Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
78 registered members (azjake, 2015_PSD, 87sammy, aquariuscsm, Arrechera, 10 invisible), 1,906 guests, and 36 spiders.
Topics306,086
Posts5,287,113
Members71,596
Will this fluid grenade my transmission? #5405883 04/17/20 10:52 AM
A
AntDeek Offline OP
A
Hi Guys,
I was going to do a drain and fill on my 1996 Nissan 200SX SE-R. I bought 4 quarts of Supertech 75w-90. It is a GL-5. My transmission is swapped out of a 1993 and requires a GL-4 at 80w-90. Are GL fluids backward compatible like SAE oils? Will this destroy my synchros? This fluid is compatible with the vLSD in my trans.
Thanks guys.
5MT with an already blown 5th gear, just trying to squeeze as much life out of it as possible.
2013 Ford Edge - 3.5L V6 Ti-VCT
Mobil 1 Extended 5W-20 + Motorcraft FL-500S.
The best oil filter is a good air filter!
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5405898 04/17/20 11:03 AM
J
Jimzz Offline
J
Most GL5 are not aggressive on yellow metals like older fluids and should work fine. With that said still better to play it safe and try to find a GL4 fluid.
This is a good GL-4 fluid that is well reviewed.
https://smile.amazon.com/gp/product/B01MZIHGH3/
yup
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5405922 04/17/20 11:31 AM
MolaKule Offline
Global Moderator
Global Moderator
Understand but some Pennzoil synchromesh or Valvoline synchromesh are GL-4's and would shift much better.
"As engineers [and scientists] we are wired to solve problems and to create new things, to challenge the status quo and push the limits..." Ken Hurt, Embry-Riddle University, Class of '97.
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5405942 04/17/20 11:51 AM
B
benjy Offline
B
my notoriously poor shifting O2J 5 speed in an 01 jetta shifted a lot better with Redlines MT 90, in fact i could barely get it in 5 th gear. it was better after changing + it got even better after a couple of thou which puzzles me! its GL4 by the by
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5405950 04/17/20 12:01 PM
A
AntDeek Offline OP
A
https://lucasoil.com/products/gear-oil/gear-oil/heavy-duty-80w-90-gear-oil
Thanks for the replies. This stuff seems like a safer bet.
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5406057 04/17/20 02:02 PM
J
Jimzz Offline
J
Thats a GL5 fluid like the supertech. No better/worse; so not really safer.
yup
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5406066 04/17/20 02:12 PM
F
Farnsworth Offline
F
How about this one. Delo ESI from Walmart. Meets it all GL4, 5 and MT1. I have some ready to install this summer. Its 80w 90 too.
https://www.walmart.com/ip/CV-DELO-ESI-80W-90/361645283
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5406125 04/17/20 03:16 PM
A
AntDeek Offline OP
A
Thanks for the replies guys. I was looking to do this drain and fill tonight.
This lucas stuff I got seems to be GL4 and MT1 spec as well as the Delo you recommended?
Re: Will this fluid grenade my transmission? [Re: AntDeek] #5406158 04/17/20 03:48 PM
SpitFire6 Offline
RED LINE Synthetic Manual Transmission 90 MT90 75W-90 GL4
2002 206 CC 2L 4Cyl. 0W40 FS
1972 Spit 2L5 6Cyl. 0W40 FS
Re: Will this fluid grenade my transmission? [Re: benjy] #5409384 04/21/20 09:51 AM
David1 Offline
At work I hear nothing but good things about REDLINE Products... also Liqui Moly I hear people rav about it with VW and BMW.. I have customers whom only use Liqui Moly and or REDLINE Products.... Starting with Watter Watter...
2015 Acura ILX
60K miles
Castrol Magnatec 0w20
Re: Will this fluid grenade my transmission? [Re: David1] #5409403 04/21/20 10:25 AM
K
kschachn Online Content
Online Content
K
If you hear "rav" reviews of "Watter Watter" then I'd discount anything else they say after that. A completely useless product for a street car.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
