Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
Mesh Router System - 160MHz Backhaul?
by JHZR2 - 05/26/20 08:06 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
107 registered members (4WD, 55hambone, Astro14, AlienBug, 1978elcamino, 01rangerxl, 8 invisible), 2,524 guests, and 51 spiders.
Topics305,938
Posts5,283,284
Members71,540
Page 1 of 3 1 2 3
Do you drain your air compressor tank? #5407520 04/19/20 07:36 AM
M
motor_oil_madman Offline OP
M
I bought a new Quincy compressor and I would crack the water drain valve open for a few seconds every few days thinking that was enough to get the water out. Then I discovered I can go back 30 minutes later and get more water out each time without the pump still not turned on. I wonder if I need to just drain the tank completly after every use. Although an empty air compressor imo doesn't do much good. Imo constantly draining the water will rust the tank faster because rust only occurs where their is air. If that one area of the tank always has a little bit of water at the bottom it won't rust as much imo.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407540 04/19/20 08:01 AM
H
honeeagle Offline
H
mine has been in the garage attic for 15 years ,no rust, synth oil as per this board and never drained.
Volvo 670 singled smart car 'on deck' towing newmar 5th
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407545 04/19/20 08:05 AM
9
92saturnsl2 Offline
9
Not as often as I should. When I do drain (every couple weeks?) the water comes out brown so evidently there is some rusting going on. It’s not a high dollar compressor by any means so if the tank goes someday, I’ll just replace it. Will probably take a long long time for a tank to rust through.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407550 04/19/20 08:11 AM
Char Baby Offline
Thanks for the reminder! smile
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407561 04/19/20 08:21 AM
T
Traction Offline
T
Yes, you should drain your tank. A compressor service tech told me about a local car dealer shop that was saying their compressor wasn't working right. Turned out that the 80 gallon tank was completely full of water! I always drain mine when before I fire it up while the compressor is cool. Otherwise water in the tank will vaporize when the hot air hit's it and send it down the air line. You could always install an automatic tank drain, which is basically just a solenoid valve operated by a timer. When it's warm and humid is when the water builds up pretty fast in a compressor.
Certified Tire Service Instructor since 2009
50 Chevy Fire Truck
13 Tahoe Pursuit
97 C5 Corvette
00 BMW M Roadster
02 Camry
12 Camry
81 Camaro
55 Chevy C4
Re: Do you drain your air compressor tank? [Re: honeeagle] #5407563 04/19/20 08:22 AM
J
JC1 Offline
J
I installed a ball valve on my compressor. I usually open the drain for 5-10 seconds once or twice a week and let the water drain out. Every month or so, I'll let all the air out of the tank and then I'll fire it up and let it run until it's full (60 gallon tank).
Are you sure about that? All compressor air tanks will get water inside them due to condensation.
When I bought a 27 gallon coleman compressor a few years back, the first thing I did when I got home was drain the tank. There was at least 1 liter of rusty water inside that tank. The previous owner never drained it. It was so rusty it looked like gravy. I installed a ball valve on it and draining it was easier.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407564 04/19/20 08:22 AM
E
eljefino Offline
E
If you leave a puddle of water in the bottom of the tank, and if (big if) it doesn't corrode "underwater", it still will at the "shoreline".
I usually drain mine, and leave it open, but don't put tons of thought into it.
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407570 04/19/20 08:27 AM
skyactiv Offline
I don't drain mine unless I'm using it. Being that I'm a semi mechanic, I put a manual drain valve with a lanyard on my air compressor which makes it a breeze.
We had a smaller Quincy back up compressor fail the annual tank sonic test and tossed it in the scrape bin at work. Ran fine, but no one wanted it with a bad tank.
[Linked Image]
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407582 04/19/20 08:38 AM
E
Eddie Online Sleepy
Online Sleepy
E
I actually leave my drain valve ever so slightly cracked always, so it will blowout any water as it runs. Ed
2014 CX5 Touring 2.5L :-)
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407583 04/19/20 08:38 AM
Z
Zaedock Offline
Z
When I owned my shop, I drained the 250 gallon tank daily before going home.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407597 04/19/20 09:07 AM
R
Randol Offline
R
Pretty frequently, mines an 80 gallon vertical. I plumbed the drain out to be easily accessible and used a ball valve with a male air coupler to fill my portable tank.
Of course I purge it before filling the storage tank.
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407598 04/19/20 09:08 AM
ABN_CBT_ENGR Offline
That depends on several things.
What is the tank construction? ( almost all are ASME certified for pressure but the plate thickness has more to do with how much corrosion it can withstand)
Do you need instrument quality air?
Business or home use?
Coded or non coded system?
The average home use system will be just fine with even a monthly drain ( unless you have high humidity and really use it a lot)
Weekly is better, every use is even better- a timed drain is the easiest over the long run.
Lot of choices there and all of them will work and have limitations- depends really on your usage rate and how clean you need the air.
I need almost hospital grade clean dry air because of instruments and tooling but the average mechanic use can get by satisfactorily with nothing more than an "every once in a while" schedule. (and a good separator in the line)
Lots of ways to do this and the system
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407600 04/19/20 09:10 AM
dave123 Offline
If pumping hot air directly into tank water condensat will be much greater than if it was equipped with a after cooler and separator. You seem to be obsessed over a bit of water in tank during and after use. To be honest drain tank before and after if used for intermediate daily use. For 100% duty cycle use example Sandblasting I may have 1hr long pump run times or more just keep valve cracked during use.
You have a high end build unit with a high quality tank using common sense and little maintenance it will last a lifetime.
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407612 04/19/20 09:29 AM
J
JLawrence08648 Offline
J
Every tank I've had had a petcock on the bottom so it was always easy. I leave the petcock open when not in use as I feel if the petcock is closed there's no air movement thus rust will develop. When I turn it off and I'm done for good, I crack it so if there is any moisture it will blow out besides the air going past will dry any water out.
However, I think the inside of the tank is unpainted metal and will rust regardless. By draining, we are not accelerating the decline.
2019 Hyundai Santa Fe SEL Plus, 2.4
1992 Acura Vigor GS, 2.5
Re: Do you drain your air compressor tank? [Re: motor_oil_madman] #5407635 04/19/20 09:53 AM
sloinker Offline
I also have a Quincy. I drain it until the water stops when I remember, so every so often. I will drain it completely maybe once a year.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Page 1 of 3 1 2 3
