Walmart closing all Tire and Lube Express in Canada
by tenderloin - 06/03/20 10:38 AM
Seeking Exterior Home Aesthetic Advice (UPDATE!)
by DriveHard - 06/03/20 10:22 AM
Do you have your home HVAC system maintained?
by E150GT - 06/03/20 09:21 AM
Mixing vavoline & mobil
by ThePCMasterRace - 06/03/20 09:03 AM
Pre-Oiler?
by AJB0009 - 06/03/20 09:02 AM
1992 Acura NSX, Red Line 10W-30, ~1400 miles/1 year
by robertcope - 06/03/20 06:37 AM
Rural telephone boxes along road
by dlundblad - 06/03/20 05:06 AM
Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
93 registered members (830Lee, 2_Tall_Mitchell, 53' Stude, 2010Civic, 1911CHAMPION, ABerns, 4 invisible), 2,011 guests, and 66 spiders.
Topics306,089
Posts5,287,239
Members71,596
Page 1 of 3 1 2 3
Thicker oil in my Jeep. #5402111 04/13/20 02:32 PM
M
Micahmcmeen Offline OP
M
I've been considering running a thicker oil in my jeep to help with burning and to help it run smoother. I am just very hesitant to do so but I have added lucas to it in the past and it did help with the oil burning. I understand lucas is "snake oil" and has almost no additives and is changing my viscosity and weight anyways. It take 5w20 currently. I used to put about a 1/4 a quart of the lucas in. What viscosity and weight do you think that would make it after that?
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402114 04/13/20 02:33 PM
R
Rand Offline
R
use 5w30?
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402118 04/13/20 02:40 PM
PimTac Offline
There was a thread recently on this very subject.
https://www.bobistheoilguy.com/foru...cas-modern-engine-stabilizer#Post5382408
Oh wait, you started that thread too.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402130 04/13/20 02:50 PM
B
bullwinkle Offline
B
Which Jeep? The XJ in my sig really likes 10W40 MaxLife, but a newer one might like something a little thinner. MaxLife is still hard to beat, though.
06 Ram 3500 CTD 4X4(FG Venturi), 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7 (MC), 03 Merc Grand Marquis 4.6 2V(XG2), 11 Express 3500 6.0 (Fram PH10060 for now)
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402148 04/13/20 03:05 PM
Chris142 Offline
What year is the Jeep? The 3.8 can use 5w30 and even a 10w30 as it is an old school push rod engine.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402154 04/13/20 03:07 PM
demarpaint Offline
Try 5W30, and recycle the Lucas.
God Bless Our Troops
Re: Thicker oil in my Jeep. [Re: PimTac] #5402160 04/13/20 03:21 PM
M
M
Yeah, the purpose of that thread was something different. If you don't have anything to add please don't comment. If my posts bother you then don't look at them. A lot of people are stuck at home right now. I know I've gotten on here more than once for some sort of entertainment. Might as well post something to keep others entertained too.
Re: Thicker oil in my Jeep. [Re: Chris142] #5402161 04/13/20 03:22 PM
M
M
2010 jeep commander 3.7 with 180,000
Re: Thicker oil in my Jeep. [Re: PimTac] #5402170 04/13/20 03:26 PM
B
BAJA_05 Offline
B
LOL
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (42K)
2008 Acura TL 3.2L PPHM 0W20 & FU (117K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402179 04/13/20 03:34 PM
O
OilReport99 Offline
O
Don't cut corners and go full 20W-50. Used it a lot in my old 4.0 L to make it run "smoother". Good luck.
2018 Ram 1500 - VME 5W-20
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402192 04/13/20 03:48 PM
PimTac Offline
Sounds very familiar. Must be tiring to keep reincarnating.
2017 Mazda CX5
Roki OEM filter.
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402213 04/13/20 04:03 PM
Chris142 Offline
That same basic engine goes way back. 5w-30 and 10w-30 were ok in it in the past.
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402215 04/13/20 04:05 PM
Z
Zaedock Offline
Z
I would skip the Lucas and run Supertech HM in the 5W30 flavor and call it good. No need to add/dilute an add pack.
2019 Escape EB AWD/2016 KIA Optima SXL 2.0L Turbo/2012 F150 Ex-cab 5.0L
1992 YJ "The Heep"/2015 Chrysler 200 Limited
1975 Ford Bronco/1959 Willys CJ5/Tube Rock crawler
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402217 04/13/20 04:07 PM
T
Triple_Se7en Online Content
Online Content
T
A more upper-range viscosity 5w30 could help. Quaker State Ultimate and Rotella Gas Truck are about the thickest in 5w30. I think both are well over 11 cst @ 100. Or you can travel over to a Dexos 2 in 5w30 and get Mobil-1 ESP or Rotella T6 Multi-Vehicle. Both would serve that 2010 model well too.
2019 Hyundai Santa Fe 2.4 GDI - Pennzoil Ultra Platinum 5w30 / OEM 35504 Filter
2020 Kia Soul X-Line 2.0 MPI - a 50-50 blend of Pennzoil Platinum HM & Pennzoil Gold 5w30 // AC Delco PF1127 Ecore
Re: Thicker oil in my Jeep. [Re: Micahmcmeen] #5402237 04/13/20 04:27 PM
K
kschachn Offline
K
Or on the other hand, are you one of these posters that never actually takes any of the advice and applies it (as in buying and using an oil) instead just perpetually ask questions?
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Page 1 of 3 1 2 3
