Moving up to 5w30. How thick is too thick?
by BTLew81 - 06/03/20 11:15 PM
Renting UHaul Truck to Tow Your Own Trailer?
by Miller88 - 06/03/20 09:40 PM
First Oil Change Recommendation
by gtpimp - 06/03/20 09:20 PM
GM 10L80 Issues
by shimps1 - 06/03/20 08:26 PM
Brake/Carb cleaner issue.
by Jarpin - 06/03/20 07:27 PM
sharp oil pressure drop-off > 130C
by bbrtuning - 06/03/20 06:48 PM
Warranty work
by t1snwrbrdr12 - 06/03/20 06:10 PM
AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
rorty, Ghosty, zmann96, yetti96, weekendwally
71602 Registered Users
53 registered members (BLND1, bsmithwins, Aero540T, BrianF, BlakeB, 4 invisible), 1,373 guests, and 31 spiders.
Topics306,113
Posts5,287,768
Members71,602
Oil color after 100 miles 05 Passat TDI #5405238 04/16/20 04:30 PM
R
ruSSrt Offline OP
R
Hey oil gurus!
Disclaimer: my first TDI, my first EGR equipped vehicle, not my first diesel.
As you see in the picture that is oil color after 100 miles, yes one hundred miles driven on it.
New to me 05 Passat TDI with 190k miles. I have receipts and car fax confirmation that vehicle has been serviced 7k-8k miles at the shop that out Pentosyne oil and OEM filters. Vehicle does not smoke, no blow by, turbo solid. I changed oil with Rotella T6 15-40. And drove total of 100 miles, 50 of it freeway speeds. And that the color of my oil.
I'm comparing it to my 01 Cummins with 110k miles. On Cummins I get that color after maybe 2k miles.
Is TDI run different? Is that because of EGR stuff? Or is it because different oil is now "cleaning" things inside?[Linked Image]
2001 Ram 2500 Cummins
2005 VW Passat TDI
2011 Jeep Liberty 3.7L
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405242 04/16/20 04:36 PM
B
biggusblockus Offline
B
Yes, that is normal. I had a 2012 Jetta Sportwagen TDi that would turn fresh oil black on a trip around the block. And is was serviced at 7k intervals with Mobil One ESP since new.
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405247 04/16/20 04:39 PM
sloinker Offline
Looks like any typical diesel and I've owned a few. If you have a diesel showing clean oil after a couple thousand miles that is highly unusual.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405255 04/16/20 04:53 PM
Chris142 Offline
It will look like that as soon as you start it.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405263 04/16/20 05:00 PM
R
ruSSrt Offline OP
R
it freaked me out for a bit guys! I used to seeing that toward the end of my oil change intervals on my cummins. And on my cummins i do 5k miles on Delvac 1300 (conventional).
This this passat is new to me, i might run 5k and do oil change and maybe do a oil sample test. Just for peace of mind, but my goal is to run 10k on rotella or see if i can get some mobil ESP.
2005 VW Passat TDI
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405297 04/16/20 05:17 PM
J
JimPghPA Online Content
Online Content
J
OP, you are not the first owner of a Diesel to post here on BITOG about finding the oil looking black after a short time of running in a Diesel. It is normal and nothing to worry about.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Oil color after 100 miles 05 Passat TDI [Re: JimPghPA] #5405374 04/16/20 06:34 PM
2
2004tdigls Offline
2
this is common, particularly if you don't drain the oil filter housing, it holds about 0.3 liters of oil. Usually this is enough to make the new oil go black instantly
https://www.youtube.com/watch?v=RN93fWHL6zU
if you drain the oil filter housing your oil might stay "clean looking" for a day or two
LOL
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405400 04/16/20 07:03 PM
A
Audios Offline
A
Same on my ALH, dirty after running for a minute to check the level.
2002 VW Golf TDI-T5 10/30
2007 Mercedes GL320 CDI-T6 5/40
2005 BMW M3 BMW-Twin Power 10/60
2003 BMW M5-M1 15/50
1998 BMW M3/4/5-M1 10/40
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405475 04/16/20 08:47 PM
E
Eddie Offline
E
When I was growing up it meant get to work or get of your butt or quit goofing off. Ed
2014 CX5 Touring 2.5L :-)
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405565 04/17/20 12:04 AM
clinebarger Offline
If your Cummins takes 2,000 miles to turn the oil jet black.....You're changing the oil far to often! My old '97 12 valve's oil stayed clean for about that long after pulling the engine to replace the oil pan & gear case gasket. But after a 8,000 mile run & oil change....It would turn the oil instantly.
Facts of life for a diesel engine, Of coarse....EGR & DPF only cause more soot loading of the oil.
2001 Chevy Camaro L92/4L80E
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405572 04/17/20 12:37 AM
edyvw Online Content
Online Content
Yep. If you lick it, you will taste brand new oil smile
11' BMW 328i xDrive 6MT (Pennzoil Platinum Euro 5W40+ MANN filter)
11' VW Tiguan 2.0T (Castrol 0W30+OE filter)
15' Toyota Sienna AWD (Mobil1 5W30 EP+OE filter).
Re: Oil color after 100 miles 05 Passat TDI [Re: edyvw] #5405574 04/17/20 12:41 AM
R
ruSSrt Offline OP
R
Couldn't actually get a good taste. Had to do a shot of it to make sure it's clean.
2005 VW Passat TDI
Re: Oil color after 100 miles 05 Passat TDI [Re: clinebarger] #5405576 04/17/20 12:43 AM
R
ruSSrt Offline OP
R
Eventually I'll get rid of EGR. But for now I want to determine the base line for the car. Since I just got it.
And yes, I do change oil on my truck often. But not really. I put about 5k miles a year, so I change it once a year.
2005 VW Passat TDI
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405683 04/17/20 07:40 AM
R
ragtoplvr Offline
R
DO NOT USE THE WRONG OIL on VW Diesels. They need the correct vw spec oil because of the weird fuel injection, the wrong stuff will wear the cam shaft.
Rod
Re: Oil color after 100 miles 05 Passat TDI [Re: ruSSrt] #5405696 04/17/20 07:57 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
Fine carbon black soot does that. It doesn’t take much to look fully dark black like ink.
