ATF Flush vs Drain and Fill
by diyjake - 06/01/20 11:24 AM
Is Your Vehicle Deadly?
by SubLGT - 06/01/20 11:02 AM
Question on the bottom of bottle with Penz Platinum
by babyivan - 06/01/20 10:55 AM
Used Mitsubishi Lancer prices
by 97prizm - 06/01/20 10:32 AM
Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
109 registered members (ABN_CBT_ENGR, 830Lee, ArrestMeRedZ, Al, Avery4, 2015_PSD, 11 invisible), 2,294 guests, and 38 spiders.
Topics306,121
Posts5,286,862
Members71,588
Dexos users, which oil do you prefer? #5409362 04/21/20 09:22 AM
Y
yagciogullari Offline OP
Y
here motul is quite popular amongst dexos certified motoroils (so much so that counterfeits started circulating)
also got into the bandwagon and currently using it. i mostly drive my car long distance smile no complaints so far. it was good price for a 5 litre container.
another popular brand is liqui moly...which is on the pricier side. nobody likes the GM branded oil that the dealer puts in from the barrel. that's for sure.
on the forums here people suggested that castrol edge ACEA C3 is a superior PAO based oil so i'll try to try that in my next oil change.
2017 Opel Astra K 1.6 CDTI (diesel) - Motul 8100 X-Clean EFE 5W-30
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409388 04/21/20 09:55 AM
sohccammer427 Offline
I'm guessing you're asking about Dexos 2 which is normally C3 used in GM euro diesels? That's what I have to run in my Chevy Colorado. I always use a 5w40 and not a 5w30. I have some Castrol Edge Turbo Diesel I bought at NAPA queued up for my next oil change.
It's interesting that I have 1l bottles and not quarts which would be normal here in the USA. Perhaps this does have some PAO as it cost close to $10/qt here which is pretty expensive. Fortunately I had a coupon. I'll have to check and see where it was manufactured. Anyhow, use with confidence. It's good stuff.
[Linked Image]
2015 VW Passat TDi 6 Speed Manual
2017 Colorado Duramax
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409389 04/21/20 09:56 AM
R
ragtoplvr Offline
R
I d=so not think a significant difference in Dexos certified oils exists. I use which ever is cheaper.
Rod
Re: Dexos users, which oil do you prefer? [Re: sohccammer427] #5409396 04/21/20 10:07 AM
Y
Y
i dont know that much about dexos. my diesel car uses dexos2™ smile it might be different for gasoline engines. that's why i put just 'dexos' on this thread.
add to the confusion the dexos site lists these 3:
[Linked Image from i.imgur.com]
never heard of dexosD, here.
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409441 04/21/20 11:24 AM
N
NuttCase Offline
N
I've just finished a 20L tub of Shell Helix Ultra 5W30 AG - Dexos2 & C3. I did not require the dexos approval - the C3 spec, previous good experience with Shell oils and the price were the main drivers - 20L for £43 (£2.15 a litre). I've used it in three non-GM cars which were out of warranty and intend to send off some samples for a UOA in the next few days - oil changes done today at home. Out with the 5W30 and in with 0W30 Shell Helix Ultra ECT C3 which was even cheaper!
With any C3 spec oil that has a solid manufacturer approval such as Dexos2, MB229.51, VW504/507 I doubt you can go too far wrong if you keep to reasonable oil change intervals.
'15 Merc C300 diesel hybrid, Shell Helix Ultra 0W30 ECT C3
'13 Ford Fiesta 1.25, Shell Helix Ultra 5W30AG
'17 Audi R8 V10, Motul 8100 X-Clean+ 5W30
'19 Mini JCW, Shell Helix Ultra 0W30 ECT C3
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409450 04/21/20 11:31 AM
53' Stude Offline
Since we don't know if OP means DEXOS 1 GEN2 or DEXOS 2; I prefer to use either M1 0w30 of PP 5w30
2009 Toyota Camry LE
Re: Dexos users, which oil do you prefer? [Re: 53' Stude] #5409494 04/21/20 12:51 PM
K
Kamele0N Offline
K
OP has 1.6 turbo diesel (CDTi) in his Sig.... So dexos2...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409498 04/21/20 12:59 PM
53' Stude Offline
Kameleon: he posted DEXOS users, which oil do you prefer. It has nothing to do with signatures also so doesn’t matter. Thanks anyways
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409519 04/21/20 01:41 PM
SubieRubyRoo Offline
I got four 5L jugs of the X-Clean+ 5W30 for $45 shipped, total for all four, from a glitch on Amazon I think. A gift card I had brought the actual expenditure down to $13 for 20 liters. I'm likely going to use it off-label for a winter oil, or donate it for F&F OCs.
De omnibus dubitandum.
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409555 04/21/20 02:19 PM
B
bullwinkle Offline
B
I would be interested to hear the differences between Dexos 2 & Dexos D, since Dexos 2 seems to be the light duty diesel oil, maybe Dexos D is the heavy duty one (Duramax use)?
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Dexos users, which oil do you prefer? [Re: yagciogullari] #5409615 04/21/20 03:31 PM
N
NuttCase Offline
N
Some discussion on one of the few approved Dexos D oils below. Only 0W20
AC Delco DexosD oil
