Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
90 registered members (ABN_CBT_ENGR, 4WD, AlienBug, 53' Stude, 94astro, amblerman, 8 invisible), 2,493 guests, and 51 spiders.
Topics306,017
Posts5,284,913
Members71,558
Does MMO burn off in the crankcase? #5408256 04/19/20 10:15 PM
2
2009Caraman Offline OP
2
I put about 500ml of MMO in my 5qt engine. Runs fine.
Before filling I replaced my oil pan gasket. I've since lost about 1/2 litre according to the dipstick. 800 kms driven. No oil below. This van has never burned oil either.
I'm thinking it's the Marvel Mystery Oil burning off. I thought I read that can be expected but can't find any confirmation.
Re: Does MMO burn off in the crankcase? [Re: 2009Caraman] #5408259 04/19/20 10:19 PM
B
blufeb95 Offline
B
It's mostly a bunch of solvents, so yes it will evaporate out of the oil like fuel does will when the oil is up to temp.
Re: Does MMO burn off in the crankcase? [Re: blufeb95] #5408267 04/19/20 10:39 PM
2
2
that's great. TY.
Re: Does MMO burn off in the crankcase? [Re: 2009Caraman] #5408766 04/20/20 03:00 PM
K
KCJeep Online Content
Online Content
K
Yes exactly. The solvents can burn off, which is why putting MMO in the crank for a little cleaning near the end of an OCI can still be effective. It does most of it's cleaning early after it's added. Nothing wrong with putting it in when you change the oil either, however it is wise to account for the thinning it will create.
2018 VW Passat GT VR6 - 28k - Castrol Pro OE 5w40 - VW OEM filter
2012 KIA Sedona 107k - Valvoline Maxlife 5w30
2012 VW Tiguan 108k - Castrol 0w40
2004 Jeep Grand Cherokee, gone but not forgotten.
Re: Does MMO burn off in the crankcase? [Re: 2009Caraman] #5410020 04/22/20 05:30 AM
L
Lubener Offline
L
It's not going to burn off, it's not moisture, just dillutes the oil. Beginings of oil usage is one reason I do not add cleaning solvents to my oil. A buddy of mine seized up his engine when he added kerosene to his oil. It cleaned too good, loosened up some sludge which plugged an oil gallery feeding the bearings.
The "thinking" man's friend.
Re: Does MMO burn off in the crankcase? [Re: Lubener] #5410227 04/22/20 10:44 AM
B
blufeb95 Offline
B
It's mostly napthenic solvent and mineral spirits which are pretty volatile and when the oil is up to temp should readily evaporate into the crankcase and get sucked up into the intake through the PCV and burned off
Re: Does MMO burn off in the crankcase? [Re: blufeb95] #5411227 04/23/20 01:00 PM
Drew99GT Offline
Hmmm, wonder if that could possibly clean the intake valves on GDI engines???
Re: Does MMO burn off in the crankcase? [Re: Drew99GT] #5412368 04/24/20 10:10 PM
B
blufeb95 Offline
B
I Doubt it, probably not much different than the normal amount of fuel that travels through the PCV from blow by and fuel contamination.
Re: Does MMO burn off in the crankcase? [Re: Lubener] #5412776 04/25/20 11:55 AM
ABN_CBT_ENGR Online Content
Online Content
Not a Chemical Engineer or Chemist but this is what my own experience has shown and OA reflects. Once its blended its bonded and there for the duration.
Re: Does MMO burn off in the crankcase? [Re: blufeb95] #5413640 04/26/20 12:14 PM
Surestick Offline
They used to make "top end oilers" that would deliver a small amount of oil into the intake to act as a UCL.
I've been wondering if that sort of system wouldn't work with the right fluid (Seafoam, MMO, etc.) To keep the intake and valves clean on engines that suffer from this problem (VW TDI, most GDI engines).
Re: Does MMO burn off in the crankcase? [Re: ABN_CBT_ENGR] #5427033 05/12/20 07:00 AM
T
talest Offline
T
My experience backs this up that it would likely NOT evaporate out. I have put like 40% MMO in engines (cleaning was needed) and after about 1000 miles most of it was still there.
On extremely dirty engines, monitor oil level, yes... but MMO is not the strongest.
Would Seafoam evaporate...
