Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
KPVD Eerily Deserted
by wings&wheels - 05/29/20 12:24 PM
BMW N55 Recommendations
by BSchmidt25 - 05/29/20 10:21 AM
Castrol / Mobil 1 blend?
by mbres2000 - 05/29/20 09:40 AM
My Henry 22 Magnum Rifle (pics)
by tig1 - 05/29/20 09:04 AM
overfilled my crankcase by 3/10 of a liter - problem?
by tom in boise - 05/29/20 08:49 AM
Espresso
by buster - 05/29/20 08:34 AM
I didn't believe there were fake spark plugs.
by JustinH - 05/29/20 08:14 AM
New Tire Selection
by artbuc - 05/29/20 07:44 AM
Well question
by supton - 05/29/20 07:11 AM
Cable Modem Thoughts/Recommendat
ions?
by alarmguy - 05/29/20 07:10 AM
Tire choice 2016 Lexus es 350
by Toros - 05/29/20 06:20 AM
Infineum trends: Passenger vehicles (2019)
by Gokhan - 05/29/20 05:11 AM
Another story from the service bay
by clinebarger - 05/29/20 12:11 AM
KIA TYPE 4 (M) ATF
by flinter - 05/28/20 08:49 PM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
82 registered members (53' Stude, 4WD, Alfred_B, 928, AlienBug, ABN_CBT_ENGR, 6 invisible), 2,376 guests, and 39 spiders.
Topics306,017
Posts5,284,902
Members71,558
15/40 CNG engine oil in a gasser? #5407216 04/18/20 06:26 PM
dblshock Offline OP
Any reason it wont work in a mower?
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
Toyo Open Country H/T II
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Falken Wildpeak AT3W
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407219 04/18/20 06:34 PM
simple_gifts Offline
Why would you?
Probably not formulated to deal with the combustion by products of gasoline.
Are you planning to take your lubrication contrarian thinking to an new absurd level? (j/k)
2004 Prius; 131K; ATM
2007 Yaris 108K ATM
2006 B2300;137K;ALM
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407220 04/18/20 06:39 PM
Dinoburner Offline
What could go wrong, seriously.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407222 04/18/20 06:43 PM
dblshock Offline OP
maybe it's better IDK?
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407229 04/18/20 06:59 PM
B
blufeb95 Offline
B
Looking at the Delo Spec sheets, their dedicated CNG oil seems to have lower sulfated ash content and a lower TBN than the standard HDEO. Not sure if it's a big deal in a mower, do mowers really deplete the TBN in most cases? I guess the best question is what reason do we have to change the oil in a mower, too much contamination from wear metals due lack of filtration, fuel dilution, shearing from the extreme heat of an air cooler engine, something else?
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407236 04/18/20 07:06 PM
U
userfriendly Offline
U
Petro Canada GEO LD meets manufactures' specs for LPG, CNG & also meets CK-4/SN. They call it the ultimate mixed fleet engine oil. Available in 10W30 & 15W40 only.
I cannae think of a reason CNG/LPG wouldn't work extremely well in a mower.
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407245 04/18/20 07:24 PM
CT8 Offline
CNG engines are different as they operate at a conservative steady state RPM so the adds are different. Would the engine blow up?
No ! but the add packs are some what different. Probably short interval oil changes would be the safest. Do a uoa after 2,000 miles of use .
2015 F150 2.7
2018 F350 6.2
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407247 04/18/20 07:27 PM
dblshock Offline OP
at work I drive a company CNG Semi, runs good sounds great and they let the OCI's go out 50k..I don't think the bearings rings cams ect are are worlds apart.
05 Lexus GX470 175k
640:1 TCW-3
M1 0W40 XG-3614
06 4Runner SR5 155k
640:1 TCW-3
M1 0W40 XG-3614
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5407286 04/18/20 08:21 PM
CT8 Offline
No just the add packages because the CNG is cleaner.
2015 F150 2.7
2018 F350 6.2
Re: 15/40 CNG engine oil in a gasser? [Re: dblshock] #5410587 04/22/20 07:03 PM
F
Fraser434 Offline
F
Most likely it will work fine, whats different?
Gas/LNG engine oil has about 500-600 ppm zinc/phos
The duration of LNG engines is usually very long and large bore sizes which tend to use more oil, the oil is formulated with low ash (zinc phos) to avoid combustion chamber deposits that cause misfires.
IMO, I wouldn’t run the oil any longer than you would regular dino oil. For a regular interval should work ok.
