Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Haywood, ToOliwer, AbbeyRoad, RPF, Rayi
71586 Registered Users
102 registered members (Astro14, 5AcresAndAFool, 77GrandPrix, Alfred_B, 2015_PSD, 2010Civic, 7 invisible), 2,238 guests, and 36 spiders.
Topics306,108
Posts5,286,590
Members71,586
Page 1 of 3 1 2 3
Stongest Filter Body? 💪 #5401905 04/13/20 11:33 AM
SavagePatch Offline OP
I have a Champion 27ton Log Splitter. The hydraulic oil filter is a spot that makes it vulnerable to being hit by split logs and is also facing upwards.
What's the oil filter with the strongest body? I remember the Royal Purple being pretty beefy but they don't make one for this application. The K&N seem like a close second. What's your thoughts?
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401910 04/13/20 11:39 AM
JohnnyJohnson Online Content
Online Content
Pictures might help.
2004 Corolla 140116
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77077
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Stongest Filter Body? 💪 [Re: JohnnyJohnson] #5401925 04/13/20 11:46 AM
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401928 04/13/20 11:48 AM
J
jeepman3071 Offline
J
Wow that's a terrible design. I'm surprised it isn't turned 180 degrees so the filter isn't in the flight path of falling logs.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (61k) - Liqui Moly 5w40, MANN HU816X
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401932 04/13/20 11:50 AM
PimTac Offline
Maybe a box made out of plywood or something that would slip over that while you are using it?
That’s a poor place to have something like that.
2017 Mazda CX5
Mobil 1 Annual Protection 0w20
Roki OEM filter.
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401953 04/13/20 12:06 PM
Online Content
Wow now that's some real engineering isn't it LOL
2004 Corolla 140116
2006 Duramax 77077
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401961 04/13/20 12:12 PM
J
JimPghPA Online Content
Online Content
J
The Mobil 1 filters I have used in the past feel like the steel is very solid / thick, and there was recently a post here on BITOG where someone cut some filters and commented that the Mobil 1 filer had a thicker case and thicker anti drain back valve by far compared to the other filters he cut.
But a thicker steel case still might not be enough from what I see in your picture. I would rig some kind of protection.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Stongest Filter Body? 💪 [Re: PimTac] #5401963 04/13/20 12:15 PM
I agree, that's the idea I had. With a strong filter housing as a back up.
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401968 04/13/20 12:18 PM
K
Kage860 Offline
K
The purolator BOSS was supposed to be an oil filter with an unusually thick can.
2007 Jeep Liberty PP 0w-20 / Carquest Blue, 6k oci
2015 Nissan Rogue PP 0w-20 / Pronto, 5k oci
2019 Audi Q7 - Castrol 5w-40 / OEM Filter
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401981 04/13/20 12:33 PM
Driz Offline
That really is a 💩 design. Can you weld? If it was me I’d hit the scrap yard and grab a hunk of steel plate 1/8” or so and fab up a shield for that filter. Better yet can you relocate it to someplace safe like underneath towards the rear? That would be by far best though you’d possibly need to make up a small bolt on bracket of sorts. You’d have to mind your other clearances under there for moving it about but it would be much safer from log impact than flyin in the breeze like it is.
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401985 04/13/20 12:37 PM
PimTac Offline
I think I would concentrate on protecting the filter. No matter the thickness or sturdiness of the body, if a large chunk of wood hits it right the problem would be down at the base. The filter baseplate could come loose from the body or the force could damage the base itself due to the lateral force, especially if the wood hits the filter higher up.
2017 Mazda CX5
Roki OEM filter.
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401988 04/13/20 12:39 PM
U
Ursatdx Offline
U
Might be best to relocate the filter.
Add a section of hydraulic hose from the reservoir and mount the filter
next to the pump under the I beam.
"If there must be trouble, let it be in my day, that my child may have peace." --- Thomas Paine
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401990 04/13/20 12:40 PM
Donald Offline
If you can find a Bobcat hydraulic filter that fits that would be your best bet. They are tough enough that you cannot cut them open with a filter cutter. But expensive.
2015 Ford F-250 w/Powerstroke
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401991 04/13/20 12:41 PM
K
kstanf150 Online Content
Online Content
K
Can’t tell from looking at the picture, but Is it possible to
relocate the filter?
If not the M1 filter is for sure the strongest can of off the shelf brands
Re: Stongest Filter Body? 💪 [Re: SavagePatch] #5401993 04/13/20 12:41 PM
Donald Offline
With heating oil under $2/gallon does it make sense to cut and split wood? (For more than a romantic fire in the fireplace).
Page 1 of 3 1 2 3
