Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
103 registered members (53' Stude, 2oldtommy, 4WD, 830Lee, 77GrandPrix, 1911CHAMPION, 10 invisible), 2,053 guests, and 55 spiders.
Topics306,103
Posts5,287,477
Members71,601
Page 1 of 4 1 2 3 4
Clogged Kitchen Drain #5408536 04/20/20 09:55 AM
M
maverickfhs Offline OP
M
So have a very slow flowing(almost clogged) kitchen drain. After removal, thoroughly cleaned up P-trap and all other pipes underneath the sink.
Couldn't clean the small pipe going into the wall because for some reason whoever installed them, thought that pipe would never be removed in future.
Ideally don't want to use any chemicals, have already used boiling water multiple time, baking soda/vinegar and no luck.
What have you successfully used in the past? Snake? Or any other help/tips would be appreciated. thumbsup
2006 Civic EX 209K/AT
2006 Acura TSX 199K/AT
2007 Accord VP 154K/AT
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408559 04/20/20 10:17 AM
G
Gebo Offline
G
Maybe squirt some Dawn down in there and let it sit?
Did you plunge it?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408569 04/20/20 10:25 AM
bdcardinal Online Content
Online Content
When that happened to me it was the drain line out to the street that had tree roots growing into it. Plumber came out with the snake to clear it out.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Clogged Kitchen Drain [Re: Gebo] #5408571 04/20/20 10:27 AM
G
georgemiller Offline
G
[Linked Image]
Re: Clogged Kitchen Drain [Re: Gebo] #5408574 04/20/20 10:36 AM
M
M
Did you plunge it?
Can you please elaborate? Just use plunger on each side of the sink?
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408576 04/20/20 10:41 AM
W
wog Offline
W
Cover one side and plunge otherside, this will clear to the trap. Down stream use a liquid drain cleaner,or a snake. Snake is better longterm! There should be a cleanout on the line. If not you will have to go through plug at bottom of trap.
Re: Clogged Kitchen Drain [Re: wog] #5408579 04/20/20 10:49 AM
G
Gebo Offline
G
What he said. I feel your pain...
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Amsoil OE 10w-30
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408584 04/20/20 10:55 AM
dadto2 Offline
Try a plumbing bladder. Stick it in the pipe in the wall, now that you have the trap removed. This worked for me when my wife put potato peels down the disposal.
HF Draining cleaning bladder
'16 GMC Sierra 1500 Crew Cab 4.3
'15 Volvo S60 T5 AWD
'99 Volvo S70 2.4
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408587 04/20/20 10:57 AM
O
opus1 Online Content
Online Content
O
Just went through this with a basement bathroom sink. Multiple rounds with chemicals, the last few were almost successful as the drain would seem to clear and then whatever was blocking it would shift, the drain would emit a sort of burp, and that was the end of that.
You're going to have to bite the bullet and snake it.
Current Fleet:
2010 Hyundai Sonata GLS
2009 Chevy Cobalt SS Sedan (yes,the turbo)
2002 Dodge Dakota SXT Club Cab
1994 Ford Ranger XLT (RIP, Dad)
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408593 04/20/20 11:03 AM
BlueOvalFitter Offline
Look outside at the wall opposite of your sink and there should be a wall clean out. Go to any hardware store and buy a BLOW BAG. You can run it down the wall clean out. If there's not a clean out there, there is a vent stack protruding from the roof. Run your BLOW BAG down that pipe. This should unclog your drain pipe.
If that don't work, call a plumber.
https://www.acbyj.com/blog/unclog-drain-with-blow-bag
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408595 04/20/20 11:08 AM
A
Aredeeem Offline
A
Agree. Snake time. Curious, are other plumbing fixtures in the house mis-behaving or is it just the kitchen? Could be cooking grease dumped down the drain over a long period of time.
Re: Clogged Kitchen Drain [Re: Aredeeem] #5408600 04/20/20 11:14 AM
M
M
It's just the kitchen drain, everything else is functional and working - knocking on wood!
Re: Clogged Kitchen Drain [Re: wog] #5408601 04/20/20 11:18 AM
M
M
I have already cleaned out the pipe until the trap after removing it.
Re: Clogged Kitchen Drain [Re: maverickfhs] #5408602 04/20/20 11:18 AM
Donald Offline
I think a plumber would use sulfuric acid. Works like a charm. A one time use will not cause septic problems.
2015 Ford F-250 w/Powerstroke
Re: Clogged Kitchen Drain [Re: BlueOvalFitter] #5408610 04/20/20 11:30 AM
M
M
Are you talking about the highlighted area/lug right next to the pipe going inside the wall?
[Linked Image]
Page 1 of 4 1 2 3 4
