Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
98 registered members (830Lee, 1911CHAMPION, 2010Civic, 53' Stude, 2015_PSD, 2009Edge, 9 invisible), 1,929 guests, and 34 spiders.
Topics306,089
Posts5,287,217
Members71,596
oil viscosity chart? #5407573 04/19/20 08:28 AM
X
Xcbullet Offline OP
X
Is there any where that has actual oil viscosity, as in [email protected] and @100, comparing different company's and grades? some what like i have seen on fork oil. I put this here but it actually could include all oils even industrial. Like one I tried to find was amsoil SS 10-30.
96 Gmc Z71 - restored & rebuilt
2000 Bonneville
2004 LeSabra
99 Electra Glide - rebuilt
2001 edge600 -rebuilt
2002 edgeX 600 - rebuilt
Re: oil viscosity chart? [Re: Xcbullet] #5407578 04/19/20 08:31 AM
PimTac Offline
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: oil viscosity chart? [Re: Xcbullet] #5407606 04/19/20 09:20 AM
Snagglefoot Offline
I imagine you are looking for something like this. I put this together for some Shell affiliated oils. I haven’t seen a comprehensive list.
If you want the job done right......do it yourself.
Re: oil viscosity chart? [Re: Xcbullet] #5407616 04/19/20 09:36 AM
G
Gokhan Online Content
Online Content
G
The viscosity specs for the various standards are given in glory detail in the Afton Specification Handbook.
Afton Specification Handbook -- September 2019
2020 Toyota Prius Prime XLE plug-in hybrid, 2ZR-FXE engine, ~ 65 mpg on regular gasoline, ~ 5,000 mi
TGMO 0W-16 SN/RC Japan
OEM spin-on oil filter Japan
Re: oil viscosity chart? [Re: Xcbullet] #5407626 04/19/20 09:45 AM
K
ka9mnx Online Content
Online Content
K
He's looking for company brands:
https://pqia.org/passenger-car-motor-oil/
2005 Ranger 3.0 - SuperTech Syn 0w-20/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: oil viscosity chart? [Re: Snagglefoot] #5407856 04/19/20 02:12 PM
cdlamb Offline
Yes, I am surprised there hasn't been a comparison made up like this for each of the oil brands. Quite a difference in viscosity from the PP D1/G2 to a Shell Rotella. Would be interesting to see a spreadsheet like this, for each grade of oil, with viscosities, & additive pack differences between competitors.
Re: oil viscosity chart? [Re: cdlamb] #5407879 04/19/20 02:39 PM
MolaKule Offline
Global Moderator
Global Moderator
And a good opportunity for you to become familiar with Excel. smile
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: oil viscosity chart? [Re: Xcbullet] #5407893 04/19/20 03:07 PM
Z
ZeeOSix Offline
Z
If you want the latest up to date info, pretty much every major oil brand KV40 and KV100 data can be found on the manufacture's website.
Yes, it would be a good Excel spreadsheet project for someone to build-up showing all the major brands and viscosity.
As far as Amsoil SS oils ... all the technical data is on Amsoil's website ... just need to search a little more.
https://amsoilcontent.com/ams/lit/databulletins/g2880.pdf
Re: oil viscosity chart? [Re: Xcbullet] #5408021 04/19/20 05:14 PM
G
Online Content
G
How would knowing the KV help someone? It's a fairly irrelevant viscosity. What matter are the HTHS and VI. While the VI is usually published (or could easily be calculated from the KV), the HTHS is seldom published. What also matters is the base-oil viscosity, for which I have developed a calculator to estimate if both the KV and HTHS are available. The KV hardly matters, except for the oil leaks.
Re: oil viscosity chart? [Re: Xcbullet] #5408029 04/19/20 05:23 PM
X
Xcbullet Offline OP
X
Thanks everyone
I find I need to mix to get what I want sometimes. So once I know what works then ad and divide and find something in that range. Did this with fork oil and I,m working on whats best for primary chain case with clutch now. I have come up with 7 good choices with this method from the help above. Would like to find one with the smalest gap between KV40 and KV100 in the range that worked best fo me so far. That being amsoil ATF and amsoil Primary. I have a list of 17 I tried to post. One I want to try is Cat tdto sae 30.
The HTHS is a good point.
2000 Bonneville
2004 LeSabra
Re: oil viscosity chart? [Re: PimTac] #5408085 04/19/20 06:36 PM
O
OilUzer Offline
O
Originally Posted by PimTac
Good info. I had forgotten about all good info we have in bob's
Re: oil viscosity chart? [Re: Xcbullet] #5408149 04/19/20 07:42 PM
G
Online Content
G
Thanks everyone
For mixing viscosities, you need to use the Arrhenius equation or a more complicated formula.
[Linked Image from lh3.googleusercontent.com]
You can also use the Widman viscosity-mixing calculator, which employs this formula with some small unknown deviance. There are also more complicated formulas, which may be needed when mixing two dissimilar oils (such as dino and PAO).
