So since we have been a month on lockdown now here in Spain due to the COVID-19 , i've been spending plenty of time in the garage.
So i decided on ordering online a jug of Valvoline Maxlife 10W-40, "Synthetic Technology" , which i have read only is one of the few 50/50 synthetic blands o the market, supposedly 50% Group II and 50% Group III HC ( according to a BITOG type Spanish forum )
Acoording to a VOA on oil-club.ru, although it is from 2015, the European version has a whopping 1600ppm of Zinc!! ( Really ?, more than VR1? ), 1500ppm of Phosphorous and 133 Moly, and 3400ppm of Calcium.
Specifications : SPI SM/SN, ACEA A3/B3 / A3/B4, plus various Renault, VW, MB and Fiat specs, and 5L of it costs 25€ with free shipping, not bad at all.
I noticed it immediately after starting the engine, but definetly after a week it sounds quieter / smoother.
Compared to the 15W-40 HDEO and 20W-50 PCMO i have tried before it definetly seems to run quieter both cold and warm ( Makes sense since 10W-40 is the specified viscosity for the Ford CVH )
On the 15W-40 HDEO it had a lifter that tended to tap at cold idle sometimes, however the tap always goes away once you rev the engine up a bit, and on the Maxlife 10W-40 it doesn't do it at all.
Despite being at 110k miles and being 32 years old it's surprising that it really burns no oil at all, no smoke from the exhaust ever, not even a small puff on cold start, it only has a slightly "sweaty" oil pan gasket, and it dribbles a little oil when you shut the engine off from inside, yes INSIDE the distirbutor, which has a small seal on the main shaft which tends to age and harden causing it not to seal anymore so it always dribbles a drop or two of oil from the distirbutor when you shut it off, strangely enough it doesn't appear to affect the way the engine runs at all.
Video of it running : https://www.youtube.com/watch?v=D94y6fFM4Gw
