Hailstorm Yesterday
by Delta - 06/05/20 04:47 AM
Date code on Mighty Engine Guard II? Air Filter
by blufeb95 - 06/05/20 01:01 AM
My poor Jetta can't catch a break.
by FordBroncoVWJeta - 06/05/20 12:22 AM
Bought a truck finally, warning no Ford content
by bdcardinal - 06/04/20 11:31 PM
Got a septoplasty today....
by daves66nova - 06/04/20 10:44 PM
2020 330i xDrive Loaner
by MCompact - 06/04/20 10:02 PM
Appliance repair?
by motor_oil_madman - 06/04/20 09:44 PM
Glad we got a seasonal RV site
by Pat in Speedway - 06/04/20 09:19 PM
Mobil 1 AP Clearance at Wal-Mart
by KeithS_NW_Ohio - 06/04/20 09:07 PM
Recent experience with a Michelin Defender
by FordSVTGuy - 06/04/20 08:46 PM
music quality of speakers in the 70's vs now
by raaizin - 06/04/20 08:15 PM
pressure washer care
by raaizin - 06/04/20 08:06 PM
Watch Forums?
by maverickfhs - 06/04/20 07:53 PM
Who has a media/sand blast cabinet?
by spasm3 - 06/04/20 07:39 PM
Why isn't Polyethylene Glycol standard?
by RamFan - 06/04/20 06:37 PM
Motorcraft GF-6 at Quick Lane.
by Gene K - 06/04/20 06:29 PM
OEM Honda wiper blade curvature
by mclasser - 06/04/20 06:24 PM
GDI vs. MPFI OCI's
by LubricatusObsess - 06/04/20 06:19 PM
Mobil “full synthetic”
by 53' Stude - 06/04/20 06:01 PM
1992 Ford Ranger Brake Fluid Type
by yeehaw1960 - 06/04/20 04:21 PM
stubby73, Polkaman, Ramboagain, tekfire07, Kernal
71608 Registered Users
28 registered members (Amkeer, BBC_bias, bachman, CB900F2, chuck172, DaHen, 3 invisible), 751 guests, and 24 spiders.
Topics306,229
Posts5,288,652
Members71,608
Another water heater thread #5404226 04/15/20 05:37 PM
T
Toy4x4 Offline OP
T
Seems like some of us are finally doing things that needed to be done quite a while ago. I had to replace the water heater about 5-6 years ago and have a Bradford White Defender with the swirl feature to help prevent buildup. Well, the heater has been banging and popping for a quite a few months, so I decided to drain it. Not much came out. I saw a video YT explaining putting a larger gate valve to improve drain flow. Upon removing the stock valve, I saw why it was making so much noise (see pics...sorry for the blurry one). I'm still in the process of filling and draining to get the garbage out and have also thought about putting in about four gallons of white vinegar for a day (I have a few pieces of scale in a half cup right now to see how well it works). Some big chunks came out by carefully using a small screwdriver to lift them out. Scale and fine particles are still draining.
Now I'm wondering, is it too clogged?
[Linked Image]
[Linked Image]
[Linked Image]
2007 Toyota 4Runner Ltd V8 Titanium Metallic
M1 0w40
2018 Mustang GT Premium Ingot Silver A10 PP1
M1 5W30
Gone:
1993 Toyota 4x4 3.0 owned 20 years
1969 Chevelle
1989 Civic Si HB
1981 Civic DX HB
Re: Another water heater thread [Re: Toy4x4] #5404248 04/15/20 05:54 PM
J
JohnG Offline
J
That's pretty bad! I'm assuming this is a gas heater?
Anyway, you are loosing a lot of efficiency if it's gas. If it's electric, I'd clean the elements if not replace them. The bottom of that tank will likely get a pinhole pretty soon. It just seems to happen that way when you get that kind of buildup.
Since you are in Arizona, I'd look into heat pump water heaters if I were you. You obviously have very high mineral content in your water. A softener might be in order here as well.
Heatpump water heaters are good for warm climates, not so good for cold places. They heat the water on the outside circumference of the tank, not the bottom. That way any lime/scale buildup won't lower the efficiency as much. Annual cost (yellow tag $264/year).
Re: Another water heater thread [Re: Toy4x4] #5404275 04/15/20 06:07 PM
T
Toy4x4 Offline OP
T
Yes, it is a gas heater and the (city) water is pretty hard. My yellow tag says $242, but since it is only me, It is way lower than that. I'll look into those water heaters. Thanks!
M1 0w40
M1 5W30
Gone:
1969 Chevelle
1989 Civic Si HB
1981 Civic DX HB
Re: Another water heater thread [Re: Toy4x4] #5404325 04/15/20 06:37 PM
B
Boomer Offline
B
One of the reasons I always have a water softener in the house. Really pays for itself in extended life of water heaters, dishwashers, washing machines and plumbing in general. Also, you save on soaps and detergents.
2019 VW Passat 2.0 liter gasoline DI engine, DI, 2,700 miles, Castrol Professional VW 508 0W-20
2017 VW Golf All Track 1.8 liter gas engine DI, 25,500 miles Castrol Professional VW 505 5W-40
Re: Another water heater thread [Re: Toy4x4] #5404337 04/15/20 06:52 PM
T
Toy4x4 Offline OP
T
Water softener is in future plans when/if I get a garage put on. No room right now.
M1 0w40
M1 5W30
Gone:
1969 Chevelle
1989 Civic Si HB
1981 Civic DX HB
Re: Another water heater thread [Re: Toy4x4] #5404344 04/15/20 06:57 PM
snarl Offline
How about going tankless?
1995 K3500 cclb 6.5 turbo diesel running whatever 15w40 is on sale.
Re: Another water heater thread [Re: Toy4x4] #5404383 04/15/20 07:49 PM
W
walterjay Offline
W
Unless you add a water softener, a tankless is not a good idea. I have had to service tankless units that hardly had any flow as a result of the calcium buildup.
I would try an acid soak for a day in the meantime.
Re: Another water heater thread [Re: Toy4x4] #5404390 04/15/20 07:54 PM
G
gregk24 Offline
G
That looks pretty bad. I am going to try and drain out 40 gallon gas Rheem (1 year old) every 6 months. Hopefully that will help with the build up and extend life.
2012 Honda Accord EX-L K24z3
61,xxx miles
PPPP 0w20 / Fram Ultra
2014 VW Jetta SE 1.8T ea888
54,xxx miles
Castrol Edge 0w40 / OEM filter
Re: Another water heater thread [Re: Toy4x4] #5404404 04/15/20 08:04 PM
sloinker Offline
Even a whole house cartridge filter would help. Not a big fan of soft water, tastes funny, don't need the slightly extra sodium for me or the lawn.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Another water heater thread [Re: sloinker] #5404435 04/15/20 08:40 PM
K
kschachn Offline
K
If your outdoor hydrants are connected to the soft water then someone didn't know what they were doing when they plumbed the house.
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Another water heater thread [Re: Toy4x4] #5404443 04/15/20 08:45 PM
R
ripcord Offline
R
So glad to live where the water is baby bottom soft!
Re: Another water heater thread [Re: Toy4x4] #5404456 04/15/20 08:56 PM
Dinoburner Offline
The 1986 Nautilus we have gets a quick flush every time the cartridge filter is change , about every 3 weeks. The tank is a wet base meaning the burner is in a tube above the bottom of the tank so no minerals condense over the burner. Have never changed the anode rod, probably should check it but don`t want to cause a problem.
77 Chev stepside 454 Casteroil syn
95 GMC 4wd mobil syn
2016 Equinox LTZ V6 dealer
Kubota L5030 T6
Re: Another water heater thread [Re: Toy4x4] #5404461 04/15/20 09:00 PM
W
Wolf359 Offline
W
While you're at, try changing out the anode rod. I just picked up some at $13.45 each at supplyhouse.com. Only $13.45 each, but if you're only going to do one, it's probably cheaper on Amazon if you have prime. I bought 8 just to get over $100 for free shipping. (I have 10+ water heaters).
https://www.supplyhouse.com/Rheem-SP11526C-900-x-44-3-8-Magnesium-R-Tech-Anode-Rod
Re: Another water heater thread [Re: Toy4x4] #5404548 04/15/20 10:45 PM
J
JMJNet Offline
J
You just have to put a sharp screwdriver and try to clean that hole as much as you can.
Then replace the valve with something like this:
https://www.amazon.com/House-Mods-HMP010-Heater-Replacement/dp/B074DGWLXZ/
This valve have a bigger opening so all the sediments can come out.
Hook the hose.
Then start the input valve and fill with water heater to stir the sediment and let it drain.
You will need to do it a lot of time with filling and draining the water.
Take off the hose once in a while to make sure it is not clogged.
I just did mine today.
I had to replace the drain valve a few years ago.
The Anode Rod replaced 6 years ago is still good.
  • 2017 Toyota Sienna
Re: Another water heater thread [Re: Toy4x4] #5404552 04/15/20 10:53 PM
P
PW01 Offline
P
[Linked Image]
I installed one of these
2015 Ford Fusion Titanium, Ecoboost 2.0L turbo, Magnetic (metallic gray)
2015 Chevrolet Silverado 1500 Double Cab, 4x4, 4.6L V6, Black
