AC Flashing Light
by artbuc - 06/03/20 05:13 PM
Watches
by Passport1 - 06/03/20 03:57 PM
best budget tire
by VQLT - 06/03/20 03:33 PM
Castrol EDGE turns black/red FAST
by Silver - 06/03/20 03:20 PM
Our van feels "Darty" or twitchy" on the highway
by 1911CHAMPION - 06/03/20 02:55 PM
You guys who pile the miles up weekly on your ride
by Speak2Mountain - 06/03/20 02:22 PM
'19 + '20 Kicks w/C.V.T. : Any owners or know
by odie - 06/03/20 01:38 PM
Securing rubber hose to metal tubing?
by joshuawesl - 06/03/20 01:15 PM
Extremely rare Honda
by wings&wheels - 06/03/20 12:36 PM
Shuffle Dancing
by BlueOvalFitter - 06/03/20 12:19 PM
Do you practice a vegan-keto diet?
by Ed_Flecko - 06/03/20 12:08 PM
Digitizing Photos and Slides
by Snagglefoot - 06/03/20 12:04 PM
Eezox vs Prolix?
by Gebo - 06/03/20 11:49 AM
Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
Ghosty, zmann96, yetti96, weekendwally, Bugsbrewery
71601 Registered Users
98 registered members (4WD, 830Lee, 2015_PSD, 77GrandPrix, 2010Civic, ajchien, 9 invisible), 2,002 guests, and 55 spiders.
Topics306,104
Posts5,287,558
Members71,601
Rounded off bolt help #5404379 04/15/20 07:45 PM
samven Offline OP
I was going to do a transmission fluid and filter change today so I put the truck up on ramps and slid underneath. I took the first 3 bolts out with a bit of trouble because the heads were rusted but the 4th rounded off. After a few choice words I slid out and got my sets of extractors. The first one I tried was an 8mm spline type but it got no bite so I pulled out the flank bite sockets and it rounded worse. I did not let it go all the way over because I could tell it was not going to work so I finally ended up with the reverse twist lock type and that made a perfect round head. I skipped the to rest of the bolts and every single one was rusted and rounding so I just hammered the twist style on and got all of them off but 1 more. I went back and replaced all the bolts with new ones as I worked on the 2 that would not budge. As you might expect I made a mess of 1. I tried cutting a slot in the head for an impact driver and it just made a security screw out of it. You know the kind with a ramp. Then I ground 2 flats on it but I could not get an open end wrench in because of the pan on one side and a flange on the other so I tried clamping vise grips on it nose up and and as expected they just slid around and bugger everything up. Then I ground the head flat and center punched it and tried a left hand drill bit but that did not work and started moving off center so I got the ez outs in the hole and it tore the head off but left the bolt in the hole. I have 1 more to try and get out and thought I would ask if anyone has any ideas that I did not already try on the first. I cant put a torch in there but I did put a big 150 watt soldering iron on the head of the first to get it warmed up, I did not try penetrating oil because the bolts already had a coating of transmission fluid on them from the crap job the dealer did when they changed it last time. They pushed Black permatex into all the threads which is why I think I am having so much trouble. I found a set of reverse biting sockets on Amazon for removing studs and it has 7, 7.2, 7.5 and 7.8 mm but it costs $79. I may just order them. It wont stop me from having to finish drill and plug the first hole but maybe they will get the 2nd one out.
Re: Rounded off bolt help [Re: samven] #5404387 04/15/20 07:52 PM
Z
Zaedock Offline
Z
I don't mean to be rude, but that paragraph is a tough read. If you could edit the post and maybe separate it a bit, I think folks would have an easier time reading it and be able to help you better. I had to re-read it a few times.
From what I can tell, if you have a rounded off bolt and there is room, I would try welding an oversize nut on. The heat from the weld also helps loosen it up.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Rounded off bolt help [Re: Zaedock] #5404398 04/15/20 07:59 PM
M
meadows Offline
M
Weld a new nut on top and take it out with that. The heat also helps to break it loose.
Re: Rounded off bolt help [Re: samven] #5404403 04/15/20 08:02 PM
spasm3 Online Happy
Online Happy
I've welded nuts on sheared bolts before, but not in an aluminum case. i don't know if thats ok. Tig1 or Trav or Clinebarger would know.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Rounded off bolt help [Re: samven] #5404414 04/15/20 08:13 PM
Z
Zaedock Offline
Z
I've welded nut's to broken studs on aluminum heads without issue. Shops do it all the time.
Re: Rounded off bolt help [Re: samven] #5404419 04/15/20 08:20 PM
samven Offline OP
Sorry about the formatting, I tried to use punctuation. I only have a stick welder and a Mig machine but I am worried about the TCU and any other electronics in there. Is there a possibility of frying anything. Thanks. Oh its a Dodge Ram 5-45.
Re: Rounded off bolt help [Re: samven] #5404434 04/15/20 08:37 PM
Z
Zaedock Offline
Z
No man, that's ok. I absolutely understand your frustration. That's a tough repair!
I've zapped nuts on studs with MIG and stick. Stick works surprisingly well. On the Ford 5.4 engines I've done head studs on, I've disconnected the battery as a precaution.
I have used two car batteries using 7018 3/32" rod to repair Jeeps out in Moab. I disconnected the battery in those cases too. In the time I owned a shop, I've never had any computer issues as the result of welding repairs.
Re: Rounded off bolt help [Re: samven] #5404444 04/15/20 08:45 PM
samven Offline OP
Thanks, I will drag the welder out tomorrow. This would not be half so bad on a lift but on your back with the pan 6" above your nose its hard to focus or move.
Re: Rounded off bolt help [Re: samven] #5404485 04/15/20 09:20 PM
Z
Zaedock Offline
Z
At least it will be dry. Most of my off road tomfoolery repairs were done laying on the ground in a puddle.
Good luck getting that sucka out!
Re: Rounded off bolt help [Re: Zaedock] #5404493 04/15/20 09:32 PM
spasm3 Online Happy
Online Happy
There you go!
Re: Rounded off bolt help [Re: samven] #5404615 04/16/20 02:59 AM
J
joegreen Offline
J
Nice at least you have a welder. Most times it seems when bitog suggests to weld on a nut the person doesn't have a welder. I would absolutely weld on a nut. I have done it plenty of times and the heat from welding really helps.
1978 Chevrolet k20
Engine: Delo 10w30xle
Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel
Engine: Delo 400 15w40le
Re: Rounded off bolt help [Re: samven] #5404619 04/16/20 03:09 AM
IMSA_Racing_Fan Offline
Very descriptive story, I liked it. 👍
Re: Rounded off bolt help [Re: samven] #5404634 04/16/20 04:16 AM
Been there. Think of the time investment vs reward of fighting to extract a bimetal corrosion fused rusty bolt. Personally I grind it flush, drill, tap oversize, and go with a larger bolt. Drill the pan hole if necessary.
Re: Rounded off bolt help [Re: samven] #5404642 04/16/20 04:48 AM
T
tig1 Offline
T
I had a oil pan drain plug rounded off(quick lube place) to remove on my sons 2008 Ranger. I welded a nut to the head and it came right out. [Linked Image]
2007 Ford Fusion 258,000 miles
M1 5-20HM
2017 Ford Fusion 91K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: Rounded off bolt help [Re: samven] #5404658 04/16/20 06:04 AM
Should have videoed the excruciating experience lol
