Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
83 registered members (830Lee, 97prizm, ABN_CBT_ENGR, 4WD, 55hambone, 555, 6 invisible), 2,083 guests, and 33 spiders.
Topics306,053
Posts5,286,514
Members71,593
Page 1 of 4 1 2 3 4
Oil for a 1979 Ford Pinto? #5405848 04/17/20 10:32 AM
SoftLight Offline OP
Hi everyone. I've read some threads here before, and now have joined. smile
I recently acquired a 1979 Ford Pinto with the 2.3 engine (4 speed manual). Miles are unknown (5 digit odometer, no idea if it's flipped over).
What oil should I use? Is an oil high in ZDDP needed?
Thanks.
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405863 04/17/20 10:42 AM
slacktide_bitog Online Content
Online Content
welcome
You can probably use any oil of the correct viscosity with no problem. I'd probably use Walmart brand HM or whatever brand is on sale smile
Re: Oil for a 1979 Ford Pinto? [Re: slacktide_bitog] #5405870 04/17/20 10:45 AM
Originally Posted by slacktide_bitog
welcome
Thanks smile
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405877 04/17/20 10:48 AM
Z
Zaedock Offline
Z
No need for any special oil in the 2.3L. FWIW, I have Supertech 10W40 in my '75 Bronco right now. Most of my Jeep powered toys are running Pennzoil Platinum or QS syns in 5 and 10W30. No extra ZDDP needed for stock engines.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405880 04/17/20 10:49 AM
G
Gebo Online Content
Online Content
G
If possible, I'd try and use what was being used in it. Was it running regularly when you got it?
'98 LEX LS400 310K
'02 4Runner 250K
'05 Lex LS430 90K
'07 Lex GX470 75K
Shell Gas and Truck 5w-30
Amsoil OE 10w-30
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405886 04/17/20 10:54 AM
R
ripcord Offline
R
My uncle gave me a 72 Pinto as my first car. When I got my first real job, I traded it off to a neighbor at 270K miles and he was driving it years later. I'm pretty sure it was never rebuilt and the only thing I knew that was done on the engine was valve guide seals to try to reduce the smoke a bit in the mornings.
I would put any SN rated 10w30 in it with confidence as it's much better than the oil it came with.
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405887 04/17/20 10:55 AM
O
OVERKILL Offline
O
You'll be fine just using an appropriate oil for the climate, probably 10w-30. If you want to be super careful, you could run an HDEO in that grade like Rotella.
Re: Oil for a 1979 Ford Pinto? [Re: Gebo] #5405890 04/17/20 10:56 AM
The person I got it from has no idea what was in it. Basically got it from someone else, and it ended up sitting for a few years. I was able to drive it home.
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405891 04/17/20 10:59 AM
N
NormanBuntz Offline
N
Like several commenters have posted, in CA I'd use a 10w-30 weight in a high mileage synthetic blend. I don't see a benefit or need of full synthetic. And buy a fire extinguisher for that thing!
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Oil for a 1979 Ford Pinto? [Re: OVERKILL] #5405893 04/17/20 11:00 AM
PimTac Offline
This sounds like a good suggestion here. A 10w30 would be my choice.
Any idea if it is burning or leaking oil?
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405911 04/17/20 11:19 AM
F
FordCapriDriver Offline
F
Valvoline VR1 10W-30, affordable, high ZDDP, can't go wrong with that.
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Oil for a 1979 Ford Pinto? [Re: FordCapriDriver] #5405964 04/17/20 12:26 PM
K
kschachn Online Content
Online Content
K
Ah yeah, an $8 a quart racing oil for a 1979 Ford Pinto. Right.
Why not Red LIne at $12 a quart? Wouldn't that be more better?
I mean, you couldn't go wrong with that either.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405965 04/17/20 12:26 PM
E
ecotourist Offline
E
Pintos had problems when struck from the rear, and that is not a rare type of accident. But that may be true for only the earlier model years. And there were allegations at the time that there was a simple fix that Ford had simply chosen not to apply.
All that would be worth looking into. Were they safer by 1979, and if there is a simple fix, could it be retroactively applied to your new car.
And welcome to BITOG by the way.
2000 BMW 528i 5MT M Sport
2007 Honda Accord EX-L 4Door V6 6MT
Re: Oil for a 1979 Ford Pinto? [Re: SoftLight] #5405966 04/17/20 12:28 PM
A
aquariuscsm Offline
A
Pennzoil yellow bottle 10W30.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Pennzoil Platinum High Mileage 10W30
Re: Oil for a 1979 Ford Pinto? [Re: kschachn] #5405969 04/17/20 12:30 PM
A
aquariuscsm Offline
A
Come on guys,don’t be so thrifty! At least use that $20 a quart RP XPR stuff laugh
Page 1 of 4 1 2 3 4
