Rockauto code expires 8/2
by gallydif - 06/02/20 08:19 AM
The worst job you ever had?
by Chris142 - 06/02/20 08:04 AM
P218F on my Ford PSD
by Donald - 06/02/20 06:34 AM
Kudos to Griot's
by Egg_Head - 06/02/20 05:43 AM
Exide Battery files for bankruptcy
by Randol - 06/02/20 04:34 AM
Just one more wax question.
by rrretiree7 - 06/02/20 01:49 AM
Removing stuck bolts- interesting technique
by rubberchicken - 06/02/20 12:47 AM
Unless it is a misprint?
by 340_Magnum - 06/01/20 10:25 PM
Raymond Weil 5590 Watch Battery Replacement
by maverickfhs - 06/01/20 09:22 PM
Echo SRM 230 idling high
by CDX825 - 06/01/20 08:40 PM
Walmart in Canada closing Lube and Tire Express
by Snagglefoot - 06/01/20 08:26 PM
2012 Sonic - LCA puck bushing
by Number_35 - 06/01/20 06:44 PM
Rotate mags?
by marine65 - 06/01/20 06:40 PM
Re-using good coolant?
by Jarpin - 06/01/20 06:21 PM
Best entry level riding mower
by UncleDave - 06/01/20 03:02 PM
2015 Pilot LX
by madRiver - 06/01/20 03:01 PM
NewMex, RandyN11049, bbrtuning, chapys, DaaBoss
71593 Registered Users
77 registered members (1978elcamino, 2015_PSD, alchargo, AndyB, akh, 53' Stude, 9 invisible), 1,926 guests, and 27 spiders.
Topics306,053
Posts5,286,477
Members71,593
2012 L96 6.0L Vortec Oil Choice #5401558 04/12/20 10:16 PM
H
HeritageHighRoof Offline OP
H
I recently acquired a 2012 GM 1-ton van with the 6.0L engine, 90K miles and 1900 engine hours. Don’t know the history of oil change frequency or type, but will be replacing leaky oil cooler lines soon and want suggestions on a good oil to run moving forward. Manual recommends Dexos 5W30 but I’m on the fence about using up some basic Chevron I got from Costco or going to synthetic 0W30 since I sometimes see -40° temps and will be towing heavy loads occasionally (10K pounds).
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5401567 04/12/20 10:39 PM
Danno Offline
I would use a block heater with a Wolverine 150W oil pan heater for winter stars, and use 5W-30 Dexos
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5401577 04/12/20 11:16 PM
G
GMguy84 Offline
G
I STRONGLY recommend Rotella Gas truck 5W30 it's dexos certified Its full syn and made for your needs also you Might get lucky and find some remaining at Autozone for $2 a qt on clearance thumbsup And to top it off there is a $10 rebate on top also thumbsup
or if you have a Tractor supply neear by they have Mobil 1 Truck/SUV @ Tractor supply for $15 a 5qt jug on clearance
Dave
[Linked Image]
01 Silverado 1500HD Shell RGT 5W30/XG3675
07 Suburban 1500 Mobil Super Syn 10W30/XG10060
82 Trans Am (KITT) M1 10W40HM/XG5
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5401621 04/13/20 02:22 AM
U
userfriendly Offline
U
Low hours for 90K miles. We have one 2016 2500 6.0L that runs around a pulp mill that has 33,000 miles and 6800 hours. The one I drive once in a while, mostly around a rail yard (2017 6.0L) has 3x the miles and less than half the hours. I witnessed the 16 with no oil pressure at -38F one morning using 5W30 Dexos. I found the cheapest solution is either 5 gallon pails of T6 0w40, or 5 liter jugs of M1 FS Euro 0w40 on sale. Mobil Delvac 0w40 would be a good year round oil for your 6L, but it's not cheap.
At 90K miles & 8 years old, time to do the transmission, diff, power steering and brake fluid.
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5401707 04/13/20 07:42 AM
Snagglefoot Online Content
Online Content
I have a 2008 6.0 that reached 200,000 miles using various brands of 5w30 synthetic motor oil. It still does not consume oil between changes.
This winter I used Pennzoil Platinum 0w30 Euro LX and for the summer will probably be going to a 5w40. I noticed the oil pressure during idling is a bit lower than when it was new. The oil pressure at highway speed is the same as new.
With your mileage I would just run Dexos 5w30 year round or 0w30 in the winter if you do a lot of cold starts. smile
If you want the job done right......do it yourself.
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5401774 04/13/20 09:15 AM
SteveSRT8 Offline
We use 3500 Express/Savanas at full gvwr (9700 pounds) in a hard duty cycle. These 6.0 engines routinely reach high mileages. We use whatever syn is on sale, follow the OLM.
I have an 06 in my lot with 228k miles on her that still runs great and does not leak or consume oil.
5W-30 is great for these trucks. Note that GM runs all trans fluid and engine oil into the radiator so everything gets nice and hot. Keep your stock t-stat!
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
Re: 2012 L96 6.0L Vortec Oil Choice [Re: GMguy84] #5402484 04/13/20 09:16 PM
H
H
Thanks for the info. Unfortunately, my local Autozone has no Rotella Gas Truck oil left. I think I’ll use Kirkland Dexos 5w30 for now. Really love this powertrain combination. I got a hand calculated 18.3 mpg taking it easy on my mostly rural commute last week.
Will be changing all fluids soon. Need to check for coolant leak, as I sometimes smell coolant when engine is hot.
Re: 2012 L96 6.0L Vortec Oil Choice [Re: HeritageHighRoof] #5410535 04/22/20 05:41 PM
Z
zfasts03 Online Content
Online Content
Z
I would run a 0w-30. Such as Mobil 1 0w-30 or Amsoil 0w-30.
Also would be nice to heat the oil pan and transmission pan, also a battery blanket and you should be good to go.
Also if you have any grease fittings? Tie rods, etc. Grease w/ a grease that is rating for low temps.
- 03 Corvette Z06
Amsoil 5w-30 SS
- 07 Honda Accord 2.4L
Amsoil 5w-20 SS
- 16 Suburban 5.3L
Amsoil 0w-20 SS, XG10575(16-28 by-pass)
- 18 4Runner TRD Off Road
Amsoil 0w-30 SS, TRD filter
