Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
104 registered members (4WD, 10WSmuckers, 330indy, 55hambone, 53' Stude, 14Accent, 11 invisible), 2,505 guests, and 36 spiders.
Topics305,938
Posts5,283,305
Members71,540
2015 Ram 3.6 Engine Temps #5407526 04/19/20 07:39 AM
O
oilchangeguy Offline OP
O
my engine temps get up to 231 degrees at times. Dealer said this is normal for that engine. Anyone else experience this?
2015 Dodge Ram 1500 QS Ultimate/ Mopar Filter
2017 Ford Edge SE QS Ultimate/ Motorcraft Filter
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407539 04/19/20 08:01 AM
Snagglefoot Online Content
Online Content
It would be normal for higher rpm use. What are the typical shift point rpms?
If you want the job done right......do it yourself.
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407542 04/19/20 08:03 AM
H
hemitom Offline
H
In normal driving conditions highly unlikely to be normal. I have never seen temps this high in any of the cars i have owned unless there was a system failure.
But in your case with the 3.6 possible ?? i have no experience with this engine.
2009 Saturn Vue.
2015 Mustang GT Convertible.
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407565 04/19/20 08:24 AM
Z
Zaedock Offline
Z
I don't believe that is normal, especially as the coolant is also used to cool the transmission.
I did a quick search in gOOgle and found that people with V6 Rams had issues with the accuracy of the gauge (some verified with an IR gun) and some had water pump issues.
Apparently there was a backorder of pumps back in '15 +/-. I have a Fluke IR gun, but I imagine the Harbor Freight one isn't too bad. I would shoot the water pump and T-stat area and then compare to the gauge. If it matches close enough, you may need a water pump.
I would check for any TSB's on the issue.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: 2015 Ram 3.6 Engine Temps [Re: Snagglefoot] #5407581 04/19/20 08:37 AM
Online Content
Just to verify, are you talking about coolant temps or oil temps. A lot of Rams have oil temp readouts in addition to coolant temps. 231 sounds high for coolant temps, but would be normal for the oil temp if the engine was running at higher rpm such as with towing.
Re: 2015 Ram 3.6 Engine Temps [Re: Snagglefoot] #5407589 04/19/20 08:48 AM
O
O
Its engine coolant temps. Oil has been up to about 245 when towing on a hot day.
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407614 04/19/20 09:35 AM
Online Content
Ok, your indicated temp is too high. Take Zaedock’s advice and shoot some temps with a IR gun. They’re a must-have tool anyway.
Re: 2015 Ram 3.6 Engine Temps [Re: Snagglefoot] #5407617 04/19/20 09:37 AM
B
big_guy Offline
B
check the grill shutters.. i've read you can remove couple of the flaps to increase air flow. or consider pulling them right out
I just bought a 2019 classic 3.6 only gets hot 220' s when stuck in traffic.
2019 RAM 1500 CLASSIC SXT PLUS QUAD CAD 4X4... 3.6L
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407620 04/19/20 09:41 AM
J
JTK Offline
J
On my 2017 Ram 1500 with the pentastar, I've seen coolant temps get close to 220degF sitting at a stop light on a very hot, humid day after being on the interstate.
It's normally in the 180-185 range. Same with engine oil and ATF temps which all display on the dash.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: 2015 Ram 3.6 Engine Temps [Re: JTK] #5407629 04/19/20 09:46 AM
B
big_guy Offline
B
Case Number: S1324000004
Release Date: 2/12/2013
Symptom/Vehicle Issue: Vehicle Temperature Gauge Reads Hot
Discussion:
Engineering has determined the gauge is reading higher than design intent. If this is the customers complaint, review the below operating parameters. This condition is being investigated by Engineering.
Some customers may comment the temperature gauge appears to read hot or above the half way point in its travel. The thermostat is designed to open at 221F, resulting in an Engine operating temperature of 230F. Verify the vehicle is operating at no more that 230F with the wiTECH tool, and that no codes are present before releasing the vehicle to the customer.
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5407688 04/19/20 11:00 AM
I
IndyFan Offline
I
I think mine in my Jeep has hit 223 or 224 on the guage. It has been rare, but does happen once in a while. Not as high as yours but not too far off, either. The fan then kicks on and sounds like an F-14 at military power, then it comes right down. I tow only a little with that Jeep, so it was on its own when I noticed it. I think one time was rock crawling in Utah at about 1mph in very hot conditions.
Edit...I'm reading it from a digital readout, not a needle.
18 Jeep JLUR Wrangler 3.6 31k
15 Ford Transit 129k, Reman 3.5 @85k
17 Jeep Renegade 2.4 29k
08 Jeep Wrangler 3.8 141k
04 Jeep Grand Cherokee 4.7 111k
99 Mercedes E430 Sport 90k
Re: 2015 Ram 3.6 Engine Temps [Re: big_guy] #5407689 04/19/20 11:04 AM
T
tiger862 Offline
T
Discussion:
This has been the same since electric fans have came out in front wheel drive vehicles. Most gauges don't have a number just low, normal, or high. Engines run higher temperature as it is more efficient. The op is running severe service with towing so at higher rpms and more load temps go up. Only thing that you could do is run a Synthetic oil and keep radiator clean. Maybe check grill shudder for proper operation.
Tiger862
2018 Grand Caravan
Re: 2015 Ram 3.6 Engine Temps [Re: oilchangeguy] #5411559 04/23/20 07:23 PM
J
JTK Offline
J
I've been paying attention to mine since I made the above post.
With ambient temps in the 30-40F range and after my 40mile drive to work my engine oil and coolant temps stay around 194-196F. Transmission temp about 10deg cooler and oil press around 42psig.
