Forums Migration
Please read this thread
API SN safe for TGDI?
by mdixon26288 - 07/07/20 02:18 PM
borgwarner 4484 t case dexron iii or gear oil?
by apollo18 - 07/07/20 02:12 PM
Hand Sanitizer warning : Methanol
by odie - 07/07/20 02:11 PM
BEST Oil Filter for 2020
by DCMotorsports - 07/07/20 12:39 PM
1997 Lancruiser/Colorado/
4Runner wishbone bolt
by Kamele0N - 07/07/20 12:33 PM
why change oil on low mileage car consuming oil
by NewC-05 - 07/07/20 11:50 AM
Which oil to use?
by HydroxZ - 07/07/20 11:02 AM
What oil for supercharged Lotus Exige?
by mkiv808 - 07/07/20 10:59 AM
Carb Metering Diaphrams
by Fordiesel69 - 07/07/20 10:30 AM
ABS Brake Bleeder/Pulsate Software?
by shibby6600 - 07/07/20 10:30 AM
NAPA Gold vs. WIX
by DCMotorsports - 07/07/20 10:11 AM
A/C symptoms-what to do?
by sipman - 07/07/20 09:59 AM
M1 and Liqui Moly - can I mix?
by ssoH - 07/07/20 08:47 AM
HF JACK-STAND RECALL EXPANDED
by demarpaint - 07/07/20 08:15 AM
Five Euro Car Myths?
by BMWTurboDzl - 07/07/20 07:46 AM
Trust Funds
by stockrex - 07/07/20 07:28 AM
3 on the tree
by Chris142 - 07/07/20 07:21 AM
ROCKAUTO selling old expired stock.
by nicholas - 07/07/20 07:21 AM
Amsoil SS 5w30
by mpgo4th - 07/07/20 06:57 AM
Water/Coolant Contamination?
by nastyc5 - 07/07/20 06:53 AM
HydroxZ, JDMorgan, sycboi, Chuck_Ellison, BakonBittz
71871 Registered Users
111 registered members (AlienBug, 2015_PSD, AandPDan, 4WD, 69Torino, Alfred_B, 12 invisible), 2,020 guests, and 27 spiders.
Topics307,555
Posts5,313,061
Members71,871
Oil accumulator to prevent engine wear #5398564 04/09/20 03:32 PM
IMSA_Racing_Fan Offline OP
I remember hearing some number like 90% of engine wear occurs at startup.
Has anyone here seen, heard, or installed themselves a hydraulic accumulator with a solenoid operated valve that shuts off and on with the ignition switch?
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398571 04/09/20 03:38 PM
CT8 Offline
Yes and there are also electric primers pumps.. The question is do we really need one? May be for a seldom driven vehicle. I hear lots of stuff and we need to discern what we hear. Usually a maintained reliable engine brand out lasts the vehicle.
2015 F150 2.7
2018 F350 6.2
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398630 04/09/20 04:55 PM
2
2009Edge Offline
2
AMSOIL had one with a solenoid and accumulator at one time.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398633 04/09/20 04:57 PM
R
ripcord Online Content
Online Content
R
I had a project manager whos late 80s Mustang SVT burned up a couple of turbo's and when he tore one down he found coked bearings. To try to fix the issue he installed an accumulator that released whenever oil pressure fell below a certain point. It was plumbed into T at the turbo's oil line to give it some extra oil pressure while it spun down at shutdown.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398671 04/09/20 05:39 PM
Marco620 Offline
Apexi Turbo Timers work great. Pull E brake up,set for 5 minutes and pull key out. I think if the car was seldom ran then doing the Lubegard storage additive https://www.lubegard.com/products/free-eze/
I think this also might be a case where a high ester based oil might work really well.
15' Civic r18, 344,000 mi M1 5w30(3qt)/Redline 5w30(1qt),Castrol CVT Fluid,Redline Si-1
Doberman Whisperer! Honda/Acura nerd; detest ethanol,wind,"green" ,solar & vegan.
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398687 04/09/20 06:07 PM
K
kschachn Offline
K
The majority of wear does not occur at startup, that is a myth. The majority of wear occurs during the warmup phase.
1994 BMW 530i, 253K
1996 Honda Accord, 289K
1999 Toyota Sienna, 437K
2000 Toyota ECHO, 290K
Re: Oil accumulator to prevent engine wear [Re: IMSA_Racing_Fan] #5398769 04/09/20 08:32 PM
B
bulwnkl Online Content
Online Content
B
Low-rpm, low-flow, post-start is when the accumulator would be diverting oil from the engine to re-charge itself. So, you’d have pre-oiled, but then have insufficient flow for a while after start-up. Are you accomplishing much with such a system?
I understand the concept here, but if I wanted to spend money and time on a pre-oiler, I’d use an electric pump. That eliminates:
—the need to regularly check or re-charge the accumulators (that was nearly an annual need on some of the tractor transmissions), and
—the diverted oil flow when the engine is already receiving least oil flow.
I use speech recognition frequently. Please excuse any consequent grammatical or typographical errors.
