Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
102 registered members (A_Harman, 2015_PSD, bbhero, Astro14, 2010Civic, Alfred_B, 8 invisible), 2,152 guests, and 20 spiders.
Topics306,108
Posts5,286,580
Members71,586
JD will not start #5408004 04/19/20 04:56 PM
M
matrass Offline OP
M
Hello and good day fellow Bitogers.
Went to start my JD riding mower after the winter season and it will not start.
Before I put it away for the end of the season I ran Amsoil small engine treatment rhough it and ran it until it was out of gas, it just shut off.
Took the battery out and stored it in my basement whice stays at least 64-66 degree all winter .
So I put the battery on my charger to be sure it is good and soon after it reads 100%.
Filled the gas tank up today and put the battery back in and connected it.
Let is sit for 30 minutes then tried to start it .
I had this problem last year and thought I had it licked, ended up lettting it sit after making sure the tank was full of gas.
The fuel filter was just changed last Spring .
I am putting a charge back on the battery as it was wearing down from the starting attempts.
Any ideas why this is happening , should I leave the battery in , leave a small amount of gas in the lines at the end of the season ?
Re: JD will not start [Re: matrass] #5408011 04/19/20 05:04 PM
ABN_CBT_ENGR Offline
You could paint it industrial yellow and put a CAT sticker on it
Re: JD will not start [Re: matrass] #5408019 04/19/20 05:12 PM
dave123 Offline
Did u pull a plug are they wet dry? Do you smell raw gas full choke?
Re: JD will not start [Re: matrass] #5408030 04/19/20 05:25 PM
L
Lou_Boyle Offline
L
Compression, spark, and a correct amount of gas and it will fire right off. Need to figure out which one is missing. You can hear the compression to a certain extent by the variation in the starter motor sounds. Remove the spark plug and check for a good hot spark, not just a feeble spider web spark. Note if the plug is dripping wet which can indicate no spark or a carb problem and flooding. If you have good spark and a dry plug try some starting fluid. These checks likely won't locate the problem but will tell you where to focus your investigation.
Re: JD will not start [Re: matrass] #5408037 04/19/20 05:46 PM
E
Eddie Offline
E
I'd give it a shot of ether in the carb. Ed
2014 CX5 Touring 2.5L :-)
Re: JD will not start [Re: matrass] #5408038 04/19/20 05:49 PM
spasm3 Online Happy
Online Happy
Since it has not been sitting that long, i'd check for spark, and if you have spark, look for the float to be stuck. I have seen float stick on lots of stored equipment. If you can take the fuel bowl off with out removing the carb, and wiggle it up and down, and see if gas moves through it,
On push mowers, i have told friends to lift the back end about 4 inches and drop it. A lot times that works.
I run tcw3 ( 640:1 , 1 0z in 5 gallons) along with stabil on my last tank of the season, and it seems to keep things clean and working.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: JD will not start [Re: Eddie] #5408053 04/19/20 05:59 PM
CourierDriver Offline
best answer yet,,,always worked on my JD,,,20 yr old now
I'd still like to have my 67 Beetle back....life was easy then..imho 2 quarts of oil roughly ,lol
No matter what time it is,its always time for a nap
Re: JD will not start [Re: matrass] #5408066 04/19/20 06:15 PM
Chris Meutsch Offline
Ether and it will fire right up.
2016 Toyota 4Runner Trail Premium, 58k
*RIP* 2005 Honda CR-V EX, 284k
Re: JD will not start [Re: matrass] #5408069 04/19/20 06:20 PM
dinofish Online Content
Online Content
Did you run 'Amsoil small engine treatment' last year, too?
Re: JD will not start [Re: matrass] #5408078 04/19/20 06:27 PM
B
Brybo86 Offline
B
I would check the spark plug to make sure it isn't covered in the fogging oil.
Shot of ether in the plug hole
And
one in the intake for good measure.
Guaranteed startup.
12 Honda Odyssey 112k
09 Kymco Super8
08 Honda Accord 2.4L 164k
01 Kymco People 50
95 Yamaha Jog
Re: JD will not start [Re: matrass] #5408090 04/19/20 06:42 PM
ctechbob Online Content
Online Content
Does it have one of the carbs with the electric shutoff? Those can freeze closed and not let any fuel through.
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: JD will not start [Re: matrass] #5408133 04/19/20 07:29 PM
dlundblad Offline
I would also give it some starter fluid.
Mow with it right away and/ or run it for a considerable time too.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: JD will not start [Re: matrass] #5408162 04/19/20 07:48 PM
M
matrass Offline OP
M
Thanks for the suggestions everybody.
I feel that a shot of starting fluid would get it going but it appears I do not have any on hand .
Will stop after work tomorrow and pick some up .
Guess the idea with the JD mower is to not run it out of gas like other equipment.
There is a hose on the outlet side of the fuel pump that goes right into the carb , can give it a little spray there and see what happens .
Wish there was a way to drain the gas out of the carb at the end of the season and I would just run it low in the tank after using some kind of stabilizer.
Ran the same Amsoil additive the last couple of years and there have been no problems with it .
Re: JD will not start [Re: matrass] #5408199 04/19/20 08:23 PM
J
jhellwig Offline
J
Carb cleaner also works as starting fluid on small engines. Could just be that the pump lost prime and needs a shot of gas down the carb to get it spun up fast enough to go.
Sparks fly from my fingers.
1995 Chevy K2500 Suburban lt 5.7
2014 Toyota Sienna
1983 Chevy K5 350
Re: JD will not start [Re: matrass] #5408218 04/19/20 08:41 PM
J
jeepman3071 Offline
J
Running it out of fuel shouldn't hurt it at all, I do this with a lot of pieces of equipment I have that are used sparingly. If it's been cranking enough to wear down the battery, you likely have enough fuel and flooded it. Starting fluid won't help if you have a fuel related issue. It's either getting fuel or it isn't.
Pull the spark plug. Does it smell like fuel, is it wet with fuel?
My bet is on a spark issue:
-The plugs could be soaked with fogging oil
-There could be a safety switch not working 100% not allowing you to get spark
-Mice could've chewed some wires.
I'd be buying an inline spark tester (they are a couple bucks) instead of starting fluid and go from there.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
