Pentosin Mania
by Snagglefoot - 07/01/20 11:30 PM
Spills. Synthetic vs petrolium
by Chris142 - 07/01/20 10:35 PM
Michelin Pilot Sport All-Season 4
by FordFocus - 07/01/20 10:04 PM
NGK Ruthenium Spark Plugs
by Deontologist - 07/01/20 07:49 PM
Ram Truck Speaker Upgrade Questions
by edhackett - 07/01/20 07:41 PM
OLM SCREWED UP
by demarpaint - 07/01/20 06:12 PM
Have Valvoline European 5w-40. Use in Cummins?
by RetiredGuyOR - 07/01/20 06:06 PM
Change in evaporation rate over time?
by mosschops - 07/01/20 05:56 PM
17 Golf overzealous OLM/Minder
by lawrencerd - 07/01/20 04:24 PM
First cell phone
by Chris142 - 07/01/20 04:08 PM
Motorcraft FL836 Specifications
by viscous - 07/01/20 03:41 PM
Chipmunks - Damit.
by PontiacHO - 07/01/20 03:37 PM
27/18k portable genset oil.
by 1978elcamino - 07/01/20 03:31 PM
Saw a new BMW and had to do a double take.
by wemay - 07/01/20 02:55 PM
Seems like there is less activity on BITOG
by SLO_Town - 07/01/20 02:21 PM
Rock Auto horrible customer service
by cknight49090 - 07/01/20 02:09 PM
Mobil 1 rebate hassle
by cknight49090 - 07/01/20 02:00 PM
Ac rebates horrible to deal with
by cknight49090 - 07/01/20 01:58 PM
RetiredGuyOR, BretBouer, JKMark, Tugcan, George_Robert
71821 Registered Users
30 registered members (carlprop, bulwnkl, 2009Caraman, boulderdentist, BlakeB, bbhero, 2 invisible), 938 guests, and 32 spiders.
Topics307,387
Posts5,309,598
Members71,821
Three high-ZDDP 40-weights #5253264 10/29/19 04:05 PM
4
440Magnum Offline OP
4
Note: I will post each of these in its own thread with the oil type and date in the title so that it will be easier to find with the site's search engine... but I also wanted to post all three in a single thread for comparison's sake. The oils are: Rotella T6 CK-4 5w40, Redline 0w40, Royal Purple HPS 10w40.
This is something I really did for other forums more than BITOG, because the current misinformation out in flat-tappet land is "Rotella changed! Its no good anymore! Its not for gasoline engines! They lowered the Zink " <- yes, that's how most of these goobers spell it). Now I have a VOA to prove that the ZDDP dose didn't change when they dropped the PCMO SN approval and went to only Diesel CK-4 approval.
The other two are a couple of common alternatives that I had on hand- Royal Purple HPS 10w40, and Redline 0w40 (which I use in my SRT-8, not my vintage cars, though now that I see the results I certainly could use it!). Royal Purple shows a low flashpoint, which to my way of thinking agrees with its habitually mediocre NOACK results. I've used it in my 1960's flat-tappet 440 Magnum v8s with good UOA numbers, but it does increase the consumption a bit. Given everything in these three VOAs, I really doubt I'll spend money on purple bottles anymore... at least until/if they really DO revise Rotella T6 and cut down the ZDDP.
'66 Dodge Polara & '69 Dodge Coronet R/T both 440/727
'08 Ram 1500 4.7/545RFE
'12 Challenger SRT8 392/6-speed
'99 XJ 4x4 4.0/AX15, '14 WK2 4x4 3.6/8HP
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5253375 10/29/19 06:04 PM
J
JAG Offline
J
Thank you!
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5253376 10/29/19 06:06 PM
SOHCman Offline
nice!
I urge people not to wait 100K to change out the fluid in their transfer case units. -Kestas
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5253481 10/29/19 07:36 PM
W
wings&wheels Offline
W
thanks
'05 Lotus Elise S/C
'85 Land Rover 90 diesel
'74 Triumph TR6
'74 BMW 2002
'72 Land Rover Series III 88"
'99 Porsche 996
'01 Porsche Boxster S (mostly Wife's...)
'19 VW Golf R (Wife's)
Piper Pa28-236
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5263706 11/10/19 10:59 PM
B
Bonz Offline
B
Good info, thanks! All very good higher zinc oils.
Where does Blackstone get different "should be" values for these oils when they all are 40 weight on the top end? Doesn't make a freakin' bit of sense and they've tried to explain it away to me when I have had UOA's of synthetic 10w40 with my motorcycle.
They said because my sample oil starts as a lower 40 weight as per the manufacturer specs, the "should be" values shift. In this case it was Mobil 1 10w40 4T. Even though it sheared out of grade a small amount by industry specs, they said it remained in grade relative to the amount it dropped from where it had started.
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5408669 04/20/20 12:56 PM
W
whizbyu Offline
W
Is it still foolish ( I've been told years ago not to ) mix 2 oil brands to get the best of both additive packages?
Re: Three high-ZDDP 40-weights [Re: 440Magnum] #5408671 04/20/20 12:57 PM
W
whizbyu Offline
W
Or 3, or 4 brands
