Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
90 registered members (aleneros, 53' Stude, 2015_PSD, 2009Edge, Ag76, amblerman, 9 invisible), 1,904 guests, and 43 spiders.
Topics306,089
Posts5,287,208
Members71,596
Recommend Battery Charger #5409447 04/21/20 11:28 AM
P
Phishin Offline OP
P
Recommend a battery charger for me.
Uses: Car, truck, and smaller batteries found in garden tractors.
Options: Fully automatic, provide a starting boost if the battery is DEAD. Maybe more options would be nice, but I'm unaware at this time.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Recommend Battery Charger [Re: Phishin] #5409465 04/21/20 11:52 AM
R
Rand Offline
R
full auto, small battery, and 50amp+ boost is asking for alot of features.
the 20amp solar pro-logix is decent for the price.
2/10/20 amp modes 6/12volt agm/standard etc.
prologix 20amp without boost.
this one has "engine boost" mode not sure exactly that is but its more than 20amp
amazon link pro-logix 20amp w/boost
Re: Recommend Battery Charger [Re: Phishin] #5409479 04/21/20 12:27 PM
U
UncleDave Offline
U
I do not know of a charger that meets those criteria.
That prologix charger is not fully automatic.
One needs to select voltage, amperage, and chemistry.
At 20 amps you want either a remote temp gauge, and or a temp gauge in the positive clamp like the Ctek 2500 has
An ambient temp sensor in the body of the charger isnt that helpful as the charger could be sitting on a cold concrete floor or bench and the battery could be sizzling.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Recommend Battery Charger [Re: UncleDave] #5409489 04/21/20 12:41 PM
P
Phishin Offline OP
P
When I stated "automatic" I mean, it has multiple charging stages and automatically switches between those....until the battery is fully charged, and then the charger goes into a "maintenance" mode.
I am fully capable of selecting voltage and chemistry.
Re: Recommend Battery Charger [Re: Phishin] #5409504 04/21/20 01:08 PM
Donald Offline
There are many that are fine if you can skip the "boost" feature. What is your budget?
2015 Ford F-250 w/Powerstroke
Re: Recommend Battery Charger [Re: Phishin] #5409507 04/21/20 01:18 PM
R
Redright9 Offline
R
Not sure if this fits what you are looking for... I have a cheap solar panel charger that plugs into the 12v adapter and has a connector to connect to the battery as well. sits on the dash and has very low amps so it cant overcharge... Too weak to. It works great at keeping batteries maintained that the vehicle sits outside.
https://www.amazon.com/gp/product/B0006JO0KG/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
I have a "normal" bigger charger for batteries I need to charge within that day/hours.. and a jump pack for quick starts.
Re: Recommend Battery Charger [Re: Phishin] #5409508 04/21/20 01:18 PM
T
The_Nuke Offline
T
Are you sure you would even use the boost feature of an equipped charger?
Modern vehicles are smart enough now to turn off lights that left on and other accidental battery drains. I haven’t needed a boost for a dead battery in a long time. Sure I’ve had dead batteries recently, but they were all actual dead batteries that needed replacement and couldn’t be merely jumped off and allowed to continue once the alternator was engaged.
2012 Charger Pursuit aka "The Bacon Hauler"
- 5.7L + NAG1 (A5) + 3.07 (215mm)
Re: Recommend Battery Charger [Re: Phishin] #5409524 04/21/20 01:44 PM
SubieRubyRoo Offline
I have the Pro-Logix as well and it's "revived" several batteries that were written off by parts stores. Plus if left connected, it switches automagically to a float mode, and will keep the battery ready through winter or something. Even on 10A, it's not super fast in completing a cycle, but then again, it's not a jump starter. If I were going short term revival, the 20A with boost is what I'd get.
De omnibus dubitandum.
Re: Recommend Battery Charger [Re: Phishin] #5409529 04/21/20 01:51 PM
W
WobblyElvis Offline
W
The best bang of the buck is an old manual charger you may find at a yard sale or whatever. I have 4 chargers, 2 automatics, 1 tiny trickle charger and 1 old manual style. I usually end up using the old manual charger but you have to keep an eye on it. I you want one that will boost a vehicle, I suggest one that has at least a 100 amp boost setting
Re: Recommend Battery Charger [Re: Phishin] #5409658 04/21/20 04:40 PM
R
ripcord Offline
R
I have the 15amp version of this unit: https://www.walmart.com/ip/STANLEY-25-Amp-Battery-Charger-with-75-Amp-Engine-Start-BC25BS/38243762
The jump start option is fairly limited and is really only useful on the garden tractor or if the car can just barely not turn over.
Re: Recommend Battery Charger [Re: WobblyElvis] #5409775 04/21/20 07:10 PM
W
Wolf359 Online Content
Online Content
W
Just how much are they at the garage sale? A regular 8 amp charger without boost capabilities is about $35 at Amazon. Used to be cheaper around $25, but probably Amazon doing its thing of raising and then lowering prices. You'd be hard pressed to find an 8 amp automatic charger for less, new or used.
https://www.amazon.com/Schumacher-SC1279-12V-Rapid-Charger/dp/B07DM22XTN
Re: Recommend Battery Charger [Re: Phishin] #5409789 04/21/20 07:21 PM
B
BHopkins Offline
B
I would also recommend a Pro-Logix. Totally automatic as you described. However, Pro-Logix has discontinued the boost feature in all but their most expensive model, which runs about $100. It's a good charger, but a steep price to pay for the boost feature.
https://www.amazon.com/Clore-Automotive-PL2545-Intelligent-Battery/dp/B007P7ABE6?th=1
The model I have has a boost feature, but it has been discontinued. I just recently used the boost feature for the first time when my neighbor left a door open overnight on her Nissan Rogue. But if I didn't have the boost feature, I could have just jump started her car with one of mine.
In God we trust. All others bring data.
2013 Subaru Outback 2.5i - M1 HM 0W-20 & NAPA Gold filter
2014 Mercedes E350 M276 - M1 European 0W-40 & Purflux filter
Re: Recommend Battery Charger [Re: Phishin] #5409830 04/21/20 08:11 PM
U
UncleDave Offline
U
You dont want to charge a wet lead acid at much more than 20% of the face value AH's-
This makes a 15 or 25 amp charger likely too large for the mower/tractor battery.
UD
Uncle Dave
Re: Recommend Battery Charger [Re: Phishin] #5409833 04/21/20 08:15 PM
R
R1jake Offline
R
I prefer a good hobby grade charger with a converted psu power supply for all of my charging needs. This way you can charge any battery you come across.
Yamaha R1 5vy
94 Ford E150
09 Pontiac vibe AKA Toyota Matrix
02 dodge neon my winter car, refuse to drive my van in the salt.
Re: Recommend Battery Charger [Re: R1jake] #5409846 04/21/20 08:30 PM
P
Phishin Offline OP
P
You got a link?
