Goodwood Racing
by AZjeff - 05/31/20 10:23 PM
Blackstone Lab Question
by klt1986 - 05/31/20 08:19 PM
Fram oil filters at Advance Auto
by Electromotive - 05/31/20 08:02 PM
The Last Coat 2?
by tbm5690 - 05/31/20 07:33 PM
Can a car have too much battery?
by wings&wheels - 05/31/20 07:13 PM
Oil Extractor Pump Problem
by tc1446 - 05/31/20 07:11 PM
Tacoma fuel filter cut open
by funflyer - 05/31/20 06:53 PM
Electronic Octane Testers on eBay
by smonska - 05/31/20 05:35 PM
0W-8 is here: JASO GLV-1
by Gokhan - 05/31/20 05:26 PM
2010 Corolla What oil ??
by GMguy84 - 05/31/20 05:19 PM
Knock While Cruising, None While In Boost
by gathermewool - 05/31/20 04:11 PM
Replaced Golf Sportwagen with an Alltrack
by dareo - 05/31/20 03:27 PM
TW Ceramic Spray First Time
by Toros - 05/31/20 02:49 PM
The perfect tractor oil
by Chris142 - 05/31/20 02:42 PM
5.7 HEMI Lifter/cam failure cause
by Skippy722 - 05/31/20 02:38 PM
Battery 2013 4Runner 4WD
by Gebo - 05/31/20 02:29 PM
Supermarket Heroes 500 at Bristol
by bdcardinal - 05/31/20 01:55 PM
More M1 changes
by Flashlightboy - 05/31/20 01:49 PM
Car Reviewers
by borgward - 05/31/20 01:43 PM
Final charge global extender
by mker - 05/31/20 01:15 PM
Jcvjr, Haywood, ToOliwer, AbbeyRoad, RPF
71587 Registered Users
20 registered members (earlyre, Cdn17Sport6MT, 53' Stude, Donald1953, ctechbob, emod, 2 invisible), 1,158 guests, and 39 spiders.
Topics306,109
Posts5,286,667
Members71,587
Poulan 2900 46cc kicking my butt - Won't stay running #5398764 04/09/20 08:30 PM
deanm11 Offline OP
I got this unit as a throw when buying a guy's generator.
I finally got it running and it ran ok for a half hour session.
Couldn't get it restarted and decided to try Chinesium carb/spark plug/air filter.
It ran ok for about an hour. Couldn't restart. Tried a few days later and then a few days later. After much travail, could usually get it running for a few minutes.
I played with the L/H adjustments, starting with the 1.5 turns out point... a few times I got it to idle pretty nice at certain adjustment level, though most often it would bog under full throttle. And then after a few minutes
it doesn't want to idle or restart.
I checked based on one youtube and verified muffler screen not caked. I checked my source fuel can in a glass jar and though hard to tell because of color of 2-stroke oil, doesn't appear to contain separated water.
My best guess is intermittent coil. About $20 on Amazon. Any other suggestions?
2012 Subie Impr 2.0 142k M1EP 0w20 7.5k
2002 Tahoe 5.3 171k 5w30 syn 7.5k
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5398790 04/09/20 09:07 PM
deanm11 Offline OP
I should have included- new fuel line was included in kit but did not change it initially due to new line OD being much bigger than stock. Today finally opened up the hole into tank to accommodate new fuel. No difference, I don't think.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5398925 04/10/20 12:37 AM
L
Linctex Offline
L
I have never owned a Poulan saw I could honestly say I was the possessor of.
All of them I had high expectations for, and all of them have failed miserably.
My Stihl and Makita (Dolmar made, Germany) are so well made, so well-performing, and so reliable....
There's just no sense in subjecting yourself to the frustration.
YES - I suggest that you Don't fight it - - sell it to someone else to play with.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5398966 04/10/20 04:53 AM
K
Kamele0N Offline
K
Check/replace also semmerings on its crankshaft... If they leak air inside body...
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 (Shell?) 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Shell Rimula R6M 10W-40
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5398972 04/10/20 05:05 AM
L
Lubener Offline
L
That is it, you are guessing. When it fails to start, do you lose spark?? Will it attempt to start with ether? I don't trust anything coming from China and would look more closely at that cheap Chinese carb. A long shot, look at the flywheel and key. I have a Stihl chansaw which had a flywheel with a screwed up key slot which threw the timing off just far enough that I couldn't start the dang thing. Could also be worn out where the compression just won't pull in the fuel from the carb.
The "thinking" man's friend.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5398974 04/10/20 05:21 AM
deanm11 Offline OP
Thank you for the ideas... I am going to try to check the spark. I had read sometime last night about worn crankshaft seal or the like can lead to not enough vacuum to draw the fuel/air mix.
My next saw will be a nice Stihl for sure when I'm ready to spend the money. (ms291)
Dean
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5399077 04/10/20 08:44 AM
chainblu Offline
There are very few things more frustrating than a balky chain saw!
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5399081 04/10/20 08:47 AM
deanm11 Offline OP
Verified good spark while in no start condition this morning. Started right up on ether. It would run very briefly.. you could see at least some fuel flow through gas line.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5399611 04/10/20 06:16 PM
dave123 Offline
Dean
Nice Sthil MS 261cm that’s when your ready.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: dave123] #5399913 04/11/20 05:34 AM
L
Lubener Offline
L
Dean
Shop around, the new Stihls are not what they used to be and have been cheapened quite a bit. I would look at Husqvarna and Echo.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5399954 04/11/20 07:16 AM
spasm3 Offline
Echo is an excellent saw in the non pro class.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: deanm11] #5399956 04/11/20 07:19 AM
4WD Offline
My mean green no starting machine went to the curb at one year. Bought a Stihl gasser and Worx 120v
I do lots of light jobs with the electric … so quiet and easy to control.
Re: Poulan 2900 46cc kicking my butt - Won't stay running [Re: spasm3] #5399960 04/11/20 07:28 AM
dave123 Offline
Correct and it’s not in the class of a Stihl 261 pro saw or Husqvarna 550xp
