Toyota Genuine Motor Oil - old -vs new (latest)
by Ed_Flecko - 07/03/20 03:21 PM
Not trusting orbital buffer -- dilemma ???
by BAJA_05 - 07/03/20 02:44 PM
"New" Raw Water Pump From Amazon
by wings&wheels - 07/03/20 12:39 PM
Best refried beans?
by aquariuscsm - 07/03/20 12:16 PM
Northern hot cold pressure washer - clogged
by Donald - 07/03/20 10:48 AM
Porsche Transaxle Fluid Label
by wings&wheels - 07/03/20 08:52 AM
Ford 7.3 Godzilla Engine
by Snagglefoot - 07/03/20 08:43 AM
Growing Blackberries and Mulberries
by krismoriah72 - 07/03/20 07:50 AM
Yo! Starsky,
by RichR - 07/03/20 02:03 AM
Chinese air filters?
by Dogred08 - 07/03/20 01:18 AM
2006 Jetta TDI 5-speed with 324K miles in Florida
by atikovi - 07/02/20 10:51 PM
Rain X
by hardcore302 - 07/02/20 10:06 PM
K&N as for Trax MAF?
by hardcore302 - 07/02/20 09:46 PM
Auto Zone Delo 400 XLE 10w-30 1/2 off and rebate
by blupupher - 07/02/20 09:45 PM
RAM about to pass Silverado sales
by gfh77665 - 07/02/20 07:49 PM
JeffAR, ThaKid22, Speedeuphoria, 400rwkw, daveCarTruck
71841 Registered Users
86 registered members (97prizm, 1WildPig, andyd, 55hambone, aquariuscsm, Atrocious, 11 invisible), 2,064 guests, and 36 spiders.
Topics307,368
Posts5,309,926
Members71,841
2017 Corvette / 14.4k / ACDelco 75w90 gear oil #5391272 04/01/20 07:59 PM
dparm Offline OP
This is the third rear differential fluid change the car has seen. Mileage worked out to a tad longer (14.4k vs 11k) but overall track time was similar (22 hours vs 24 hours). The car has a dedicated differential cooler.
Blackstone highlighted that iron came down even further despite the longer run and everything else is steady. They attributed the aluminum to something "benign" like oxides. Confusing to see it continue to rise, but I don't consider it a wear metal for a differential. Open to ideas.
I'm now using Red Line 75w90 GL-5 gear oil instead of the OEM GM fluid.
Code
OIL             ACDelco    ACDelco    ACDelco
MILES IN USE    14,465     11,057     2,958
MILES           28,480     14,015     2,958
SAMPLE TAKEN    3/24/20    10/20/18   7/3/17
ALUMINUM        174        111        40
CHROMIUM        1          1          1
IRON            123        138        107
COPPER          5          4          3
LEAD            1          1          1
TIN             0          0          0
MOLYBDENUM      1          1          1
NICKEL          4          3          2
MANGANESE       4          6          7
SILVER          0          0          0
TITANIUM        0          0          0
POTASSIUM       1          2          5
BORON           67         62         56
SILICON         6          7          7
SODIUM          7          7          9
CALCIUM         14         16         11
MAGNESIUM       8          4          4
PHOSPHORUS      2291       2103       2299
ZINC            18         16         20
BARIUM          0          1          3
INSOLUBLES      0.3        0.3        0.2
WATER           0          0          0
FLASHPOINT �F  390        380        380
SUS VIS 210�F  69.4       71.1       73.7
cSt @ 212�F    12.80      13.23      13.93
TBN             3.1
TAN             6.4        9.2
2017 Chevrolet Corvette Grand Sport
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391610 04/02/20 07:51 AM
B
benjy Offline
B
redline lubes are as good as it gets + besides protecting more they last longer. only downside of excesive changes is $$$
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391751 04/02/20 10:46 AM
R
RhondaHonda Offline
R
Any idea how much is left behind in the diff cooler when you change it? I’m looking to change my 2017 Grand Sport soon if anything because I’m bored.
2019 Ford Raptor
2017 Corvette Grand Sport
2017 Yukon XL Denali
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: RhondaHonda] #5391966 04/02/20 03:35 PM
dparm Offline OP
Not sure, but when my shop changed it out, I gave them the gallon jug and they said they used "most of it". I can't remember if this is the process for the diff, MT, or both, but it involves putting fluid in and then putting the car in gear and running it at low speed for like 10 minutes -- then topping it off.
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5391974 04/02/20 03:48 PM
R
RhondaHonda Offline
R
Thanks. I’ll read up on the procedure before attempting.
2019 Ford Raptor
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5397163 04/08/20 09:14 AM
E
Emperors6 Offline
E
Thanks for posting this. I'll keep an eye on your UOAs to compare to mine since I also have a C7 smile
2013 Cadillac CTS-V
2016 Chevrolet Corvette Z06
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5402126 04/13/20 02:47 PM
J
jtwrace Offline
J
Aluminum could be your cooler coming apart internally.
"Science is not a democracy"-Earl Geddes Ph.D.
Re: 2017 Corvette / 14.4k / ACDelco 75w90 gear oil [Re: dparm] #5407824 04/19/20 01:40 PM
E
Emperors6 Offline
E
I also have aluminum in my diff oil changes for my C7. It's reassuring you're also getting it, since it might be normal wear.
2013 Cadillac CTS-V
