2017 RAM 2500 6.4 Hemi AMSoil and PUP
by Gondul - 05/28/20 07:50 PM
Nail in tire, what would you do?
by Brybo86 - 05/28/20 07:44 PM
Any decent lap tops for $200.00 or less?
by BAJA_05 - 05/28/20 06:49 PM
New PW with Honda 190 engine - Ethanol treatment?
by DirtyApe - 05/28/20 06:38 PM
What size tube should a 110/50-6.5 Tire use?
by taztheman - 05/28/20 06:14 PM
C&P Allison Transmission Filter - 27k miles, 3 years
by shibby6600 - 05/28/20 05:51 PM
XG9100 - 7k miles - 9 months - filter magnet
by shibby6600 - 05/28/20 05:47 PM
2017 Audi A4 PCV Valve replacement
by dbias - 05/28/20 05:23 PM
Audi E-Tron Technik
by OVERKILL - 05/28/20 05:12 PM
Deer 1....My Avalon 0
by ZZman - 05/28/20 03:21 PM
Auto Dealers Supplies?
by cknight49090 - 05/28/20 03:09 PM
interesting video reg vs premium
by raaizin - 05/28/20 02:55 PM
Discount Tire Direct FLASH SALE
by Mr Nice - 05/28/20 02:42 PM
2021 Acura TLX Sports
by buster - 05/28/20 01:36 PM
Honda GC vs GS engines?
by Avery4 - 05/28/20 01:10 PM
Advanced auto parts
by Fitter30 - 05/28/20 12:52 PM
Is there a best time to switch to synthetic oil?
by Jgelack - 05/28/20 12:37 PM
Alignment good then bad
by Barkleymut - 05/28/20 11:56 AM
What's in the Box?
by BeerCan - 05/28/20 11:31 AM
Kboggs, oldcodger, cwllams1, Danwrig, DanielR
71558 Registered Users
90 registered members (14Accent, Alfred_B, 2_Tall_Mitchell, aba4430, 2002 Maxima SE, 55hambone, 13 invisible), 2,240 guests, and 33 spiders.
Topics305,992
Posts5,284,297
Members71,558
Hard deposits on spark plugs, pre ignition? #5399510 04/10/20 04:24 PM
T
Therealdusky Offline OP
T
Hi guys!
Changing headers on my Chevy SBC and desided to do a comp test while at it. ( all 8 cylinders at 200 psi, so happy me)
Anyway, found some hard deposits on some spark plugs. And I wonder what it could be. I do run a lead additive so might have overdosed on that ? I also changed the distributor , running 36 degrees all in at 2500 rpm.
Those are the only changes I made between putting these new plugs in and now.
Running NGK BP6FS plugs.
The old plugs didnt have this problem ( AC DELCO RT45) .
I know that the plugs look very very black here, but that's 99% sure because I just ran the engine for 40 seconds to drive it up the ramps on choke. ( dont think its oil burning, no smoke and no oil consumption)
Happy to hear your thoughts. I was thinking it might be overheating the plugs or pinking ( wouldn't hear it in this car, it's too [censored] loud) .
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399515 04/10/20 04:29 PM
T
T
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399533 04/10/20 04:49 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by Therealdusky
Hi guys!
...Changing headers on my Chevy SBC and desided to do a comp test while at it. ( all 8 cylinders at 200 psi, so happy me)
Those are the only changes I made between putting these new plugs in and now. ..
Octane Booster deposits.
Is the fuel of such low octane that you need a booster? Are you racing this engine?
Your oil is probably loaded with the Octane Booster.
Dr. Larry Fleinhardt: "You know, that term "dark matter" has always perplexed me. It fallaciously implies that the 95% of our universe that cannot be observed is some amorphous, eventless emptiness."
Amita Ramanujan: "I'm sorry?"
Dr. Larry Fleinhardt: "I guess it's all too human. Instead of admitting to the present limits of our knowledge, we just declare things to be unknowable." NUMB3RS
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399584 04/10/20 05:49 PM
B
Blkstanger Offline
B
I used to run octane booster in a Harley I built with higher compression. I always had those deposits when I changed plugs. Never had the deposits before the additive.
99 Jeep WJ 4.7 200,000mi. Maxlife 10w30, Fram Ultra.
15 Ford Escape S 2.5, 75,000mi. Castrol Edge EP 5w30 Fram Ultra.
Re: Hard deposits on spark plugs, pre ignition? [Re: MolaKule] #5399591 04/10/20 05:58 PM
T
T
Hi guys!
Interesting!
The lead replacement is Castrol valve master plus, wich indeed is an octane booster too. I just use this to be on the safe side because I'm running a high ignition advance (afaik) and it buys me some safe zone when I let the car sit for longer periods of time.
Now that you mention it, I did only recently start using this brand. Maybe better to use a different one?
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399684 04/10/20 07:27 PM
2
2004tdigls Offline
2
that looks like overfueling a "wet" plug
https://www.championparts.ca/Parts-...maintenance/how-to-read-spark-plugs.html
also could be caused by a really large cam with overlap
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399702 04/10/20 07:49 PM
sloinker Offline
Too rich. You say your old plugs didn't do this so I would go back to them and check to see if the problem mitigates by using them. Hard to believe a plug heat range could cause this much rich fouling.
'16 Tiguan TSI Vaico 5W40
'15 VW Golf TDI Red Line 5W30 Euro
'15 VW Golf Sportwagen TDI M1 ESP 5W30
'14 Dodge Grand Caravan 3.6 Valvoline 5W20 Semi Synthetic
'64 Plymouth Fury440 Pending
Re: Hard deposits on spark plugs, pre ignition? [Re: sloinker] #5399743 04/10/20 08:32 PM
T
T
Just From the choke I think. Engine hadn't run for 5 weeks and then just ran 30 seconds to get it up the ramps.
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399928 04/11/20 06:28 AM
A
Amkeer Offline
A
Too rich and under torqued plugs. I would ditch the additive, put new plugs in.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 107000
2008 Toyota Tundra D Cab 5.7 M1 5-20 100000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 220000 miles
2020 Toyota Camry SE 2.5 600 miles
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5399989 04/11/20 08:01 AM
A
ARCOgraphite Offline
A
You don't even TRY to read plugs after idling a car up on ramps wit the choke on.
Fully warmed a couple WOT runs , key off engine at end of third WOT run in third gear.
Let cool, then read plugs. You should know which too cylinders are the lean and rich running - just pull those.
Now, What carb, how is the carb jetted what powervalve ( Holley)
Tell us more about the engine. Cam, heads, static compression, distributor ( hope it's a DELCO HEI )
I see you have later vortec heads with peanuts - is this a 90's Caprice by any chance?
If it's high comp you should'nt need 36 deg all-in at 2500 rpm! More like 34 all in at 3200-3500, esp on the vortec.
Ar you running vacuum ported vacuum advance and how much?
And ditch those NGK and run Champion or ND or standard copper Bosch.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#9 70254mi-Rotella
Gas Truck 5W20 + Fram Ultra 7317 Filter
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5400018 04/11/20 08:39 AM
dnastrau Offline
Hi guys!
Anyway, found some hard deposits on some spark plugs. And I wonder what it could be. I do run a lead additive so might have overdosed on that ?... .
You are running a lead additive? What year is your small block Chevy? For the 1971 model year, all GM passenger car and light truck engines in the US (and probably Canada) started using induction hardened exhaust valve seats and compression ratios of no more than 9.0:1 to accomodate the new 91 RON (marked as 87 R+M/2 in the US and Canada since the mid '70s) low-lead and unleaded fuels. No lead additive is needed on those engines. If the engine is a '71 or newer and is stock, you probably don't need any octane booster either. Isn't gasoline is Belgium either 95 or 98 RON (roughly the same as current 91 or 93 R+M/2 fuel in the US and Canada)?
Andrew S.
Re: Hard deposits on spark plugs, pre ignition? [Re: ARCOgraphite] #5400218 04/11/20 12:41 PM
T
T
Why under torqued?
I was not trying to read the plugs, just took them out for a compression test because it's so much easier to remove them with the headers removed.
The base of the engine is a 4 bolt goodwrench, with ported 416 heads on. Cam the lunati equivalent of the comp 268.
I run vac advance, IIRC its manifold vacuum, 8 degrees. Compression is 10.5:1
Running a MSD HEI.
Re: Hard deposits on spark plugs, pre ignition? [Re: dnastrau] #5400220 04/11/20 12:43 PM
T
T
Hi guys!
Andrew S.
Thing is, I dont know how old these 416 heads are. Mind, they had valve work done so 99% sure they have unleaded seats.
Indeed, Only use 98 ron from Shell ( which has no ethanol in it - for now).
Cheers
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5401035 04/12/20 10:39 AM
dnastrau Offline
Hi guys!
Andrew S.
Cheers
Aren't "416" heads originally found on the 305 HO engines from the 1980s? They should already have induction hardened exhaust valve seats from the factory. No lead additive needed - you should be fine.
Andrew S.
Re: Hard deposits on spark plugs, pre ignition? [Re: Therealdusky] #5401217 04/12/20 01:55 PM
A
A
Why under torqued?
Running a MSD HEI.
Decent combo, never run 305 smog heads, small chambers can shroud the intake but give good tumble.
I like the only 8 deg vacuum advance, make sure you arent running too much initial mechanical - and you said you were.
Thats and engine killer under wot bc you dont loose mechanical advance. Let the vacuum can take care of light throttle cruise.
Take a look at your metering if you are running a carb. You have steady vacuum at a 650rpm idle?
You may want a stiffer metering spring if you are running a Carter or a fatter rod.
The Soot may just be a coincidence of taking time to get the car on ramps with choke. I'd would let it warm first before ramping it.
But taking the headers off I understand "the get er up and get er done".
And get rid of those NGK! Dare you try Autolite on a Chebby? They are a decent copper plug
