Mobil1 12 quart $30 at Walmart
by wkcars - 06/03/20 12:58 AM
"The Bright Knight"
by GumbyJarvis - 06/03/20 12:35 AM
Pennzoil Axle oil with LSA.
by Snagglefoot - 06/02/20 10:03 PM
Replaced the plugs on the bike: HUGE improvement!
by 14Accent - 06/02/20 09:26 PM
Accord Trans Case crack (bad casting?)
by redhat - 06/02/20 08:38 PM
Replacement SLA Battery for Clore Jumper
by SubLGT - 06/02/20 08:34 PM
ABS codes
by 2010Civic - 06/02/20 08:02 PM
Tie rod ends - which manufactures ok?
by jdw1222 - 06/02/20 07:40 PM
Who makes their own seltzer water?
by JLawrence08648 - 06/02/20 07:23 PM
Slight Tire Bulge
by coopns - 06/02/20 06:13 PM
gm 6.2l cylinder 8 misfiring only at idle
by apollo18 - 06/02/20 04:59 PM
Ford flex
by Micahmcmeen - 06/02/20 03:42 PM
Hengst Blue.care
by service_now - 06/02/20 03:14 PM
Windows Movie Maker
by Jetronic - 06/02/20 02:46 PM
Motul X-cess Gen2 and X-clean Gen2 5W-40
by The Critic - 06/02/20 02:10 PM
ATF Differences?
by AJB0009 - 06/02/20 02:01 PM
Worst relationship you've ever been in
by Lolvoguy - 06/02/20 01:58 PM
2 cycle with catalyst - carb settings?
by cjolson140 - 06/02/20 01:22 PM
boathead, Digital_Dad, RobertChapmant, NewMex, RandyN11049
71596 Registered Users
24 registered members (Char Baby, alchargo, A_Privateer, chemman, blufeb95, ArrestMeRedZ, 1 invisible), 1,313 guests, and 70 spiders.
Topics306,079
Posts5,286,958
Members71,596
Meprolight Night Sights #5398648 04/09/20 05:06 PM
BlueOvalFitter Offline OP
I have these night sights on my 2 LE trade in 1.0 M&P .40's. One was made in 2015, the other, 2016. The sights are extremely bright. And, they have a 12 year warranty.
Other than getting them when you bought a LE trade in, did you install some on your M&P? If so, why did you choose Meprolight?
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5398653 04/09/20 05:12 PM
2015_PSD Offline
My M&P's are wearing Truglo tritium sights, but I have used Meprolights on SIG pistols in the past. They still glowed after 15 years but had dimmed somewhat. No problems with them at any point.
Fairly certain that HK VP9 and VP9SK factory night sights are Meprolights.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Ultra]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Meprolight Night Sights [Re: 2015_PSD] #5398667 04/09/20 05:30 PM
Marco620 Offline
HK is meprolights made in Israel! Good stuff too. Right now I'm on the serrated rears blacked out and front sights only.
15' Civic r18, 335,000 mi M1 0w30/5w30 & LG Biotech,Castrol CVT Fluid,Redline Si-1
Dog Whisperer! Honda/Acura nerd; detest ethanol,wind, and anything vegan.
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5398692 04/09/20 06:15 PM
ctechbob Offline
I used to choose Meprilite over Trijicon simply because at the time, Trijicon painted the white around the tubes whereas Meprolite used white plastic that held up better over time.
These days I use the Glock brand night sights. No idea where they come from, but they are good value (If you own a Glock that is)
2008 Acura TL Type S-170k
2003 Honda Accord V6-222k
Oil-Havoline HM 5W30
Filter-Partsmaster 61334
Trans-Idemitsu H+
Re: Meprolight Night Sights [Re: ctechbob] #5398768 04/09/20 08:32 PM
Not a Glock owner here.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5398926 04/10/20 12:38 AM
W
WhyMe Offline
W
i bought a brand new glock 19 in 1989 and had meprolights installed . used it for a few years and then put it away. after 20 years i pulled it out to clean and check . Checked to see f there was still any glow to the sight. even after 20 years there was still some. not like new of course, but still enough to see in a dark room.
always prefered mep instead of trig because of the circles ad stated by another post.
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5399967 04/11/20 07:37 AM
I have never been a night sight fan. I figure if you're going to take time to adjust your aim at the bad person at night with night sights, you're going to be a GONE PECAN! The night sights were already on my M&P's when I bought them. I think they do help your aim at night, but as I stated earlier in my comment, you will be gone before you have time to sight up the bad guy. I'm not going to go out of my way to remove them. They are very useful during daytime hours. Not glowing of course, but for a great aiming sight.
2007 F150, 4.2 V6
"One Box, One OCI!"
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5400037 04/11/20 09:01 AM
H
hatt Offline
H
Night sights allow you to see your sights at night. That's a nice feature. I'm not sure why night sights would slow you down at night vs no sights.
2013 F150 5.0, Delo 400 SD 15W-30, Wix 57502
2010 Camry 2.5, PP 10W-30, Mobil1 M1C-251A
Re: Meprolight Night Sights [Re: BlueOvalFitter] #5400124 04/11/20 10:42 AM
B
bsmithwins Offline
B
Sight use is situational. If you’re at bad breath range grossly pointing a pistol and firing is the correct action. If your 30 feet away down a hallway you need your sights to hit.
In the dark it’s easy to get into a situation where your target is silhouetted. Without night sights you might not be able to see how your pistol is oriented against a dark background.
BSW
