2017 Toyota Sienna AWD
by 92saturnsl2 - 06/06/20 09:33 AM
Wix 57045
by electricmarquis - 06/06/20 08:42 AM
VW GTI
by greenjp - 06/06/20 08:25 AM
Mower Engine Got Drenched With Oil
by viscous - 06/06/20 08:19 AM
Mobil 1 versus Motul for a 2020 Camry 0w16
by Amkeer - 06/06/20 05:52 AM
Slowest lap ever...but legal...
by Shannow - 06/06/20 05:15 AM
Another SCORE !!!
by GMguy84 - 06/06/20 02:24 AM
Is it just me...
by daves87rs - 06/06/20 01:26 AM
Total Repair Costs over 200,000 miles
by Palut - 06/06/20 12:08 AM
Vredestein will start making American-market specific tires
by slacktide_bitog - 06/05/20 11:33 PM
Fried plantain question
by aquariuscsm - 06/05/20 11:08 PM
Castrol Edge LL IV 0w20, not majority PAO
by wemay - 06/05/20 09:08 PM
Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day 🇺🇸
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
viscous, Roamingtxn, 3Dperf, LouK2, Michael328i
71618 Registered Users
94 registered members (2015_PSD, 4WD, 92saturnsl2, 830Lee, 94astro, 97prizm, 5 invisible), 2,120 guests, and 94 spiders.
Topics306,283
Posts5,289,596
Members71,618
Chain Tensioners / Guides Choice Help #5408785 04/20/20 03:54 PM
Y
Y_K Offline OP
Y
Hi,
I need to order a chain replacement kit for a Panther in my extended family fleet, that is Ford modular v8 of 2004 vintage. Chain guide start to rattle at 280k miles in her Towncar. Looking at the Melling chain kit with cast iron guides (3387SG) vs Melling kit with the polymer primary guides (3387SIF). The job is going to be performed by a professional mechanic. I am clueless in this.
Which one would you chose?
Thank you in advance.
“This disease making us more cruel to one another than if we are doggs.” -- Samuel Pepys 1666
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5408806 04/20/20 04:16 PM
Donald Offline
What does your mechanic say? What about OEM? If you tell mechanic what to use and something goes wrong he may not want to hear it.
If you got 280K out of the original then why not go OEM?
2015 Ford F-250 w/Powerstroke
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5408811 04/20/20 04:21 PM
Chris142 Offline
I would check with the guys on the Forum that are familiar with those engines. My personnel choice would be metal/
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Chain Tensioners / Guides Choice Help [Re: Donald] #5408818 04/20/20 04:26 PM
Y
Y_K Offline OP
Y
Mechanic is irrelevant in this case. But thank you for pointing out to this variable. The car can go for another 600k miles or it can go to a junk yard.
It is of a personal sentimental value, but nobody will accuse the mechanic if anything goes 'wrong'.
As my wife puts it: "My calculations were correct, just not in my favour".
It is still easy and cheap to take care of panthers. I had a nearly new rear end, whole nine yards, delivered and swapped for less than $500. The only thing I regret is not taking advantage of new crate engines when they were on every web page for nearly nothing. Now they are gone. The cheap ones that is.
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5408826 04/20/20 04:36 PM
K
KGMtech Offline
K
I'd go with Motorcraft, not that Melling is bad, it's just not an area that warrants trying to save $50 - $100 overall.
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Chain Tensioners / Guides Choice Help [Re: KGMtech] #5408845 04/20/20 05:01 PM
Y
Y_K Offline OP
Y
Thank you very much
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5408859 04/20/20 05:17 PM
slacktide_bitog Online Content
Online Content
My choice would be the Melling kit with the metal. My instinct is to opt for metal when both metal and plastic are available for the same application.
And if it fails for some reason, you can always swap in a Mustang engine drive
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5408921 04/20/20 06:32 PM
1
14Accent Offline
1
I think you're mistaken, the guides are the same in both kits. The TENSIONERS are different. You definitely want the metal bodied tensioners.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
1980 Honda CB900C - 15k mile cream puff
Re: Chain Tensioners / Guides Choice Help [Re: 14Accent] #5408969 04/20/20 07:10 PM
Y
Y_K Offline OP
Y
I *am* clueless. Thank you
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5409030 04/20/20 08:35 PM
1
14Accent Offline
1
No problem! I'm glad I noticed, I was curious myself when you said guides. I've replaced several of the plastic units with metal, they're much much better quality.
Re: Chain Tensioners / Guides Choice Help [Re: Y_K] #5409064 04/20/20 09:21 PM
clinebarger Offline
The only knock against the plastic body tensioners is the body seal will eventually blow out, And I would be surprised if that happened to a updated one in under 200,000 miles. I've rarely seen the plastic tensioners even with blown seal cause much issue on a 2V Modular. Guide wear & Breakage is most common.
The 3V Modulars are a whole other can of worms & people like the blame the Tensioner seals, But VCT system & Oil Pump Leakage is the main culprit.
2001 Chevy Camaro L92/4L80E
