Forums Migration
Please read this thread
Extra Load tires - Firmer ride?
by Spetz - 07/09/20 12:34 AM
make sure to use a software firewall
by 2004tdigls - 07/08/20 11:02 PM
Castrol 0w40 without LL-01 in BMW S63
by propellerhead78 - 07/08/20 09:59 PM
Automated key duplicators
by y_p_w - 07/08/20 09:59 PM
0W20 vs 5W20 base oils
by aquariuscsm - 07/08/20 09:39 PM
Shell Rotella T6 Multi Vehicle 5w30
by SummitX670 - 07/08/20 08:56 PM
Silicone rubber valve cover gaskets?
by Spetz - 07/08/20 07:59 PM
Back Up Camera
by Redright9 - 07/08/20 07:53 PM
Good Jackstands?
by 2015_PSD - 07/08/20 07:17 PM
Harbor Freight recalls more jack stands
by FordBroncoVWJeta - 07/08/20 07:11 PM
can a family of 4 use 34k gallons
by WhyMe - 07/08/20 05:26 PM
305 SBC Starter Grinding
by WA1DH - 07/08/20 05:19 PM
Ever hit a water meter with your riding mower?
by bchannell - 07/08/20 05:10 PM
Oil Recommendation 2020 GR Supra (Z4 har har)
by afree - 07/08/20 04:21 PM
Failing A/C compressor
by mb32 - 07/08/20 04:14 PM
PQIA 3 5W-30's 1 0W-20
by Jackson_Slugger - 07/08/20 03:35 PM
fl22 benefit over zerex?
by avi1777 - 07/08/20 02:51 PM
Brake Won't Bleed
by Gebo - 07/08/20 02:43 PM
Swimming Pool Chlorination
by Al - 07/08/20 02:30 PM
Sledstorm1, Wishiwereaskibum, snowshew, Tenderness, SummitX670
71888 Registered Users
41 registered members (19elantragt, alchargo, avi1777, BLND1, blufeb95, alcyon, 2 invisible), 902 guests, and 36 spiders.
Topics307,626
Posts5,314,473
Members71,888
Pressure Washer - Racing Oil? #5398572 04/09/20 03:41 PM
H
hal26 Offline OP
H
pressure washer calls for 30 wt. or 10w30. I have a lot of Valvoline RACING oil 10w30. Not rated and probably has no detergent additive. Should stand up to the very heavy loads and high summertime heat. This unit bakes oil real quick. What say ye?
2016 Dodge Challenger ScatPack 6.4
2003 Harley Road King
2019 jeep wrangler 4 dr 3.6
2019 Ram Hemi
2016 Triumph 1200 Thruxton
2016 Kawasaki Versys 1000 Sym wolf classic 150
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398587 04/09/20 04:07 PM
spasm3 Offline
Pressure washers sit a lot. More moisture, I would want an HDEO for a higher tbn.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398589 04/09/20 04:09 PM
Chris142 Offline
I'm pretty sure that your Valvoline racing oil hads Detergents. You want a ND sae30. You do not want a detergent oil in that application.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Pressure Washer - Racing Oil? [Re: Chris142] #5398602 04/09/20 04:34 PM
spasm3 Offline
Usually I agree with you, but here no. I would not run a no detergent oil in any combustion engine. I don't think it has any add pack or anti-wear components. ND oil is for hinges, and maybe compressors.
In the pump maybe, but not the engine.
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398655 04/09/20 05:14 PM
K
Kawiguy454 Offline
K
Are you talking the engine or the pump? 2 completely different environments there.
Re: Pressure Washer - Racing Oil? [Re: Kawiguy454] #5398737 04/09/20 07:32 PM
G
gman2304 Offline
G
HDEO, assuming you’re asking about the engine.
Re: Pressure Washer - Racing Oil? [Re: spasm3] #5398794 04/09/20 09:11 PM
J
jeepman3071 Offline
J
+1
If the oil has detergents which I'm pretty sure it does, it should be fine to run in the pressure washer.
1998 Jeep Wrangler Sahara 4.0L/5MT (157k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (63k) - Liqui Moly 5w40, MANN HU816X
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398898 04/09/20 11:08 PM
O
Oildudeny Offline
O
In the pump 30wt non detergent. TX heat I would run hd sae30 or 15w40
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398924 04/10/20 12:23 AM
L
Linctex Offline
L
What engine?
I have a vertical shaft Honda GCV160 (overhead cam) on mine, and it is super easy on the oil!
In the water pump, I always add a little STP to the oil.
Re: Pressure Washer - Racing Oil? [Re: Linctex] #5398934 04/10/20 12:58 AM
H
hal26 Offline OP
H
OP Here this is for the crankcase. Valvoline Racing 10w30 is designed for racing car engines under SEVERE racing conditions - high RPM -extreme loads and very high heat. It is not recommended for use on public streets and needs to be changed often. I have several quarts that (I want to use in something and this pressure washer works hot and hard for hours on end in Texas summer heat. I think I will give it a shot and change it every 25 hours......
2019 Ram Hemi
Re: Pressure Washer - Racing Oil? [Re: hal26] #5398948 04/10/20 02:05 AM
L
Linctex Offline
L
I think that plan will be just fine.
It's very likely the engineering on your power washer engine was done 50 years ago....
meaning any oil made in the last 30 years will probably run it perfectly fine.
Re: Pressure Washer - Racing Oil? [Re: hal26] #5399164 04/10/20 10:04 AM
J
jeepman3071 Offline
J
It's not recommended on the street because the racing oil has higher zinc which can be bad for cat converters on passenger cars. This wouldn't be an issue on a pressure washer engine.
Re: Pressure Washer - Racing Oil? [Re: hal26] #5399184 04/10/20 10:19 AM
K
kschachn Offline
K
Is this Valvoline VR1 Racing Motor Oil? If so then it is "rated", according to their PI sheet it is API SL and appears on the API EOLCS Directory:
https://sharena21.springcm.com/Publ...bd3/a61538b4-0cbd-e711-9c12-ac162d889bd1
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
