- Joined
- Nov 29, 2009
- Messages
- 7,217
I bought a new Quincy compressor and I would crack the water drain valve open for a few seconds every few days thinking that was enough to get the water out. Then I discovered I can go back 30 minutes later and get more water out each time without the pump still not turned on. I wonder if I need to just drain the tank completly after every use. Although an empty air compressor imo doesn't do much good. Imo constantly draining the water will rust the tank faster because rust only occurs where their is air. If that one area of the tank always has a little bit of water at the bottom it won't rust as much imo.
