Just did an oil change. Forgot to unscrew the filler cap while draining. Did remove the filter.
Older car, first change, no idea of the amount it should take. Let it drain for about 10-15 minutes. Still had a drip going when I sealed it back up, but also didn't warm it up a lot.
Does not removing the filler cap 'hold' (vacuum) oil in?
Think 10-15 minutes got enough that no real difference exists?
