Tire Mobility Kits
by wings&wheels - 06/02/20 12:06 PM
Worst accident you've witnessed
by Dave Sherman - 06/02/20 12:04 PM
Shock Fluid
by splinter - 06/02/20 11:21 AM
Michelin X-Ice 4 North for Canada ...
by odie - 06/02/20 11:03 AM
Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
83 registered members (14Accent, 69GTX, ARB1977, 2015_PSD, aquariuscsm, Alfred_B, 4 invisible), 2,355 guests, and 103 spiders.
Topics306,055
Posts5,286,594
Members71,593
Maxlife, good stuff! #5405602 04/17/20 04:07 AM
F
FordCapriDriver Online Content OP
OP Online Content
F
So since we have been a month on lockdown now here in Spain due to the COVID-19 , i've been spending plenty of time in the garage.
So i decided on ordering online a jug of Valvoline Maxlife 10W-40, "Synthetic Technology" , which i have read only is one of the few 50/50 synthetic blands o the market, supposedly 50% Group II and 50% Group III HC ( according to a BITOG type Spanish forum )
Acoording to a VOA on oil-club.ru, although it is from 2015, the European version has a whopping 1600ppm of Zinc!! ( Really ?, more than VR1? ), 1500ppm of Phosphorous and 133 Moly, and 3400ppm of Calcium.
Specifications : SPI SM/SN, ACEA A3/B3 / A3/B4, plus various Renault, VW, MB and Fiat specs, and 5L of it costs 25€ with free shipping, not bad at all.
I noticed it immediately after starting the engine, but definetly after a week it sounds quieter / smoother.
Compared to the 15W-40 HDEO and 20W-50 PCMO i have tried before it definetly seems to run quieter both cold and warm ( Makes sense since 10W-40 is the specified viscosity for the Ford CVH )
On the 15W-40 HDEO it had a lifter that tended to tap at cold idle sometimes, however the tap always goes away once you rev the engine up a bit, and on the Maxlife 10W-40 it doesn't do it at all.
Despite being at 110k miles and being 32 years old it's surprising that it really burns no oil at all, no smoke from the exhaust ever, not even a small puff on cold start, it only has a slightly "sweaty" oil pan gasket, and it dribbles a little oil when you shut the engine off from inside, yes INSIDE the distirbutor, which has a small seal on the main shaft which tends to age and harden causing it not to seal anymore so it always dribbles a drop or two of oil from the distirbutor when you shut it off, strangely enough it doesn't appear to affect the way the engine runs at all.
Video of it running : https://www.youtube.com/watch?v=D94y6fFM4Gw
1975 Ford Capri II Ghia 3000 V6 - 315k, Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - 110k, Valvoline Maxlife 10W-40
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405614 04/17/20 04:51 AM
dlundblad Offline
I wonder how your formulas compares to to ours. 10w40 isn’t A3/B4. I’m not even sure you can get full synthetic Maxlife in 10w40.
10w40 and 20w50 in the blend formulations though. Last I looked, the 20w50 was A3/B3 too.
03 Jeep WJ 4.0 208k
02 Volvo S60 2.4T 199k
97 Chevy Blazer 4.3 175k
04 Audi A4 3.0 210k
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405620 04/17/20 04:59 AM
SR5 Offline
I'm using the Valvoline DuraBlend 10W40 semi-synthetic right now, it would be similar, if not exactly the same as your maxlife. I've always like this oil, as you said, it feels "smooth" for whatever that is worth.
The Durablend is rated API SN/CF, ACEA A3/B4, MB 229.1, VW 502.00, VW 500.00, and I can pick it up at the local Bunnings warehouse at $30 (AUD) for 5L (about 17.50 Euro or $19 USD) which is a pretty good every day price here. And better than half the price of a full synthetic for me.
I've also used the MaxLife 20W50 semi-synthetic (SN/CF and A3/B4) which was a fine oil.
Valvoline do make good stuff, and I've always been told that their semi-synthetics are at least 30% synthetic (Group III) when I have spoken to their tech people (some time ago).
Valvoline DuraBlend 10W40 SN & A3/B4 semi-synthetic + Valvoline V06 synblend media filter
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405630 04/17/20 05:36 AM
T
Triple_Se7en Online Content
Online Content
T
My departed Chevy S10 ran best on the Maxlife Blend 5w30. Did not feel the same when I tried the Full Synthetic Maxlife. Glad you found a winner FordCapriDriver.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405648 04/17/20 06:24 AM
K
krismoriah72 Offline
K
Here is a VOA of maxlife 10w40 high mileage to compare to
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4436195/VOA_Valvoline_Max_Life_High_Mi
Here is a VOA of maxlife 5w40 also done by oil-club.ru also shows high levels of additives..
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4339521/1
i dont read russian but is it possible they use a different numbering system? metric vs standard? their additive numbers always seem really high.
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405653 04/17/20 06:47 AM
Sveina Offline
Isn't these levels not compatible with API SN?
Current: '07 MB E320 CDI 4matic, '06 MB S550, '02 Porsche 996 twinturbo, '01 Dodge Viper GTS 8,1, '03 Peugeot 206 RC (race), '03 Peugeot 206 GTI.
Using Lubrication Engineers
Re: Maxlife, good stuff! [Re: Sveina] #5405684 04/17/20 07:41 AM
SR5 Offline
Yes for an ILSAC viscosity grade eg 0W20 or 5W30. For these there are limits on Phos (and therefore Zinc). Something like 600 to 800 ppm Phos from memory.
No for a non-ILSAC viscosity grade, which are the thicker xW40 and xW50 oils. They can have much higher Phos and zinc levels.
Re: Maxlife, good stuff! [Re: krismoriah72] #5405692 04/17/20 07:53 AM
SR5 Offline
That looks like a typical Euro A3/B4 add pack to me.
High TBN from lots of Calcium detergent (~3100 ppm) and a heavy dose of ZDDP giving ~ 900 ppm Phos and ~1000 ppm Zinc.
Very similar figures to this VOA of M1 0W40 another Euro A3/B4 oil
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/2365762/
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405724 04/17/20 08:36 AM
L
LeoStrop Offline
L
Not sure about those Zinc and Phosphorus numbers, but glad it is working out for you!
I'm also eager to try a Grp. III 10W40 on my oldie, but i'm not sure how it will like it. Have been looking out for some HDEO's like Rimula R6M and Delvac XHP Extra (MB 228.5 is good stuff). How are those options around there for you? Sadly they are not very easy to find, and the majority comes in 20L only.
But since i like to change my oil at 6 months and that barely hits 3k miles, maybe the good and trusty CI-4/SL, MB 228.3 Mineral should be good enough.
Chevrolet Kadett EFI '94 (Neat ethanol) - Shell Rimula RT4X 15W40
Honda Fit '09 (FlexFuel) - Shell Helix HX8 5W30 > Motul 6100 SYN-nergy 5W30
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405768 04/17/20 09:21 AM
F
OP Online Content
F
I almost bought some Shell Rimula R6M 10W-40, it's an extremely good oil.
I've seen UOAs of it on oil-club.ru of 30,40,50.000km and the oil was still ok.
But it's a "true" full synthetic made from GTL and i think even some PAO, and i was scared it would make the engine leak.
It also doesn't carry any Gasoline engine specifications, probably because of the 1.6 Sulphated ash and TBN of almost 15, it also has 1300-1400ppm of ZDDP and over 4000ppm of Calcium, a very heavy add pack.
I've even thought of making a blend of my own with about 50% Rimula R4X 15W-40 ( Mineral, API SL,CI-4 , ACEA E7 ) and Rimula R6M.
My logic is that both are HDEOs from the same brand, Shell, and the same product line, Rimula, so they shouldn't at least in theory have any problems in terms of the additive packages not working together, R4X has a somewhat weaker add pack with 1100-1250ppm of ZDDP and around 2500-3000ppm of Calcium.
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405776 04/17/20 09:24 AM
F
OP Online Content
F
One thing i just realized is that on the site where i bought the oil from it's advertised as fully synthetic, i thought Maxlife 10W-40 was a blend.
On the bottle it says Synthetic technology, but on the datasheet it says it's a blend?
No ofcourse outside Germany , like here in Spain you can legally call a Group III a.k.a HC oil fully synthetic.
So i'm not sure now wether the European Maxlife 10W-40 is a Semi Synthetic, a.k.a a blend, or a Group III HC " so called" full synthetic.
Still i'm happy with how the engine runs with it, significantly quieter and feels smoother than any other oil i have tried.
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405849 04/17/20 10:32 AM
N
NuttCase Offline
N
"Synthetic technology" is a more recent pseudonym for semi-synthetic. So your bottle and data sheet are consistent.
'15 Merc C300 diesel hybrid, Shell Helix Ultra 0W30 ECT C3
'13 Ford Fiesta 1.25, Shell Helix Ultra 5W30AG
'17 Audi R8 V10, Motul 8100 X-Clean+ 5W30
'19 Mini JCW, Shell Helix Ultra 0W30 ECT C3
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405850 04/17/20 10:32 AM
U
user52165 Offline
U
delete - wrong post
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5405900 04/17/20 11:06 AM
L
LeoStrop Offline
L
I am also worried about leaks using it, and it's just overkill for me. Around here, the TDS of the R6M shows 1.9 of SA and a TBN of 15.9!!
https://shell-livedocs.com/data/published/pt-BR/f203c2c6-7c3d-4340-87f2-b37493371421.pdf crzy
To be fair, i have nothing to complain about the RT4 X, works great and i can get it cheap on 4L just 2 min walking form my house. But since temps are always high around here, i was looking for a bit more [email protected] But i end up stuck with the 14,Xcst of the 40s or go for 18-19cst of the 50s.
Maybe my next change i will try 1L of Motul Power 15W50 and 3L of Motul Turbolight 10W40, that would give me 15,87cst.
Around here the Maxlife 10W40 is a blend, but there is no ACEA A3/B4. Only API SM.
I recently saw a VOA of the ELF Evolution 700 STI 10W40 , i was impressed with the 1300ppm of Zinc, 1120 of phosphorus and 125 of moly. The only strange thing was the VI of 201 (14,96cst/ 78,57cst). Maybe can be another good one for you.
https://www.youtube.com/watch?v=FMhyI2YG83A&list=PLNyVE5F6dRv_dqAiMo9jpOpttw1MkKcuh&index=6
Re: Maxlife, good stuff! [Re: FordCapriDriver] #5406039 04/17/20 01:48 PM
H
hemitom Offline
H
not trying to be an a-hole but it sounds like a tractor running..
2009 Saturn Vue.
2015 Mustang GT Convertible.
