etc. are all fine for that engine in your climate.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409599 04/21/20 03:18 PM
O
OilReport99 Offline
O
Run an approved 20 grade oil and sleep well. It is what the manufacturer calls for. Though a 30 grade can be safely ran, you will have a hard time finding a proof that 30 is better.
A forum poll is not a proof, btw.
2018 Ram 1500 - VME 5W-20
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409669 04/21/20 04:51 PM
U
umungus1122 Offline
U
Originally Posted by Env1ous
Hi all,
If the actual oil temp(measured manually independent of the car's gauge) is actually getting to 230, I'd use a syn 10w-30 in the summer, 5w-30 winter in CO.
'95 Chevy 1/2t 305 208k -NexGen Maxlife 5w-30, Wix filter
'04 Crown Vic 95k Maxlife full syn 5w-20
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409727 04/21/20 06:17 PM
O
Oildudeny Offline
O
No harm using a quality 5w20 synthetic
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: umungus1122] #5409741 04/21/20 06:30 PM
O
OVERKILL Offline
O
Hi all,
It's likely the temp he's seeing through UConnect, and I'm sure whatever temp the oil is at was considered during the engine's design and testing.
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409766 04/21/20 06:59 PM
CT8 Offline
The internet is a third B.S. a third regurgitated advertising claims and a third facts. The hard part is sifting through the first 2/3.
2015 F150 2.7
2018 F350 6.2
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Env1ous] #5409896 04/21/20 09:44 PM
L
Loobit Offline
L
My mom's 2013 Hemi Jeep loves Royal Purple API 5w-20. It silenced some loud ticking it made at only 35,000 miles. It's been 10,000 miles and 3 intervals with RP and it sounds and runs like a new engine. RP is expensive, but it's rarely driven yet always gets driven for a long time to get the engine hot. This allows me to only change oil once a year, and Amazon sometimes sells RP 5w-20 much cheaper than even Walmart.
Oh and the dipstick. If you still use the old one, put seven quarts and drive it around for 15 minutes to get the oil hot. Let vehicle sit overnight and then check the level in the morning. This gives you the most accurate reading! It's safe if it's right in the center of the safe zone, or slightly above it. Different oil filters can change the level for 7 quarts.
Re: 2015 Grand Cherokee 5.7 Oil Recommendations [Re: Loobit] #5409950 04/21/20 11:27 PM
O
OVERKILL Offline
O
So it has 45,000 miles on it, and you've changed the Royal Purple 3x already since 35,000 miles? Sweet Jesus that's a waste of an expensive (and mediocre if it isn't the Synerlec version) synthetic oil crzy
