Which oil is the better quality
by galaxy333 - 06/01/20 09:57 AM
"Boutique" Brands
by buster - 06/01/20 09:15 AM
CASTROL Edge 5w20 or EP 5w20
by 53' Stude - 06/01/20 09:09 AM
BT Oil
by js1956 - 06/01/20 09:00 AM
How to Properly Read a Dipstick
by Gebo - 06/01/20 07:59 AM
Why did some older cars have + grounded systems?
by JLawrence08648 - 06/01/20 07:39 AM
Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
C6H8O7, Jcvjr, Haywood, ToOliwer, AbbeyRoad
71588 Registered Users
105 registered members (1978elcamino, 97prizm, 00celicagt, 830Lee, 87sammy, 14Accent, 10 invisible), 2,157 guests, and 19 spiders.
Topics306,118
Posts5,286,830
Members71,588
which wheel brearing grease RWD Ford F350 #5408848 04/20/20 05:03 PM
G
GON Offline OP
G
I need to replace the front bearings in my RWD 2006 Ford F-350. I purchased timken bearing grease. Reading another thread in this forum0 it suggested Mobil SHC Polyrex 462 white grease.
I now have both greases- but am a bit concerned as I have never used white grease on a bearing, etc.
I do live in the mountains, haul a 7,000 lb trailer, and usually drive extended distance through major interstate mountain passes.
Any thoughts?
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5408854 04/20/20 05:11 PM
4
46Harry Offline
4
If I remember correctly, Ford has recommended a grease with a small percentage of Moly added for many years. Whether a grease containing Moly is necessary or even critical has been a subject of debate for a while. My preference would be the Timken grease if it were my truck.
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5408902 04/20/20 06:06 PM
doitmyself Offline
Your Mobil grease is a food safe polyurea grease that doesn't show any extreme pressure data nor any mention of recommended use for wheel bearings/chassis, i.e., GC-LB
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5408932 04/20/20 06:44 PM
Chris142 Offline
Valvoline Moly wheel bearing grease for Ford vehicles is what you want.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: which wheel brearing grease RWD Ford F350 [Re: Chris142] #5409034 04/20/20 08:41 PM
G
GON Offline OP
G
Chris,
Is this what you are recommending?
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5409039 04/20/20 08:50 PM
G
GON Offline OP
G
Chris,
Or this?
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5409226 04/21/20 05:41 AM
B
bullwinkle Online Confused
Online Confused
B
I've used lots of the blue tub red Valvoline myself on both Ford & Dodge, but the Full Synthetic (formerly Synpower) would probably be even better.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5409308 04/21/20 08:06 AM
4
46Harry Offline
4
The red Valvoline grease is what I've used for years on wheel bearings for years. I have used the Valvoline synthetic grease with good results, but it is more expensive. If there is still a warranty on the truck, I would use the Valvoline grease recommended for Ford product wheel bearings.
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5411796 04/24/20 07:14 AM
G
GON Offline OP
G
Thanks for the replies. Ended up purchasing synthetic Valvoline with Moly.
The only reason I was looking at the Mobil product was a misreading of a another thread on BITOG- my error.
I did write Mobil (since I already purchased four tubes of Mobil SHC Polyrex 462 white grease.
This was their response:
We do not recommend Mobil SHC Polyrex 462 for automotive wheel bearings. This product is a food grade, high temperature grease intended for industrial machinery. We have not tested its performance in wheel bearing applications and its base oil viscosity (ISO VG 460) exceeds the typical viscosity range you’d expect in this application.
We tend to recommend NLGI GC-LB rated greases for automotive wheel bearings. GC-LB is a performance classification that many manufacturers in North America specify for wheel bearings/chassis. The spec provides a general assessment of a grease’s overall performance in wheel bearing and chassis applications. It tests many key properties relevant to this application including rust protection, water washout, oil separation, EP/AW properties, low temperature torque, high temperature bearing life, fretting protection…
If you’re looking for our best synthetic GC-LB rated grease for automotive wheel bearings, I’d recommend Mobil 1 Synthetic Grease.
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5413347 04/26/20 06:05 AM
G
GON Offline OP
G
Changed out the F350 RWD front wheel bearings yesterday. Used the Valvoline fully synthetic grease with moly.
The Ford had its original bearings and grease. The grease was pretty clean and was green in color.
The Valvoline full synthetic moly is charcoal black in color. It has a very different texture than any other grease for bearings I have worked with, including the FORD OEM grease.
Re: which wheel brearing grease RWD Ford F350 [Re: GON] #5427792 05/12/20 11:33 PM
Chris142 Offline
Chris,
The blue one. I run it in my stuff.
