I installed a two post lift into my little hobby garage and I followed the instruction manual to use gear oil for cable lubrication. That was a mistake because the smell of the gear oil is too intensive. I have been cleaning the cables with clean paper rags to get rid of the gear oil and replace it with something more tolerable. What kind of oil I should use to minimize smell?
Also what about hydraulic oil vs ATF. Which one smells more. I used ATF and when I lower the lift I can smell the atf fumes that exit the breather.
