Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
Carquest Blue 85522 C&P
by FordBroncoVWJeta - 05/25/20 07:52 PM
2020 RAV4 Hybrid - oil options
by CELICA_XX - 05/25/20 07:44 PM
any battery charger/repair that can fix sulfation?
by apollo18 - 05/25/20 07:28 PM
Need Mice Advice
by Mr_Luke - 05/25/20 07:01 PM
pressure washer air compressor oil
by bedwards - 05/25/20 06:49 PM
2014 Elantra delayed shift 4th to 5th
by Propflux01 - 05/25/20 05:51 PM
2002 Ranger Electrical Weirdness (GEM, RAP?)
by DuckRyder - 05/25/20 05:47 PM
Oil change problems
by philipp10 - 05/25/20 05:41 PM
Denso 150 3024
by thrace - 05/25/20 04:58 PM
does ac delco warranty the replacement battery?
by apollo18 - 05/25/20 04:39 PM
Water drainage issue
by Paul_Siu - 05/25/20 04:39 PM
13 Corolla PCV
by AJB0009 - 05/25/20 04:24 PM
mikespine, Typerguy, showtyme1958, rickyradit, YogiTheCat
71528 Registered Users
29 registered members (bworley, bachman, ajchien, ArrestMeRedZ, BlakeB, blufeb95, 2 invisible), 1,167 guests, and 35 spiders.
Topics305,879
Posts5,281,961
Members71,528
Battery Charger Question and Recommendation #5406902 04/18/20 11:03 AM
H
H20T Offline OP
H
I have a this smart battery charger. https://www.amazon.com/Black-Decker...QJ1G/ref=cm_cr_arp_d_product_top?ie=UTF8
I have this battery on order. https://www.amazon.com/gp/product/B00CC65QCM/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
Is it ok to charge the 15ah battery that I ordered with my charger on the 4 amp setting or do I need to get a 3 amp charger like this?
https://www.amazon.com/gp/product/B0756PV96N/ref=ox_sc_act_title_1?smid=ATVPDKIKX0DER&psc=1
Re: Battery Charger Question and Recommendation [Re: H20T] #5406904 04/18/20 11:08 AM
E
eljefino Offline
E
4 amps is too much for that little guy. Ideal charge rate would be 1/10 capacity or 1.5 amps.
Re: Battery Charger Question and Recommendation [Re: H20T] #5406914 04/18/20 11:19 AM
H
H20T Offline OP
H
Thank you. I was thinking I read somewhere that you can charge up to 20% of the amp rating but I am not really sure of what I am doing when it comes to this.
Re: Battery Charger Question and Recommendation [Re: H20T] #5406920 04/18/20 11:24 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
The nameplate on the front indicates that "initial current" in cyclic use can be 4.5A. Generally the chargers will start dropping current quickly, just due to Ohm's law. But you could cause irreversible gassing that doesnt recombine, which is deadly for this type of battery. So its better to use a lower rated charger just in case.
Id prefer one of the 0.8-2A chargers that is on the market. The NoCo latest temperature compensated 1A is a good option, and the BatteryMinder temperature compensated unit (1510, IIRC) is another. Both operate in different ways, and the NoCo doesnt actually float charge the battery, but unless its sitting in standby for long periods, that may not matter much to you.
Links:
Noco 1A
Battery Minder
Re: Battery Charger Question and Recommendation [Re: H20T] #5406959 04/18/20 12:19 PM
J
JimPghPA Offline
J
A resistor in series between the charger and the battery can reduce the current so you can use a larger charger on a small battery.
Now if I could only find a Radio-Shack store to buy a power resistor at. All kidding aside, a 12 Volt accessory or brake light bulb will work fine as a resistor to reduce the current flow, assuming you know enough to be able to wire it in series between the charger and battery. NOT in parallel.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Battery Charger Question and Recommendation [Re: H20T] #5406994 04/18/20 01:20 PM
U
UncleDave Offline
U
4A is too much continuous current for that batter as El Jefino states
charging at 20% of face AH value is pretty safe at the correct voltage.
I have several of the little Shumacher 3Amps and they work pretty well, but I think hey top out at 40AH where their "smartness" stops, but Ive had them maintain small car batteries before, so they cover your small stuff pretty well, but have to stay on the shelf for anything substantive.
The battery minder product is also pretty solid.
Nocos late offering in the last two years have been pretty solid - prior to that not so much.
I'll stick to the optimate 6 being the best overall value in a throw down charger.
UD
Uncle Dave
Cat 3126/2 MB3500/Titan/RX400H/17 Ridgeline
700HP V10/ 725HP BBC/ Raptor 700/ KFX450/ YZ250/Onan 8K/ Cat3011C
Re: Battery Charger Question and Recommendation [Re: H20T] #5407023 04/18/20 01:57 PM
R
Rand Offline
R
The charger is a smart charger it wont actually charge at 4amps or at least not for very long.
it will auto switch to float etc.
IMO its fine to use with that battery on the 4amp setting.
Re: Battery Charger Question and Recommendation [Re: Rand] #5407047 04/18/20 02:44 PM
U
UncleDave Offline
U
it will auto switch to float the. IMO its fine to use with that battery on the 4amp setting.
In theory it is smart. In practice I've seen problems with them.
This product line is OEM'd to Black and Decker from Vector. Im ny experience they are only so so at charging and they are poor at maintaining.
I no longer use these for unsupervised charging after a string of logic and fan failures causing overheats.
They pretty much stay on the shelf these days. Mine are circa 2010. Maybe the newer ones are better.
UD
[Linked Image]
Uncle Dave
Re: Battery Charger Question and Recommendation [Re: UncleDave] #5408007 04/19/20 05:02 PM
K
kc8adu Offline
K
i have the vector in the rear of the pic.
the fan and output cap cause 90% of the problems.
the other issue is the idiots at the factory did a lousy crimp job on the clamps.
this all confuses the "smart" functions and makes the device stupid.
UD
[Linked Image]
