Fram Titanium 20k mile oil filters at AAP....
by bbhero - 06/05/20 09:04 PM
D-Day πŸ‡ΊπŸ‡Έ
by kstanf150 - 06/05/20 08:57 PM
Husqvarna 5.2 ounce 2 stroke oil .39 ymmv
by maintenanceMan - 06/05/20 08:53 PM
Mobil 1 Permazone
by maverickfhs - 06/05/20 07:47 PM
2 stroke oil
by opus - 06/05/20 06:19 PM
McKinney Falls State Park - Austin, TX
by wwillson - 06/05/20 05:22 PM
Gen 5 Rams (2019+)
by The Critic - 06/05/20 05:03 PM
CarQuest R95140 Cut Open
by HX520W - 06/05/20 04:47 PM
2012 Tacoma steering very stiff?
by wagsrk08 - 06/05/20 04:44 PM
"Quick change" sabotage episode
by Kira - 06/05/20 04:40 PM
Two Motorcraft FL400S Filters Cut Open
by HX520W - 06/05/20 04:36 PM
VIN character that designates engine
by grampi - 06/05/20 04:35 PM
Two WIX 57356XP Filters Cut Open
by HX520W - 06/05/20 04:17 PM
Blue lights on Uber vehicles
by John_Conrad - 06/05/20 04:08 PM
2015 RAM EcoDiesel 3.0L, 5,354mi, M1 TDT 5w40
by SavagePatch - 06/05/20 03:18 PM
2014 5.7 Charger UOA
by Bob D - 06/05/20 02:42 PM
Mazda 3 1.6 DV6C UOA Low TBN Qeustion
by mossietheno1 - 06/05/20 01:59 PM
CRJ-550
by dja4260 - 06/05/20 01:46 PM
Aluminum Welding Question
by George7941 - 06/05/20 01:21 PM
3Dperf, LouK2, Michael328i, tyman, Knot_A_Mekanik
71616 Registered Users
99 registered members (55hambone, 77GrandPrix, 01rangerxl, 10WSmuckers, 2K2AcuraTL, 28oz, 12 invisible), 1,786 guests, and 68 spiders.
Topics306,267
Posts5,289,283
Members71,615
Electric Power Washer recommendation? #5402137 04/13/20 02:54 PM
B
buster Offline OP
B
I currently have one of those Greenwork powerwashers. I've used it for the last 6 years. No issues other than it's underpowered. Looking for a better, higher powered, electric one.
Thank you
2020 - Mazda CX-30 - Mobil 1 EP 0w20
2019 - Subaru Impreza - Dealer Oil
Re: Electric Power Washer recommendation? [Re: buster] #5402166 04/13/20 03:24 PM
Donald Offline
I have a Stanley electric power washer and its fine.
I have not looked at all the models but was under the impression that for more power you needed to go to gas.
2015 Ford F-250 w/Powerstroke
Re: Electric Power Washer recommendation? [Re: buster] #5402171 04/13/20 03:30 PM
The Critic Offline
https://www.harborfreight.com/home-...ance-electric-pressure-washer-56877.html
or
https://www.lowes.com/pd/Greenworks...ater-Electric-Pressure-Washer/1000731280
I am somewhat convinced that all of the <$300 electric pressure washers are extremely similar, but the specs on the Greenworks unit almost seem to good to be true.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Electric Power Washer recommendation? [Re: buster] #5402173 04/13/20 03:31 PM
skyactiv Online Content
Online Content
Since you want more power, electric may not be able to provide that for you. People on here can say my "blah blah brand" is great, but you may not have the same opinion when using it.
I do like the HF recommendation above however.
Me: 18' Elantra Sport 6 speed manual
The rude guy that points out reality
Re: Electric Power Washer recommendation? [Re: buster] #5402175 04/13/20 03:32 PM
W
WhyMe Offline
W
Quality is not cheap
https://www.kranzleusa.com/
Re: Electric Power Washer recommendation? [Re: buster] #5402188 04/13/20 03:42 PM
007 Offline
Get gas if its possible, no comparison!
Re: Electric Power Washer recommendation? [Re: buster] #5402197 04/13/20 03:50 PM
O
ondarvr Offline
O
There are commercial electric power washers that run on 220v, they do a much better job.
I use both, although my gas one died and I'm putting off replacing it. The electric one does an adequate job at about 75% of what needs to be done, and they're quick and simple to use and maintain.
I'll probably upgrade both when a good (significantly
better) product becomes available.
Re: Electric Power Washer recommendation? [Re: The Critic] #5402199 04/13/20 03:51 PM
B
buster Offline OP
B
or
Thanks this is about what I'm looking for. cheers
Re: Electric Power Washer recommendation? [Re: WhyMe] #5402201 04/13/20 03:51 PM
B
buster Offline OP
B
Definitely nice but overkill for my needs. smile
Re: Electric Power Washer recommendation? [Re: buster] #5402232 04/13/20 04:17 PM
K
krismoriah72 Offline
K
I have the Ryobi version of the Harbor Freight/Greenworks one. Same price at $199
https://www.homedepot.com/p/RYOBI-2-000-PSI-1-2-GPM-Electric-Pressure-Washer-RY141900/205566055
It does all that i ask of it.. its main chore is removing heavy clay mud from my sidebyside after every ride. It also has pressure washed my deck once and has cleaned my personal vehicles probably 40 times.
Only had one issue that the wand burst a fitting and thats because i left it outside during a freeze. My fault.
I use Tide in the soap dispenser for mud.. seems to do well.
Re: Electric Power Washer recommendation? [Re: buster] #5402347 04/13/20 06:11 PM
spk2000 Offline
I have found anything Greenworks tends to be somewhat overrated on power based on experience with similar products. I have an older Milwaukee 14.4 hammer drill that is way more powerful than my Greenworks 24V drill and even the impact driver. They claim higher torque specs but in reality my old Milwaukee will snap heavy lug bolts off when driving into a deck. Not a chance with the Greenworks.
I also have a few of their yard tools that work fine for light maybe medium duty residential use. Tried retiring my 22 year old Makita weedeater but found it was still better than a 40V Greenworks. The 40V polesaw works fine for trimming trees around the house but definitely not a commercial product.
Also I have used several electric 110V pressure washers and they are fine for smaller light duty jobs but take too much time and effort for larger jobs. I do like that they are quieter than gas though. Would be good indoors too where you would not want gas exhaust fumes building up CO.
96 Grand Marquis 203,000 mi
01 Sable LS Wagon 163,000 mi
02 Montero 191,000 mi
03 Sable LS Sedan 73,000 mi
Re: Electric Power Washer recommendation? [Re: krismoriah72] #5402413 04/13/20 07:47 PM
B
buster Offline OP
B
Thanks. I have had good luck with other Ryobi products.
Re: Electric Power Washer recommendation? [Re: buster] #5402430 04/13/20 08:00 PM
sloinker Offline
I just retired my Karcher electric and replaced it with a gas DeWalt. Not sure why I waited so long. Night and day difference.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Electric Power Washer recommendation? [Re: buster] #5402499 04/13/20 09:44 PM
R
Rand Online Content
Online Content
R
The greenworks is definitely over-rated/fake specs.
2300 MAX PSI at 1.2 GPM, 2.3 GPM MAX at 100 PSI
but they will rate it 2300psi 2.3gpm max.
They can only do so much on under 15amps of 120v
look for usable hose reel, stable platform and around [email protected] is about it.
Re: Electric Power Washer recommendation? [Re: buster] #5402501 04/13/20 09:46 PM
J
joel95ex Offline
J
i just bought a ryobi electric and it made my 20 yr old wood fence look new. whatever you get, buy the "pump saver" lube to flush out the water after use.
95 Accord 4cyl Vtec. 500,000+miles. RIP 😒
13 sonata killed by a deer @ 156k miles
07 civic SI 179k miles PP, M1 10w-30 fram ultra
18 santa fe 55k PP 5w-30 oem filter
