Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
89 registered members (2010Civic, 53' Stude, ABN_CBT_ENGR, 2015_PSD, 2009Edge, Ag76, 9 invisible), 1,928 guests, and 37 spiders.
Topics306,089
Posts5,287,208
Members71,596
Page 1 of 3 1 2 3
What filters are you guys using on 3.6 pentastar #5406112 04/17/20 03:02 PM
stenerson Offline OP
I've done about 7 changes so far on my 2018 Ram 1500/pentastar 3.6..... I've used stock filter. I know I'm thinking like a cheapskate but there's not much to these canister filters. No metal casing, fancy springs or valves but at 10 bucks a pop seems illogical.
I noticed at Wallyworld today that supertech has a compatible one for 3 bucks. Fram xguard has a "synthetic" one rated for 20K for 11 bucks. I'm not going crazy yet with extended miles on changes so not worth it.
Interested to hear what others here use on their 3.6.
I dig the ease of these canister filters, easy access and less mess.
Another question, with filter removed that canister housing seems easier and less mess to add oil there instead of the usual fill hole. Is that a problem?
2018 RAM 1500ST EXPRESS QUAD CAB 4X4 3.6 VVT 49K miles
2004 Dodge Ram 1500 SLT 4x4 5.7 Hemi 270K miles
2005 suburu outback 200k
2007 Hyundai Sonata 170K
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406130 04/17/20 03:20 PM
Brian553 Offline
With the pentastar prone to cracking the oil filter housing, I would leverage the longest lasting oil filter. For a Fram Xtra Guard, it's still pretty comparable cost-wise at 10k mile intervals. But it's good to know it can go longer.
Re: What filters are you guys using on 3.6 pentastar [Re: Brian553] #5406150 04/17/20 03:39 PM
I was used to extended oil change intervals with my old Ram/Hemi. I averaged 10k and often went to 12ish. But with this newish truck I'll be conservative for now, keeping it at 5-6K. The oil change meter in the truck seems to want it to go 10K but playing it safe.
If the filter housing cracks how would the filter choice make a difference. By filter housing you're talking about this?:
[Linked Image from partsgeek.com]
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406152 04/17/20 03:41 PM
2015_PSD Online Content
Online Content
Use a FRAM Ultra for multiple OCIs which will bring the cost down per filter. With the exception of Mahle all of the other filters I have tried have twisted even though I am torquing the cap exactly.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406153 04/17/20 03:41 PM
Online Content
Yes, he is.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406174 04/17/20 03:58 PM
sloinker Offline
That picture is only showing one seal. IIRC there are 4 seals and an O-ring. Some leaks have been attributed to cracking the plastic housing due to over torque on the filter cap. The adapter I changed on my '14 Pentastar was leaking around the seals. It is a high heat area between the cylinder banks and I am left to wonder if the heat is causing the plastic/seals to dry rot or change at the molecular level. I use the Mopar filter and once I used a K&N. For a 5-6K interval I would find what is cheapest. I bought 4 at a time online from a Chrysler dealer a few years back and they were about $5 each. They seem to go for about $8-9 nowadays. I would just find any name brand that fits and has the lowest cost.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406196 04/17/20 04:16 PM
sloinker Offline
Should be no big deal to fill in the filter housing if it's easier for you while doing a change.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406198 04/17/20 04:19 PM
wwillson Offline
Administrator
Administrator
I'm a big fan of the Fram Ultra, except when I cut them open, the mesh backing makes them hard to cut. The construction if very strong, so I have no problem running the Ultras for extended drains. Just make darn sure you get the correct oil filter, as I've said before here that if you get the filter for the wrong year Pentastar, you will block the oil flow and ruin your engine. The difference is the support neck on the newer style filter vs the no support neck on the older filters (I think the change was in 2014).
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406216 04/17/20 04:33 PM
Thanks for the replies. Since I'm avoiding long drains I'll maybe use the supertech next time and see if it holds up. If I ever go to extended drains
I'll pay the extra buck for the extra guard 11665.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406217 04/17/20 04:33 PM
J
Jimmy_Russells Offline
J
They may have fixed it now but previously almost all the housings eventually leak even if you take care to torque the cap properly. I have a 2014 Wrangler and just swapped it a few months back, not terribly difficult but it's not an easy job either. I have used mainly Napa Golds and torque the cap to 18 ft-lbs.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406221 04/17/20 04:38 PM
Oops. Guess I'm confusing the ultraguard with the extraguard. The ultra is 10.99 at walmart. They didn't have the extraguard.
The xtra guard can be ordered for store pickup 6.99.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406228 04/17/20 04:44 PM
J
J
Apparently Fram Ultra cartridges aren't very good. Just stick with the regular ones (or Mopar or Napa) especially if you aren't doing OCI's more than about 8k.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406230 04/17/20 04:48 PM
H
harbor Offline
H
I’ve had about 10 Pentastars over the years and have always bought bulk Mopar or Mobil 1 filters on eBay at approx $4-5 per filter.
2019 Dodge Challenger AWD GT
2018 Jeep Grand Cherokee
2018 Fiat 124 Spider
2017 Jeep Renegade
Re: What filters are you guys using on 3.6 pentastar [Re: harbor] #5406233 04/17/20 04:51 PM
Good idea.
Re: What filters are you guys using on 3.6 pentastar [Re: stenerson] #5406253 04/17/20 05:08 PM
sloinker Offline
If you are buying in bulk and are willing to pay for shipping you may want to give Rockauto a looksee. Don't forget the 5% discount if you go that direction. From about $2.50 to $10.50 for all the brands they sell.
https://www.rockauto.com/en/catalog/ram,2017,1500,3.6l+v6,3435446,engine,oil+filter,5340
Page 1 of 3 1 2 3
