Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
Will 0w40 be good for next winter?
by mahanddeem - 06/05/20 01:21 PM
Motor Oil Saver less than 10.00 shipped
by cknight49090 - 06/05/20 12:27 PM
Taking my kid fishing
by Quattro Pete - 06/05/20 12:22 PM
LouK2, Michael328i, tyman, Knot_A_Mekanik, Matts59
71615 Registered Users
109 registered members (01rangerxl, 28oz, 4WD, 830Lee, ammolab, A310, 19 invisible), 1,845 guests, and 29 spiders.
Topics306,265
Posts5,289,268
Members71,615
M1 15w50 vs RT6 15w40 πŸ€” #5406380 04/17/20 07:08 PM
SavagePatch Offline OP
For a Champion 27 Ton Log Splitter with a 224cc engine which would you choose between these two? Mobil 1 15w50 or Rotella T6 15w40. Price it negligible. It has a 1/2qt oil capacity. πŸ›’
Thanks in advance! πŸ”§
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406393 04/17/20 07:21 PM
N
nascarnation Offline
N
Both will work fine.
My experience with OPE is most failures aren't lube related, its fatigue/quality stuff like a broken exhaust valve or con rod.
You tear them down and the piston and bore looks like new, except there's an exh valve smashed into the piston crown.
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406421 04/17/20 07:51 PM
A
Astro_Guy Offline
A
What is your expected operating temperature range? Have you ever tried pull starting a small engine filled with 15w-40 at or below freezing? I have. It was real, and it was fun, but it wasn't real fun.
Based upon the supplied chart I would recommend RT6 5w-40 over the options you offered.
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406427 04/17/20 07:58 PM
R
ripcord Offline
R
Agree that lubrication failure is rarely what does in small gas engines, assuming that it's kept topped up. Besides breakage, accelerated wear and failures are often due to storage and maintenance issues. Trash accumulates or critters build nests under the tin and plug the cooling vanes so it over heats. Gasahol oxidizes in the carb passages making engines run even leaner (hotter) than they come from the factory these days.
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: Astro_Guy] #5406462 04/17/20 08:36 PM
I should have specified for summer months. I agree with you though. For cold winter I'd use something lighter like GC 0w30 or a 5w40.
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406472 04/17/20 08:42 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Given that your manual specifies neither of those, I’d pick the 15w-40...
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: JHZR2] #5406598 04/17/20 11:52 PM
+1 thanks for the input!
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406622 04/18/20 12:53 AM
dinofish Offline
Out of curiosity, why not the 5W-30 synthetic as shown by the chart to tolerate summer weather?
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: dinofish] #5406634 04/18/20 01:53 AM
K
Kamele0N Offline
K
Which one? VW 504/507 BMW LL-04 MB 229.51 with HTHS 3.5+
Or API/ILSAC one with HTHS in 2.8-3.0 range?
Or maybe conventional 5w30 since you are dinofish smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: nascarnation] #5406646 04/18/20 02:27 AM
L
Linctex Offline
L
^^^ 10,000% CORRECT! ^^^
Your Chinese engine will fail mechanically before you wear it out.
Just run the cheapest 15W-40 you can find that meets current API specs.
(or, if it is really cold, 5W-30)
EDIT: I do have to hand it to Champion branded OPE - -
for being Chinese made stuff, they are very close to Honda for Quality and Reliability.
Well, at least ...... close enough to satisfy most consumers.
I also like their tasteful yellow and black color schemes!
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406647 04/18/20 02:29 AM
J
JR Offline
J
I have a intek206 5.5hp, with many hours on it.
I have used both oils in the past, and will in the future.
These small engines will run on anything you choose to use.
My small engines often get left over 0/5w-20, 15w-40, hdeo sae30/40, 20w-50, 25w-40, 10w-30/40, you name it.
Never a oil related failures here,
but I do make a point to have syn 0/5w-20 in the crankcase before it dips to or below freezing temps.
heck my tiller and bagged clean up mower have FS 5w-20dino and mmo.
-harvey
97 F250HD 7.3 320K 01 Astro 220K
93 metroXFi 94.5K
01 Impala 300K
04 RTV900R 1150hrs
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406747 04/18/20 07:39 AM
dave123 Offline
Not sure why 15w50 for a choice any 40 or 30 will do. Engine oil never big concern on this and many other units keeping hydro fluid clean keeping fuel and air filters clean. I imagine it’s oem spark plug is a torch ditch that hing and hydro fluid first change after few hrs.
It seems to be a decent little unit if it only had a GX Honda on it it would be a sweet little unit.
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406773 04/18/20 08:05 AM
B
Bighorn2500 Offline
B
For about $20 get a gallon of some T6 5W40 and you’re good for like eight oil changes based on hours not by season changeovers. Try to run non-ethanol gas if you have it available so the carb doesn’t get gummed up as well.
2012 Ram 2500 SLT 6.7L Cummins 4x4
2018 Dodge Durango GT 3.6L 4x4
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406777 04/18/20 08:09 AM
Z
Zaedock Offline
Z
I have a 22 ton Huskee splitter. A few years ago, I lent it out and they wanted to be nice and change the oil for me. Unfortunately, they left the drain plug loose and the B&S engine lost it's oil while while they ran it that one last time.
Long story short, I installed a Predator 212cc 6.5HP engine which has worked p!ssah. I currently have some leftover PP 10W30, but it's time for a change and I'll be using Delo 15W30 or 40 for the warm season. Given your choices, I would pick the 15W40.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: M1 15w50 vs RT6 15w40 πŸ€” [Re: SavagePatch] #5406880 04/18/20 10:27 AM
H
hemitom Offline
H
For typical home owner use any syn 10w30 is more than sufficient .
2009 Saturn Vue.
2015 Mustang GT Convertible.
