Originally Posted by spasm3
Originally Posted by Chris142
I'm pretty sure that your Valvoline racing oil hads Detergents. You want a ND sae30. You do not want a detergent oil in that application.
Usually I agree with you, but here no. I would not run a no detergent oil in any combustion engine. I don't think it has any add pack or anti-wear components. ND oil is for hinges, and maybe compressors.
In the pump maybe, but not the engine.
+1
If the oil has detergents which I'm pretty sure it does, it should be fine to run in the pressure washer.
