Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
How to rebuilt a starter
by LazyDog - 06/05/20 12:11 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
84 registered members (2004tdigls, 830Lee, Astro_Guy, 4WD, ammolab, 2whlgeezer, 15 invisible), 1,863 guests, and 82 spiders.
Topics306,264
Posts5,289,239
Members71,615
Home made MTF? #5407920 04/19/20 03:33 PM
M
mlab Offline OP
M
Hi,
I can't get my hands on the MTF I need right now. My transmission isn't shifting like it should (hard, notchy) and since I have to change my engine oil and do other maintenance, I thought I'd flush the old MTF and use something temporary to clean the tranny a little, then flush that out and put in some real MTF.
Any ideas for an home made alternative?
My car is a 2008 Volvo C30, with the 2.4i non-turbo engine (Canada), M56H, 5 speed manual transmission.
The recommended MTF is an API GL-4 and is found in the first category of the "Updated List of Dedicated MTF Fluids" found in this forum :
A. These MTL fluids are closest to a Kinematic Viscosity of 6.X [email protected] (About the same viscosity as a Dexron VI) and SAE 70 or so:
1. Castrol Syntrans FE 75W,
2. BMW (Pentosin) MTF-LT-3,
3. Honda MTII or MTF 2.
4. Ford FML-XT-11-QDC
5. Volvo Manual Transmission Fluid (6.4 cSt) [Recommended for: type M65 5-speed with 6-cyl. engine, M66, MTX75 and MMT6 and of the type M56, M58 and M59 from and including model year 1996. Meets Ford specification WSSM2C200-D2]
6. Redline MT-LV SAE Viscosity Grade 70W/75W Vis [email protected]°C
I have the following at home :
5w30, 10w30 conventional and synthetic motor oils
15w40 conventional oil
Tractor hydraulic and transmission fluid (API GL-4)
Tufoil engine treatment
Thanks!
Re: Home made MTF? [Re: mlab] #5407931 04/19/20 03:44 PM
A
ARCOgraphite Offline
A
NO !
Unless it's a low powered Honda.
Tell us your transmission or do I have to guess?
Is it a Muncie M21 in a '67 Chevelle SS396?
A Ford Toploader in '69 Fairlaine 500 Fastback 428 SCJ ?
A Honda Transaxle in a Civic?
Without knowing. The only the API Gl-4 would be a MT fluid.
Some cars used ATF some used Pennzoil Synchromesh.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Home made MTF? [Re: ARCOgraphite] #5407933 04/19/20 03:45 PM
M
mlab Offline OP
M
Just edited my original post with some more info, thanks!
Re: Home made MTF? [Re: mlab] #5407935 04/19/20 03:46 PM
K
Kira Offline
K
edited
Re: Home made MTF? [Re: mlab] #5407943 04/19/20 03:50 PM
A
A
There is no emergency.
Re: Home made MTF? [Re: mlab] #5407950 04/19/20 03:55 PM
M
mlab Offline OP
M
So, nothing would come close and it could do damage? Could I use cheap ATF?
Re: Home made MTF? [Re: mlab] #5407952 04/19/20 03:56 PM
A
A
O.K.
Do 50/50 10w30 Synthetic and your tractor API GL-4
It may be good for 2 years or 20k Kms
Don't get that TUFOIL ANYWHERE NEAR ANYTHING !
Cool Car the C30
I was always intrigued by those as the last Hot Hatch.
Re: Home made MTF? [Re: mlab] #5407953 04/19/20 03:58 PM
A
A
Better Get krakin'
The sun is almost down on the Horizon!
Re: Home made MTF? [Re: mlab] #5407954 04/19/20 04:00 PM
A
A
I am exiting the forum. Good luck.
But if your local auto store carries Pennzoil Synchromesh in the Yellow bottle that would do the trick for a lighter fluid.
But warmer weather is coming!
Re: Home made MTF? [Re: mlab] #5407961 04/19/20 04:04 PM
M
Miller88 Offline
M
I ran cheap 15w40 in a Jeep AX5. I did eventually break the transmission, but I blame that on the numerous rev limiter clutch drops for about 20 minutes straight.
18 Forester 2.5I 6M
00 Jeep XJ
01 F-350 4x4 5M
Re: Home made MTF? [Re: ARCOgraphite] #5407962 04/19/20 04:06 PM
M
mlab Offline OP
M
Yeah, very nice hatchback. Very little choice for HBs in those years. Came down to the C30 and the VW Golf.
Don't worry, it would be for a couple of weeks, tops. Then, I'd flush it out and put in one of the MTFs in the list above.
What's the problem with the Tufoil? Too slippery?
Thanks
Re: Home made MTF? [Re: Miller88] #5407968 04/19/20 04:12 PM
M
mlab Offline OP
M
Yeah...might be those clutch drops!
Re: Home made MTF? [Re: mlab] #5408025 04/19/20 05:19 PM
CT8 Offline
Amsoil a phone call away.
2015 F150 2.7
2018 F350 6.2
Re: Home made MTF? [Re: mlab] #5408026 04/19/20 05:19 PM
CT8 Offline
2015 F150 2.7
2018 F350 6.2
Re: Home made MTF? [Re: mlab] #5408138 04/19/20 07:36 PM
slacktide_bitog Offline
Order the Redline MT-LV on eBay smile
