ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
Scam: Ghana $+2 - US $-2
by pandus13 - 06/02/20 01:09 PM
Motorcycle rear shock rebuild
by Reddy45 - 06/02/20 12:45 PM
2016 Lexus RX350 Oil Change change
by Toros - 06/02/20 12:43 PM
Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
96 registered members (53' Stude, ABN_CBT_ENGR, 4WD, 97prizm, 55hambone, ABCarr, 10 invisible), 2,568 guests, and 62 spiders.
Topics306,062
Posts5,286,660
Members71,593
Page 1 of 4 1 2 3 4
Major Ontario nuclear milestone - criticality #5406047 04/17/20 01:54 PM
O
OVERKILL Online Content OP
OP Online Content
O
Forgot to update the other thread, so I figured this deserves a new one.
On April 7th, 2020, Darlington Unit 2 achieved first criticality since the refurbishment, marking a huge step in bringing the unit back online. Constraints have been lifted for it to start generating electricity, so there has been testing since the 7th performed and I expect to see it come back online quite soon.
My primary interest, now that we know the unit operates, is what its output will level-off at. I expect it will be more than 880MWe, but I could be unpleasantly surprised LOL Unlike Bruce Power, who has stated unequivocally that uprates will be part of their refurbishment and life extension activities, OPG has stated they are not actively looking at increasing unit output. This is only somewhat slightly undermined by the results of a recent maintenance outage a Pickering where a 515MWe unit returned to service at ~540MWe (though it varies a bit).
It's also been confirmed that Darlington Unit 3 won't be going down until the fall now, which means all four Darlington units will be online for this summer. Assuming Bruce 4 and Pickering 1 and 8 are also back up (which they should be, they are down for spring maintenance) we'll have around 12,500MWe of nuclear online to handle the summer peak which means some very low emissions thumbsup
[Linked Image]
Re: Major Ontario nuclear milestone - criticality [Re: OVERKILL] #5406069 04/17/20 02:13 PM
K
KGMtech Offline
K
Clean air electric power is all good. So few mentioned that once the coal fired generators were shutdown, the bad-air days didn't happen? is the correlation accurate?
2017.5 Nissan Rogue SV FWD
2013 Nissan Maxima SV
2009 Ford Flex SEL FWD
1984 Yamaha XJ750RL
Re: Major Ontario nuclear milestone - criticality [Re: KGMtech] #5406084 04/17/20 02:31 PM
O
OP Online Content
O
There's some correlation to be sure, given that some of the coal fired facilities were near the GTA, however much of that smog came from the US too and the transition to natural gas helped there as well. Refurbishing two of the Pickering A units and the refurbishment and reactivation of the 4x Bruce A units was absolutely critical in the elimination of coal, Bruce A alone was responsible for 70% of the power necessary.
Nanticoke could have been converted to gas as another option, which would have been significantly cheaper than the wind and solar FIT and LRP nonsense and we did convert other plants to gas, so it wasn't like it was an impossible undertaking. Of course the other option was to construction Darlington B, which was sabotaged by the GEA. It would be online now I suspect, had it been constructed instead.
Re: Major Ontario nuclear milestone - criticality [Re: OVERKILL] #5406088 04/17/20 02:35 PM
R
Reddy45 Online Content
Online Content
R
The picture is the control rods?
Re: Major Ontario nuclear milestone - criticality [Re: OVERKILL] #5406090 04/17/20 02:37 PM
Danno Online Content
Online Content
When refurbs are done, looks like there are tech advancements that can be applied to increase output and maintain same plant footprint at a reasonable cost
So its a "why not?" question vs a stay the course.
Same with crude refineries. Used to hear we are not building more, oh no !!
Secret sauce is in the ongoing production improvements that takes care of future needs without increasing foot prints.
Seen it happen all day long at my old career in consumer packaged goods.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Major Ontario nuclear milestone - criticality [Re: OVERKILL] #5406095 04/17/20 02:45 PM
skyactiv Offline
Were those plants designed by U.S. engineers? My guess is that the U.S. helped the Canadians design them.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Major Ontario nuclear milestone - criticality [Re: Reddy45] #5406101 04/17/20 02:52 PM
O
OP Online Content
O
Fuel channels. The CANDU is a pressure tube design and due to its use of natural uranium, this was necessary so that it could be refuelled online. There are 480 fuel channels in each of the 12 units between Bruce and Darlington, but Darlington's are newer, and subsequently higher output. The face covered by that blanket is called the Calandria which is full of heavy water and all the pressure tubes and fuel channels pass through it and there are removable plugs on both ends for shuffling fuel bundles in and out.
Re: Major Ontario nuclear milestone - criticality [Re: JohnnyJohnson] #5406104 04/17/20 02:57 PM
O
OP Online Content
O
Originally Posted by JohnnyJohnson
I'm not impressed can you say Chernobyl or Fukushima Daiichi?
That's not a compelling argument. Fukushima was an expensive lesson in not following the advice of the nuclear safety commission (upgrading the seawall) but it killed nobody. Chernobyl isn't comparable to anything currently operating, it had no containment.
Re: Major Ontario nuclear milestone - criticality [Re: skyactiv] #5406106 04/17/20 02:58 PM
O
OP Online Content
O
Nope, they were entirely designed by Atomic Energy Canada Limited (AECL) which is our Federal nuclear development agency. The CANDU was entirely designed in Canada by Canadians and the use of natural uranium was critical, because we had no enrichment capacity at the time.
Re: Major Ontario nuclear milestone - criticality [Re: skyactiv] #5406107 04/17/20 03:00 PM
JohnnyJohnson Offline
Three mile island and Fukushima Daiichi were both designed by U.S. engineers.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Major Ontario nuclear milestone - criticality [Re: Danno] #5406109 04/17/20 03:01 PM
O
OP Online Content
O
thumbsup
Darlington is getting major control and control room upgrades as part of the refurbishment. I expect that the new generator unit and new turbine assembly will increase output despite OPG's claims that they are staying the course. Bruce's target is 7,000MW.
Re: Major Ontario nuclear milestone - criticality [Re: JohnnyJohnson] #5406113 04/17/20 03:02 PM
O
OP Online Content
O
And all TMI did was brick itself.
One of the cool things about the CANDU is that it can be passively cooled by flooding the SG's, so even in the event of a complete loss of all power (Fukushima) the units can be kept cool even with no pumps.
Re: Major Ontario nuclear milestone - criticality [Re: JohnnyJohnson] #5406115 04/17/20 03:04 PM
javacontour Offline
Kind of an apples to oranges comparison. Chernobyl was different sort of reactor design and the were "playing" with it so to speak when they had their accident.
The other aspect of apples to oranges is you need an accident to release ionizing radiation, while a fossil fuel plant releases its poison during the normal course of operation.
network down, IP packets delivered via UPS -BOFH
Re: Major Ontario nuclear milestone - criticality [Re: javacontour] #5406132 04/17/20 03:21 PM
Proven fact is we don't know what the HxXX we are doing with nuclear yet. The only thing that keeps coming to the forefront is known as BS!
2004 Corolla 140116
2006 Duramax 77077
Re: Major Ontario nuclear milestone - criticality [Re: JohnnyJohnson] #5406141 04/17/20 03:31 PM
G
GZRider Offline
G
Nuclear power under strict safety procures like Subsafe is as safe as any other power generation system, the number of steam ships that used to just "blow up" would boggle your mind. Most reactor accidents can be attributed to normalization of deviance, aka human error.
Page 1 of 4 1 2 3 4
