Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
47 registered members (BigGeo, bdcardinal, blufeb95, Ag76, 10WSmuckers, 5 invisible), 1,270 guests, and 69 spiders.
Topics306,113
Posts5,287,778
Members71,602
ATF Fluid Question, LEGIT #5408550 04/20/20 10:12 AM
G
Gebo Offline OP
G
I was thinking. I know, I know, that shocks some of you. coffee
I don't know if this has been discussed in this forum before and I don't feel like doing a search. Too complicated for me with the date thing.
Anyways, why are some ATF fluids that come in our vehicles synthetic and some are not? Some of the new Fords are using non-synthetic
ATF's. Is is simply a situation where the manufacturers are trying to hold costs down? (I have read where some mechanics recommend
conventional gear oil for diffs)
Most people hold Toyotas in high regard for their quality but neither of their ATF's (T-IV or WS) are synthetic. I guess I don't understand and maybe
never will.
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408585 04/20/20 10:56 AM
N
nascarnation Offline
N
It's really a time/temperature relationship to determine the "life" of the trans fluid.
You could run the old Dex III forever at 200F but it died pretty quick at 275.
So as a transmission guy you are always wrestling with the cooling system folks.
We went with a premium synthetic product at Allison so we could feel confident about the fluid life even if the operating conditions were consistently rigorous and be confident giving the customer a lengthy warranty.
It's overkill for grandpa tooling down the interstate in his diesel pusher, but just right for NYC refuse or Houston transit in the summer.
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408590 04/20/20 11:00 AM
G
Gebo Offline OP
G
Great explanation! Thanks!
Why do you think Toyota only sells conventional ATF's? Just a money issue?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408599 04/20/20 11:14 AM
dogememe Offline
Very very few Toyota vehicles are used for severe service.
2010 Ford Escape 2.5 ~104K Miles: AMSOIL Signature Series 0W-30, Wix Filter.
2001 Chevy Suburban 5.3 ~292K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: ATF Fluid Question, LEGIT [Re: dogememe] #5408607 04/20/20 11:28 AM
Chris142 Online Content
Online Content
What about the ones in south america,Africa etc?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408629 04/20/20 11:59 AM
Astro14 Offline
What is wrong with conventional fluid?
Serious question.
If 99% (or more) vehicles serve out their lives with conventional fluid, then conventional is fine. It works. Synthetic fluid has zero advantage in those applications.
Why should a manufacturer use a more expensive formulation when it’s not needed and the average consumer (not BITOG member) doesn’t care?
IF a manufacturer uses a synthetic, perhaps they have a reason to. Perhaps, in that application (performance, heat, towing, whatever) they have determined that it is worth the extra cost.
But not every car, not every vehicle, needs a synthetic fluid. Legit. Serious. Regular fluid works great.
Personal examples from cars I’ve owned*.
1. 1977 Oldsmobile, 200,000 miles on the original transmission, using DEXRON conventional, fluid. Nothing else was made back then. It was my first car and saw a lot of very hard driving. I was a kid.
2. 1990 Toyota 4 Runner. Lots of 4 Wheeling and rough use. Still on the road, 300,000 miles on conventional (DEX I, then II, then III, then Toyota Type-IV).
3. 2002 Volvo T5 Wagon, still being driven by my daughter, 200,000 miles on JWS-3309 fluid.
4. 2002 Volvo XC, still on the road, 265,000 miles using, wait for it, wait for it, conventional JWS-3309 fluid.
If I can get over 200,000 miles from a transmission that used nothing but conventional fluid, why do you want to spend more on synthetic?
Here is your logic applied to a different aspect of automotive manufacture: Why doesn’t every car come with Z rated tires? Why are some companies using only H rated tires? Is it just for cost savings?
Same legit answer; not every consumer, not every vehicle, needs the performance that Z rated tires offer. Most are just fine with H rated tires. They’ll never see the speed/heat that demands a Z rating.
If the base stock of a fluid matters to you, then feel free to change it out yourself. That’s what I did on my Tundra at 25,000 miles. The Toyota WS fluid was bright red and looked great by the way, despite using the truck to tow.
So, even though I am a little OCD about fluids, the conventional fluid was holding up just fine in that application.
Just because something sounds better, or costs more, doesn’t mean that it makes sense to use it.
*I’ve owned over 25 cars, and I have yet to blow up or replace a transmission. Done a few clutches along the way. I listed the cars that made it to 200,000 or more. I still own two of those listed. They’re still in daily use. Most of the others were sold, or totaled, before reaching that number but the point remains: every single one of them ran fine on conventional transmission fluid.
32 Packard 15W40
01 Volvo V70 T5 0W30 AMSOIL SS
02 Volvo V70 T5 0W30 Edge
02 Volvo V70 XC 0W40 Edge
05 MB S600 0W40 M1
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408646 04/20/20 12:23 PM
G
Gebo Offline OP
G
Excellent points, Astro14. Note, I’m merely asking a question and your answer makes a lot of sense.
Simply put, the way I understand you, is that generally speaking, synthetic ATF’s are not deemed necessary by certain manufacturers.
I still use Toyota branded Dexron lll in my 2002 4Runner crazy
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: ATF Fluid Question, LEGIT [Re: Chris142] #5408653 04/20/20 12:28 PM
P
Pelican Offline
P
Most of them are manual shift
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408684 04/20/20 01:12 PM
B
bmwtechguy Offline
B
There are synthetic labeled fluids made with low cost (minimum spec) additive packages made and sold out there. Then you have high quality mostly non synthetic fluids but with a very superior grade additive package that are better in nearly every category than a low grade "synthetic" fluid. And the non syn might outperform the low grade full syn in most categories. Best to change whatever fluid you decide to use at a reasonable interval before the fluid is in bad shape. If you want to go longer, then use higher grade full synthetic fluid along with increased filtration efficiency and cooling which will allow you to increase change intervals safely. I also recommend this for towing use. Just my 2 cents backed up with 40 years experience.
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408829 04/20/20 04:42 PM
B
Brybo86 Offline
B
It really doesn't matter if it is conventional or synthetic as long as you buy OEM branded fluids you are GOLDEN
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408853 04/20/20 05:09 PM
G
Gebo Offline OP
G
I already know that. USA
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408887 04/20/20 05:42 PM
sloinker Online Shocked
Online Shocked
I think that if there is concern over temperatures in a transmission it would be advisable to add a bottle of the appropriate Lube-Gard. Remember when there were no synthetic fluids for transmissions? How long did they last? It seems that back in the 1970 a GM Turbo 350/400, Torqueflite, C6 lasted about 100k miles. The Japanese transmissions were pretty rare in automatic form back then so I don't recall how long they were lasting. So it shows that the transmissions and fluids are both probably better nowadays.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: ATF Fluid Question, LEGIT [Re: Gebo] #5408973 04/20/20 07:21 PM
P
Paul_Siu Offline
P
I am no industry expert, so I can only speculated based on educated guess. It cost money to retool to use a different type of fluid, so different type of fluid is based on what each manufacturer is used to. I imagine they won't change unless there is a reason to. For example, new technology require formulation of fluid or if there is a cheaper way to make fluid.
Companies may also merge or share technology, resulting in perhaps changes. Different fluid occur because companies have different branches of development, which result in different types of fluid that does the same thing. There are more than 1 way to skin a cat after all.
Paul
