My daughter's 2008 AWD Fusion with 3.0 V-6 and 130,000 miles is idling rough and occasionally is stalling. Last week she called me and told me it was "bucking" while going through the drive thru and the check engine light came on. First thing I did was check wiring and then the air cleaner. Sure enough there was a large rat nest built in the air cleaner with bird feathers, corn husks and the like. I know it was a rat because a few days before this happened I shot a rat with the BB gun that the dog chased up under the car. It was behind the motor near the firewall and I was very careful not to shoot any vacuum lines off although I second guessed myself when this idle problem started and double checked all the lines........all were good.
I checked the codes and they were P2195 and P2197 which are both O2 sensors which I'm thinking threw the code because it was running lean not getting enough air so the computer was dumping extra fuel causing a rich condition? She normally gets 25 mpg and I checked her odometer settings and she has only been getting 15 mpg. I replaced the plugs with Autolites, installed a new air cleaner, cleaned the throttle body and mass air flow sensor and checked for vacuum leaks. Cleared the codes and runs great. Gas mileage is back up to 25 mpg but still idles terribly and sometimes stalls. I can't even do the recommended idle relearn procedure after cleaning the throttle body as it won't stay running. It "lopes" like it has a big cam in it and if you put it in gear while idling it bucks. I notice that if I put the air conditioning on while in neutral it idles fine so odd it would do that under load. And it does run fine otherwise without a hiccup. Check engine light hasn't come back on yet. Fuel injector go bad? There is no idle air control sensor to replace on these as they are built right into the throttle body. I am thinking this is RAT related!! Any thoughts? Thanks, Scott
