Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
102 registered members (2015_PSD, 97tbird, 4WD, 390pi, 2010Civic, 69Torino, 8 invisible), 2,422 guests, and 64 spiders.
Topics306,059
Posts5,286,623
Members71,593
2017 Ford F-150 3.5L ecoboost #5406209 04/17/20 04:26 PM
J
jharmon203 Offline OP
J
I used pennzoil that advertised being good for turbo charged engines. I only got it because it was on sale. The Meijer brand I used in the previous oil change worked well too. The only thing that hasn't done great is the first oil change with motorcraft. It could be due to engine break-in but after 9k miles you would hope that would be a little more resolved.
I increased the mileage change again to test the theory on the fuel issue with ecoboost engines. This was closer to 9k miles.
Attached PDF document
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5406661 04/18/20 04:03 AM
W
WyrTwister Offline
W
Do as you wish , your money .
I am going ~ 3000 on dino oil and 5000 - 5500 on synthetic . Cheap insurance , when compared to the total cost of ownership .
Wyr
God bless
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5406668 04/18/20 04:48 AM
Z
zeng Offline
Z
Iron and copper wear rates is trending down , no worry IMO .
11000 miles as lab suggested should be good to go .
Break-in is still probably working its way .
Re: 2017 Ford F-150 3.5L ecoboost [Re: WyrTwister] #5406783 04/18/20 08:12 AM
J
J
I respect your decision, but what if you are buying insurance you do not need. The trends on my engine are wearing just fine with longer oil changes. Plus, I get the benefit of the oil analysis.
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5406847 04/18/20 09:31 AM
T
Triple_Se7en Offline
T
If you are first and last owner, use Wyr's suggestion. If you sell at around 100-125K and 10 years - as most do, Supertech oil and Supertech filter is fine.
I am pro-Pennzoil Ultra Platinum. This Platinum UOA is just OK, in the add-pack dept. The Warren Oil's Meijer UOA tastes better to your engine.
Strange how that works sometimes. You can get Ultra Platinum at Walmart.com for the same price as Platinum. $35 purchase for free shipping. I bought 2 in January.
The Platinum did fine for your long OCI. I credit the nice GTL base oil over the just average add-pack. If it were me, I'd cut the OCIs to 7K. Keep that oil from turning dark soon. My vehicle oils stay clear on the dipstick for over 1K. I suggest that measurement and adjust OCIs to fix - if necessary. Yes, I consider clear as being necessary. First and last owner here and anal over my engine oils. My filters are middle-ground.... not basic like PepBoy Proline for example - nor top-tier like Fram Ultra.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5407189 04/18/20 05:37 PM
N
NuttCase Offline
N
That looks like a good run to me. The Shell Helix Ultra 5W30 typically run at 11.5 to 12.2 KV100 virgin and your sample is down at 9.33 so you have lost a fair amount of KV (assuming Pennzoil and Shell equivalency) and it is just within spec. If that was my UOA I'd probably be keeping to a 8000-9000 mile OCI and not the Blackstone suggestion of pushing another 2,000 miles.
'15 Merc C300 diesel hybrid, Shell Helix Ultra 0W30 ECT C3
'13 Ford Fiesta 1.25, Shell Helix Ultra 5W30AG
'17 Audi R8 V10, Motul 8100 X-Clean+ 5W30
'19 Mini JCW, Shell Helix Ultra 0W30 ECT C3
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5408779 04/20/20 03:37 PM
J
J
I will certainly not be going over 10k miles. However, this oil change interval seems to be good enough for now.
Re: 2017 Ford F-150 3.5L ecoboost [Re: jharmon203] #5409082 04/20/20 09:41 PM
Cujet Offline
The error is in thinking a UOA displays the wear rate. Nothing could be further from the truth.
Furthermore, a good number of the 3.5 EB engines are have timing chain problems at 90-100K miles. This is due to significant particulate matter in the oil, lack of sufficient viscosity and evaporated fuel byproducts. The test for fuel dilution does not determine how much fuel has evaporated from your oil, leaving behind components that are not oil. The fix is about $4K. Or you can simply choose a quality synthetic of sufficient viscosity and change it ever 5K and expect 200K+ miles.
Re: 2017 Ford F-150 3.5L ecoboost [Re: Cujet] #5409288 04/21/20 07:33 AM
J
J
Do you have a link to documentation that supports this?
Re: 2017 Ford F-150 3.5L ecoboost [Re: Cujet] #5409342 04/21/20 08:52 AM
CT8 Offline
Lets use Cujets post an a more general truth which we all should know is each engine and each engines use should determine the oil change interval . UOAs are for how the oil is holding up. Thickening .thinning Ph etc.
2015 F150 2.7
2018 F350 6.2
