Originally Posted by Jarlaxle
Originally Posted by brages
Originally Posted by blupupher
OEM parts are made by an aftermarket manufacturer.
All OEM fluids are made by an outside vendor, none of them make their own oil, coolant or ATF.
Wix, Fram, Purolator, Mahle, Champ, Mann+Hummel, and others make OEM filters.
Many actual OEM parts (brakes, pads, fuel pumps, etc) are outsourced to "aftermarket" manufacturers and available in the aftermarket for much less as "unbranded" but identical to OEM.
Original parts are made by the Original Equipment Manufacturer, by definition.
No. Original parts are INSTALLED by the vehicle manufacturer. They no longer MAKE much in the way of parts.
OEM parts are parts that are manufactured by the manufacturer that produced the part for when the car was in production. An OEM part may be produced by a Tier I, Tier II, Tier III supplier, or by the auto manufacturer themselves. There are some parts that are almost always manufactured by the auto maker. Body panels for example.
I am one that generally prefers OEM parts. When I replace a fuel pump, I want to replace it once, so I use OEM. I want a water pump to perform to spec, and last long, so it will be OEM. I have found that OEM brake pad kits perform well, produce less dust, and are quiet. And when it comes time to change fluid in a CVT, I will only use OEM fluid.
When changing fluilds on my E350, I don't use OEM fluids, but do verify that the fluids I use are M-B approved in Bevo.
But there are some parts that I don't bother with OEM for. And I suspect very, very few fellow BITOG people use OEM. Brake rotors. Brake fluid is another. Motor oil. Differential fluid. Light bulbs. Oil filters, and engine air filters. Batteries. Serpentine belts. Tires.
Having spent enough time here at BITOG, and read enough of the referenced studies that many have shared links to, I would be hard pressed to believe that using OEM makes little, if any difference at all in these, and probably many other, applications. I believe aftermarket parts can be better than OEM in may of these items. Case in point that most here should be familiar with is Subaru OEM batteries. No doubt an aftermarket is better. How many times have we seen tear down of a Toyota or Honda oil filter? There is little doubt here that a Mobil 1 or Fram Ultra will protect an engine better, or at least longer, than most any OEM filter.
I'd put money on it that if you visited 3 different Toyota dealerships, at least 1 of them is using bulk Valvoline or Pennzoil. Why? Because it doesn't matter. People put 300k miles and more on engines with Quaker State, Castrol, Mobil 1, TGMO, and yes, even Supertech.and Amsoil.
In the case of the OP, if the fill plug is marked with Dexron II, I'd bet money that the factory fill was Dexron II. Toyota will sell you their branded tranny fluid.
