"I'm not sure they are.
But if they are, it's probably because so much dishonest purchasers remove the Ultra from the outer box and swap it with a Fram Extra Guard box and that means big $$$ savings
If that occurs enough times, the product gets discontinued."
Is that an assumption or an actually stated policy? As has been noted at this thread, the Fram Ultra oil filters sold at Walmart have a tight tape on the box, which is probably done to discourage what you note. In order to break the tape, the box will have a noticeable rip in it.
At last notice, Fram air filters at Walmart don't have the tape. Hence, I've seen Fram non-Ultra air filters in the Ultra air filter box.
