Vehicle sighting - 1968 AMC Javelin
by Number_35 - 05/27/20 04:22 PM
Looking for help on an old tiller
by BarryBl - 05/27/20 03:28 PM
is a larger alternator a no brainer?
by apollo18 - 05/27/20 03:02 PM
Rock Auto Code
by BAJA_05 - 05/27/20 01:42 PM
Considering 2019 VW Jetta
by KrisZ - 05/27/20 01:34 PM
Scheaffers moly worth it?
by mpgo4th - 05/27/20 10:50 AM
Flare wrenches
by hallstevenson - 05/27/20 10:43 AM
2000 Volvo S80 T6 Oil Recommendations
by MattV922 - 05/27/20 10:07 AM
2012 Mustang V6, 75w-140?
by RDY4WAR - 05/27/20 09:46 AM
03 WRX 203k miles P.P. 5w40 Euro
by TurboJW - 05/27/20 09:28 AM
13 Corolla U341E Filter
by AJB0009 - 05/27/20 09:19 AM
Brakes Pulsate when Hot
by artbuc - 05/27/20 08:57 AM
Castrol Magnatec Lexus DI application
by AzFireGuy79 - 05/27/20 08:31 AM
Wearing Mask Reinforced
by madRiver - 05/27/20 07:34 AM
2017 Nissan Titan SV 5.6
by ThrowinRocks - 05/26/20 11:30 PM
Need Some People to Do a Ping Test
by ZeeOSix - 05/26/20 10:22 PM
Dumb parking question.
by PhuongFU - 05/26/20 09:38 PM
spin on fuel filter
by mobilaltima - 05/26/20 09:36 PM
Peak Cool Orange no longer GM DEXCOOL Approved?
by Matt1980 - 05/26/20 08:10 PM
heikie, BarryBl, MattV922, Bruce_S, Rwogs
71540 Registered Users
100 registered members (53' Stude, 2015_PSD, 4WD, 10WSmuckers, 330indy, 55hambone, 10 invisible), 2,520 guests, and 23 spiders.
Topics305,939
Posts5,283,310
Members71,540
Page 1 of 4 1 2 3 4
Nickel vs Copper anti-seize #5399468 04/10/20 03:36 PM
The Critic Offline OP
My understanding is that Nickel anti-seize can withstand higher temperatures than Copper anti-seize. Ford specified the use of the Motorcraft Nickel anti-seize in their TSB for the 3V V8 engines as well.
Aside from cost, is there any reason not to use Nickel anti-seize (instead of copper or aluminum)? The application is general automotive.
2011 Toyota Prius 1.8L - 207K - Valvoline Premium Blue Restore 10W-30
2007 Honda Accord 2.4L - 146K - Valvoline Premium Blue Restore 10W-30
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399473 04/10/20 03:47 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
I used nickel antiseize everywhere for thirty years because I got a can of it gifted to me. This is well before I knew there were other types of antiseize. I see no problem using it anywhere.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399478 04/10/20 03:51 PM
bdcardinal Online Content
Online Content
Motorcraft Nickel Anti Seize This is the anti-seize Ford recommends.
1995 Ford Mustang GT
Ford/Mazda Parts Counter
NRA Benefactor Member
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399490 04/10/20 04:01 PM
J
JohnG Offline
J
Did you check their website?
It was my understanding, years ago, that Nickle-Ease was better on aluminum to aluminum threads, but could be used effectively elsewhere.
Copper was cheaper, so we started with that on steel bolts and flanges.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399552 04/10/20 05:10 PM
Yah-Tah-Hey Offline
GE specified N-1000 nickel anti seize for our steam turbine bolting.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399560 04/10/20 05:21 PM
A
atikovi Offline
A
[Linked Image from images-na.ssl-images-amazon.com]
I put that [censored] on everything.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399593 04/10/20 06:01 PM
tom slick Offline
[Linked Image from hvac-hacks.com]
You get what you pay for...
So keep in mind how much you paid for this advice.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399654 04/10/20 06:52 PM
T
Trav Offline
T
I use this one, not the cheapest but good stuff.
[Linked Image]
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399660 04/10/20 06:57 PM
Some sample SDS's:
Loctite 77124 (nickel): https://www.bettymills.com/product/MSDS/235028.pdf
Loctite N5000 (high-purity nickel): http://www1.mscdirect.com/MSDS/MSDS00012/88053293-20171201.PDF
Motorcraft XL2: http://www.jackbyrne.info/Msds%20PD...re%20Nickel%20Anti-Seize%20Lubricant.pdf
Permatex 77124: https://441py33rout1ptjxn2lupv31-wp...s/tech_docs/sds/01_USA-English/77124.pdf
Motorcraft and Loctite 77124 seem to be fairly similar. Permatex has the lowest amount of Nickel. Loctite N5000 is somewhere in between, but oddly enough, uses mineral oil as it's base.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399683 04/10/20 07:25 PM
T
thescreensavers Offline
T
Nickle works for all types of metals, and has a high temp tolerance. I don't buy anything else.
2017 Camaro SS 1LE (Motul 8100 X-clean 5W40)
1997 Jeep XJ 4x4 (15W40 HDEO Maxlife)
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399689 04/10/20 07:33 PM
B
borgward Offline
B
How do these compare to a Molybdenum disulfide paste? I have used Never-Seeze brand for years. A little dab will do you. There is no comparison between it and the Permatex ANTI-SEIZE LUBRICANT Tom Slick posted a picture of above. Great on things that get hot like exhaust manifold nuts and bolts. They come off easily years later. Great for exhaust pipe connections.I tried the Permatex stuff. Exhaust manifold nuts did not want to come off after only a few weeks. The Molybdenum paste is certified for nuclear use. Be careful with anything requiring a lot of torque as it is so slick that you turn the fastener more times, stretching the bold and causing failure.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399864 04/11/20 12:12 AM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I do wish there was a single document that provided the best type for each application.
My general observation is:
- plain silver is ok for low temp stuff
- copper is also ok but I prefer to avoid copper and aluminum together.
- nickel is more expensive and possibly worse for you if exposed, but goes on everything.
- zinc is good for alloy wheels on steel hubs.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399899 04/11/20 04:33 AM
F
FT92 Offline
F
nickel, have used it for 30+ years ...never a problem
Re: Nickel vs Copper anti-seize [Re: borgward] #5399931 04/11/20 06:35 AM
L
Linctex Offline
L
Originally Posted by borgward
How do these compare to a Molybdenum disulfide paste? I have used Never-Seize brand for years. A little dab will do you. There is no comparison between it and the Permatex ANTI-SEIZE LUBRICANT Tom Slick posted a picture of above. Great on things that get hot like exhaust manifold nuts and bolts.The Molybdenum paste is certified for nuclear use. Be careful with anything requiring a lot of torque as it is so slick that you turn the fastener more times, stretching the bold and causing failure.
I have been working on Pratt & Whitney and Allison/Rolls-Royce turbine engines for 30 years.
The burner can supports and igniters get nickel anti-seize. These fasteners are in the hot section, but NOT within the "exhaust stream" itself
Fasteners that ARE in the "exhaust stream" do indeed get Molybdenum Disulfide (Moly B) paste.
Re: Nickel vs Copper anti-seize [Re: The Critic] #5399941 04/11/20 06:52 AM
K
Kira Offline
K
I just completely cleaned my alloy wheel to hub mating surfaces.
I applied a thin coat of silicone grease. Maybe I should've used anti-seize.
Page 1 of 4 1 2 3 4
