Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
51 registered members (BLND1, bsmithwins, Aero540T, BrianF, BlakeB, 3 invisible), 1,372 guests, and 31 spiders.
Topics306,113
Posts5,287,769
Members71,602
Old 5hp Briggs fix/improvement - Magnetron #5405327 04/16/20 05:43 PM
N
nascarnation Offline OP
N
I've had a lot of problems the last year with my old (70s) Troy-Bilt tiller. Hard starting and stalling when hot. A lot of time wasted on carburetor rebuilds and cleaning, it appears. Installed the pointless ignition system (Magnetron) which is easy and 25 bucks and it runs like it did 30 years ago. I guess my coil was going bad.
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: nascarnation] #5405333 04/16/20 05:48 PM
Dave9 Offline
I wouldn't consider the carb rebuild and cleaning a waste of time, it probably benefited from that and would've been needed eventually.
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: nascarnation] #5405337 04/16/20 05:49 PM
W
walterjay Offline
W
Glad to hear you got it running good.
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: nascarnation] #5405365 04/16/20 06:26 PM
N
NormanBuntz Offline
N
If you've kept it going for 40+ years, you're doing things right.
Porgy Tirebiter: "Heavy on the 30 weight, Mom."
2017 Toyota Camry XLE, 12K, 2nd owner
2007 Honda Ridgeline RTS, 97K, original owner
2007 Infiniti M35, 115K, original owner
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: nascarnation] #5405515 04/16/20 09:47 PM
J
jeepman3071 Offline
J
I've done this upgrade on a few older Briggs engines, makes them a lot more reliable.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: nascarnation] #5405542 04/16/20 10:38 PM
dinofish Offline
Which oil do you use?
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: dinofish] #5407142 04/18/20 04:21 PM
N
N
It's been a 40 year trip.
Back in the early years Valvoline 20W50 Racing Oil.
Then Mobil 1 15W50.
Then the BITOG legend Castrol green 0W30 until my hoard was depleted.
Lately it's been Mobil 1 0W40.
All these are likely far too good for a Briggs flathead, but they represent what I was using in cars at the time.
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: jeepman3071] #5407459 04/19/20 05:07 AM
L
Lubener Offline
L
I don't know why everyone is against points/condenser. I never had an issue with them. From old farm tractors to small engines, If you store the engine on its compression stroke when the points are closed you likely won't have any issues with them..
The "thinking" man's friend.
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: Lubener] #5407558 04/19/20 08:18 AM
R
RyanY Offline
R
Same for me. Never had any issues with points, but installing/adjusting them requires a little more time than the plug-n-play electronic module. Any extra work or time is generally frowned on in the modern era.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >108k miles; QSUD 0W20 + STP S6607XL
Re: Old 5hp Briggs fix/improvement - Magnetron [Re: RyanY] #5407802 04/19/20 01:10 PM
L
Lubener Offline
L
Yes, work is considered worse than the corona virus.
