Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
103 registered members (azjake, 55hambone, andyd, ammolab, Alain2, 8 invisible), 2,297 guests, and 37 spiders.
Topics306,108
Posts5,286,556
Members71,586
Power washer issues #5405417 04/16/20 07:30 PM
A
ARB1977 Offline OP
A
My craftsman with the Briggs and Stratton will not start unless I use starting fluid. It stays running afterwards. Granted it gets used a handful of times a year. I run my home brew ethanol free fuel since there are no stations around me that offer E0. Took the carb apart and everything was clean. Got it all back together and the same issue. During the winter I spray Amsoil power foam inside the carb as much as I could. The gap is good on the plug. There was slight rust on the fly wheel so i sanded it down. The gap is good for the coil. Is there anything else to check? Thanks.
2015 Tacoma 4.0L 60K (as of 02/23/18)
AMSOIL SS 0W30 / Toyota filter
2018 CRV 1.5L (as of 05/11/18)
Factory fill / Honda filter
Re: Power washer issues [Re: ARB1977] #5405430 04/16/20 07:44 PM
R
ripcord Offline
R
Do you have a good hot spark? Tested either with a spark plug tester, or the plug grounded against the block?
Have you done a compression test? How many PSI?
Is this a model with a choke? Have you taken off the air cleaner and visually confirmed that the choke is closing properly?
Re: Power washer issues [Re: ripcord] #5405448 04/16/20 07:59 PM
A
ARB1977 Offline OP
A
I did bend the arm that opens and closes the choke. I opened it a little more since it was closed before starting. It has the on off switch...easy start, lol. No compression test. I’ll try testing the plug. If the spark is bad why would it run with very little starting fluid? Thanks.
Re: Power washer issues [Re: ARB1977] #5405593 04/17/20 02:38 AM
O
oldhp Online Content
Online Content
O
Gravity fed float type carb? Or carb sitting over fuel tank using a fuel diaphragm type pump? Either way it sounds like your not getting fuel into carb, then after it starts, the engine vacuum sucks in the fuel. Is tank vented properly? Does it have a clean fuel filter? Just a couple of things to throw out there. Good Luck!!!
"None of us are getting out here alive...drink that beer...eat that pizza...drive that Hot Rod"
"When others cut you down, remember where they came from."
"I don't run...........I just quietly wait"
Re: Power washer issues [Re: oldhp] #5405618 04/17/20 04:57 AM
A
ARB1977 Offline OP
A
There’s a big hose that attaches i believe from the tank to the back of the air filter housing. That hose is the case breather. The fuel line is at the bottom to the carb. There is no fuel filter.
Re: Power washer issues [Re: ARB1977] #5405667 04/17/20 07:12 AM
Silverado12 Offline
Make sure the choke is closing. The Easy Start Briggs is a decent setup. You might have old fuel and that can duplicate all kinds of weird symptoms and you'll be chasing your tail trying to find the issue. Also, for as cheap as a spark plug is I would get a new one and make sure the air filter is clear.
12 Chevy Silverado ext. cab LS, 2WD 4.3 auto
18 Mustang GT 5.0 auto
07 Harley Dyna Street Bob 96 c.i. 6 sp.
00 Mustang GT auto
Re: Power washer issues [Re: ARB1977] #5405858 04/17/20 10:40 AM
J
JTK Offline
J
Like said, if it's running and starting perfectly aside from the cold start, I'd look into the operation of the choke.
2019 Nissan Pathfinder SV
2017 Ram 1500 4x4, 3.6L.
2015 Nissan Versa 1.6 S
Re: Power washer issues [Re: Silverado12] #5405915 04/17/20 11:26 AM
A
ARB1977 Offline OP
A
I’ll check those out. I ordered a new needle valve just to rule that out. Before storing it for the winter I dumped the gas that was in there.
Re: Power washer issues [Re: JTK] #5405918 04/17/20 11:27 AM
A
ARB1977 Offline OP
A
I’ll double check the choke. I ordered a new needle valve. Just glad the carb is easy to take a part.
Re: Power washer issues [Re: ARB1977] #5406063 04/17/20 02:09 PM
E
ethnix Offline
E
If it has an auto choke check out this video by Taryl https://www.youtube.com/watch?v=YAqVcdZOZE4 Sometimes critters get in there and and make a nest. Sometimes a spring will rust and break. Sometimes the thermostat which influences the air vane fails (https://www.amazon.com/dp/B0153DMWEU)
Re: Power washer issues [Re: ethnix] #5406100 04/17/20 02:51 PM
A
ARB1977 Offline OP
A
Awesome bud, thank you. Just checked the thermostat and it’s springing back like it should.
Re: Power washer issues [Re: ARB1977] #5410182 04/22/20 09:46 AM
A
ARB1977 Offline OP
A
After changing the needle valve and tweaking the adjusting screw it’s running great again. I did make a boo boo getting carried away on adjusting the choke arm. The lever on the carb side was on the wrong side which made things worse. After taking the top cover off and seeing the operation sure enough.
The next day it started but was running bad and way too rich. I adjusted the carb and it smoothed itself out.
