Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
81 registered members (830Lee, 97prizm, ABN_CBT_ENGR, 4WD, 55hambone, 555, 5 invisible), 2,068 guests, and 32 spiders.
Topics306,053
Posts5,286,514
Members71,593
Fuel grade question #5407930 04/19/20 03:44 PM
A
aztec12 Offline OP
A
Anyone knows if a 2012 nissan maxima has to run on premium gas?
Re: Fuel grade question [Re: aztec12] #5407948 04/19/20 03:53 PM
U
UG_Passat Offline
U
If you searched for an owner's manual online,
https://owners.nissanusa.com/conten...Maxima/2012/2012-Maxima-owner-manual.pdf
And... the answer is yes.
2016 VW Tiguan|APR Stage 1|Neuspeed P-Flo|Osram CBI|Redline 5w30
Re: Fuel grade question [Re: aztec12] #5408036 04/19/20 05:45 PM
E
Eddie Online Sleepy
Online Sleepy
E
I just read the manual above and 91 octane is RECOMMENDED. That means to me you can probably use 87 or 89 if not towing or mountains driving. JMG. Ed
2014 CX5 Touring 2.5L :-)
Re: Fuel grade question [Re: aztec12] #5408117 04/19/20 07:14 PM
Skippy722 Offline
91 minimum recommended, 87 absolute minimum.
2019 Ram 1500 Classic
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Fuel grade question [Re: aztec12] #5408239 04/19/20 09:30 PM
B
blufeb95 Offline
B
Nissan VQ engines are pretty high compression between 10:1 and 11:1 depending on the specific variation, I've read many people complaining about VQs knocking on 87 or that they could tell that the engine was retarding timing when using 87. VQ engines are pretty much designed for premium, using 87 in them will most likely result in knocking and the ECU pulling back to prevent knocking, pretty much all VQ equipped cars before 2002 said premium required, some alleged that in 2002 they started saying you could use regular to make their offering more attractive because competing manufacturers were starting to offer fairly equal V6 powered cars that didn't need premium and while the NIssan's can technically run on 87 they are really made for premium and you should really use premium.
Re: Fuel grade question [Re: Skippy722] #5408369 04/20/20 05:51 AM
Char Baby Offline
The way that I understand it is...
If the owner's manual states that 91 octane fuel(gasoline) is RECOMMENDED then, other grades of fuel can be used(but, no lower than 87). Even though we know that lower octane gasoline(85-86) is available in higher altitude areas.
However, If the owner's manual states the 91 octane fuel or high is REQUIRED then, you must use that.
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Fuel grade question [Re: aztec12] #5408510 04/20/20 09:26 AM
Donald Online Content
Online Content
recommended vs required is the key to look for.
2015 Ford F-250 w/Powerstroke
Re: Fuel grade question [Re: aztec12] #5408597 04/20/20 11:13 AM
A
aquariuscsm Offline
A
You might get pinging. Stick with premium unleaded.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Fuel grade question [Re: aztec12] #5408756 04/20/20 02:47 PM
J
Jake_J Offline
J
You can safely use regular on a modern car that's designed to run on premium, the ECU will compensate by dialing back the timing which will drop the power a little. I talked to several VQ owners and some of them have never used premium. You won't get pinging, the engine's knock sensor will pick it up before you ever hear or feel it. This is not the case if you're talking about a 70's Mercedes designed to be run on premuim.
Re: Fuel grade question [Re: aztec12] #5416315 04/29/20 10:31 AM
T
tbm5690 Online Content
Online Content
T
Just use premium and forget about it...you'll be getting the bump in power and often premium fuels have better detergent packages as well.
2014 Acura MDX Tech SH-AWD
2014 Nissan Maxima SV Sport & Tech
2007 Honda Shadow Spirit VT1100C
Re: Fuel grade question [Re: aztec12] #5416525 04/29/20 02:43 PM
R
Redright9 Offline
R
Use premium.. The car will run and give you better longevity that way.. the price difference really isn't much if you do the math... a couple dollars? why worry about that when the car was designed to run best with that octane. Think of it like this.. I CAN live eating fast food, my doctor would recommend I don't.
